disable steering wheel airbag
Discussion in 'Street Trucks' started by Bullperry, Jun 8, 2015.
  1. Jun 8, 2015 at 8:46 AM
    Bullperry
    Bullperry [OP] Member
    Emerald Coast NW FL
    Caucasion Tacoma 2011 SR5
    Exterior decor: red-clay mud splatter.
    I had an accident two years ago which ruined the very top vertebra where it joins the skull. If my airbag should activate, I could be paralysed for life. I am having trouble getting instructions on how to disable the steering wheel bag on my 2011 Tacoma x-cab.
  2. Jun 8, 2015 at 9:05 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  3. Jun 8, 2015 at 9:19 AM
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    disable it, look for clock spring/ spiral cable install thread. It shows how to and shouldn't take more then ten min. airbag light will always be on though
  4. Jun 8, 2015 at 9:24 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Get the bottom of the seats wet, sensors are under there. Bingo, no more air bag deployment.
  5. Jun 8, 2015 at 9:26 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    I'm sorry but how is it any different if you get into a wreck that sets off the front air bag and instead of an air bag you slam into the steering wheel?
  6. Jun 8, 2015 at 9:33 AM
    Bullperry
    Emerald Coast NW FL
    I was "thinking" (LOL) an accidental airbag deployment.
  7. Jun 8, 2015 at 9:38 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    https://www.tacomaworld.com/threads/installed-steering-wheel-audio-controls-on-my-08.316944/
    I have a sneaky feeling that unplugging the two airbag connectors might also disable the horn. To me, driving mostly in rush-hour traffic, the horn is the most frequently used steering wheel control and an important safety item.
  8. Jun 8, 2015 at 9:41 AM
    mightytacoman
    Kel
    4.5L 1grfe
  9. Jun 8, 2015 at 10:58 AM
    Bizarroterl
    Bizarroterl Well-Known Member
    SJ, CA, USA
    2009 Accesscab 4cyl 2wd, 2010 Xrunner
    DJM 3/3, Hellwig rear sway, Rear Spoiler, Truck Covers USA tonneau, rear spoiler. Dynolock tailgate electric lock. Pioneer avic-z110bt. Xrunner is stock for now
    Wouldn't your seat belts keep you from hitting the steering wheel?
  10. Jun 8, 2015 at 11:02 AM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Never know. We don't know size of op or if he even wears it.
  11. Jun 8, 2015 at 11:21 AM
    Bizarroterl
    SJ, CA, USA
    I always assume that one would be wearing their seat belt. It's just a common sense thing, like not poking yourself in the eye with a sharp stick.
    As for the vertebra issue - the physics in a crash really stack the deck against humans. Our necks aren't designed to take the forces. That's why all cars now have headrests. They're not so you can rest your pretty head when you're tired, they are there to keep you from popping your neck when some drunk loser hits you a 50 mph while you're stopped at the red light. When you hit something while you're moving a seatbelt stops your body but does nothing for your head. I assume that's what the air bag is for. So wouldn't disabling the air bag actually be a worse situation than leaving it active?
  12. Jun 13, 2015 at 9:04 AM
    Bullperry
    Emerald Coast NW FL
    In my 1911 Tacoma, after reading your reply, I re-installed the headrest I took out when it was new. On the driver side. The passenger headrest stays out. I have the extra cab with the suicide doors and the P-side headrest creates a huge blind spot when duking it out in traffic. I find this design flaw almost unbelievable, it is that bad, and I am hoping Toyota has done something about this in later models. Thanks much for your advice — you and the rest of you who responded.
  13. Jun 13, 2015 at 2:59 PM
    Bizarroterl
    SJ, CA, USA
    I pulled the rear head rests (extracab too). For visibility I have Multivex mirrors. With those I can see extremely well. Merging and lane changes are a piece of cake. I don't have a blind spot. If it isn't in the mirror, I can see the fender directly or it isn't there.
  14. Jun 14, 2015 at 8:38 AM
    Bullperry
    Emerald Coast NW FL
    Right. If it ain't in the mirros it ain't there! I also have something learned from a Brit friend from the service: I live on a dirt road and when I am too busy or broke to get the Tacoma washed, I go out there with an old towel and a spray bottle of 409 and get only what I can see from the driver seat. Looks great going down the road! No chicks at mailboxes on my route, so....
  15. Jun 14, 2015 at 8:40 AM
    Bullperry
    Emerald Coast NW FL
    What does that [OP] after the name under my photo mean?
  16. Jun 14, 2015 at 8:45 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Original poster. It means you started the thread.
