Disable tire pressure sensors?
Discussion in 'Wheels & Tires' started by 08Tacoma, Aug 27, 2009.
  1. Aug 27, 2009 at 3:55 PM
    08Tacoma
    08Tacoma [OP] Well-Known Member
    Arizona
    2008 Tacoma, DblCab, 4x4, TrdSport, BlackSandPearl, 2.5" Toytec, TubeSteps, WindowTinting
    Does anyone knows how to disable the fricking tire pressure light?
    I'm sick and tired off that light been on all the time?
    Any suggestions?
    Thanks.
  2. Aug 27, 2009 at 3:56 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    air your tires up? :p
    just messin, im not sure how to disable it.
  3. Aug 27, 2009 at 3:57 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i removed the led on mine..... simple fix but does require tearing the cluster apart.
  4. Aug 27, 2009 at 4:01 PM
    TicTacOma
    TicTacOma UnderWater Monopoly Champion
    Anastatia Beaverhausen
    Columbia,SC
    I'm Thinking...Oh Yeah...An FJ
    It's all in my head at the moment...
    Find out WHY it's on all the time. Is your spare tire inflated to the proper pressure or equal pressure of the others? Is the spare tire EVEN there? If it's missing, it'll throw the light (unless it's an '09)
    It's a simple light but so aren't the others. If the oil light was on you'd dive into that to see what was up.
    It's a safety thing mandated or suggested by the Feds for car companies to comply to. I'm pretty sure you won't find a dealer or reputable mechanic to disable it due to the ramifications of responsibility.
    Take some black electrical tape and cover it up for a simple solution.
  5. Aug 27, 2009 at 4:05 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  6. Aug 27, 2009 at 4:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You could also get a tractor or small trailer tire and put all the sensors IN it and air up up...press reset...and hide the tire in your truck somewhere (under the frame, in the spare, under a seat, etc etc). A piece of capped PVC also works.
    Finding out why it's on makes sense too...
  7. Aug 27, 2009 at 5:21 PM
    Fire931
    VA
    00 4Runner
    well if your still running the sensors i would say find out why its on... but in my case i removed all the sensors so obviously it stayed on all the time.. thus the reason for my fix.
  8. Aug 27, 2009 at 6:17 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    When dealing with it, consider that the D@mned feds require that it be fixed before it leaves a shop. I dont know if you do your own tires, it would suck to go in for something then they say gotta fix this too....oh about $100/ $50/ $250, who knows
  9. Aug 27, 2009 at 6:40 PM
    cornwall325
    cornwall325 Toyota newbie...
    Jonathan
    Virginia
    09' D.C. TRD Sport 4x4
    Seatbelt chime turned off, Toyota bedmat, Wet Okoles, stock other than that.
    I like Fire's idea the best as far as disabling the sensors! :)
  10. Aug 28, 2009 at 8:31 AM
    sdel82
    sdel82 Active Member
    Northeast
    09 dbl cab
    Hey fire how difficult is pulling the cluster apart? I have no sensors. In same boat.
  11. Aug 28, 2009 at 8:46 AM
    Fire931
    VA
    00 4Runner
    its not difficult at all.. takes about 15 mins to have it completly disassembled. you will need a soldering iron to take out the led though.
  12. Aug 28, 2009 at 9:18 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    PVC bomb.................
    Cap a 3" dia piece of sch 40 PVC pipe, put all the sensors inside it and cap the other end with a tire valve installed in the cap, then presurize it and hide it in your truck.
  13. Aug 28, 2009 at 9:26 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Can PVC handle that kind of presure long term?
  14. Aug 28, 2009 at 9:58 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Doesnt the manual have a section on disabling it? Like hold the button down while you start, something like that. Maybe not a disable but a reset/recalibrate.
  15. Aug 28, 2009 at 10:08 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    bingo..no manufactuer will have a disable procedure on tire sensors;)
  16. Aug 28, 2009 at 12:01 PM
    EricT
    Arizona
    So recalibrate them at 0psi.
  17. Aug 28, 2009 at 1:13 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Interesting idea. I may have to try that.
  18. Aug 28, 2009 at 2:37 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Wouldn't you have to reset them to 14.7psi? I guess you could take them to 10 meters under water and set them at 0psi... :D
  19. Aug 28, 2009 at 4:04 PM
    Tacoyota
    08 4wd
    nope, just pull the valve out of the stem, once the air is out its at 0 psi, then try the recal. at that time. I'm curious if the system can do that.
    p.s. jack up the truck or something lol dunno about sitting on 4 flats
  20. Aug 28, 2009 at 4:12 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Can you put them in a small, strong balloon like the one pictured below??
    :D:D:D:D:D:D
