Disable tire pressure sensors?
Discussion in 'Wheels & Tires' started by 08Tacoma, Aug 27, 2009.
  1. Aug 28, 2009 at 4:16 PM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    They will not reset at low pressures. I had mine sitting in my center console and tried to reset to them and the light would not go out.
    Since then I've had them installed in the FJ Cruiser rims I bought when I had new tires put on.
    One way to cover the problem is to take a small piece of black tape and put it on the clear plastic right over the light. Doesn't make it go out, but at least it blocks your view of it.
  2. Aug 28, 2009 at 4:21 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Testicle Pressure Maintanence Sack :p
  3. Aug 28, 2009 at 4:24 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Standard Atmospheric pressure is 14.7 psi.
    http://www.engineeringtoolbox.com/pressure-d_587.html
    http://www.pumpworld.com/Absolute Pressure.htm
    Example: The tire has 35psi in it... That is gage pressure (as read by a tire gage). Take that and add 14.7 psi atmospheric pressure and you get 49.7 psi (absolute pressure)
    So... if you let all of the air out of the tire you get 0psig, but you get 14.7psi... it all boils down to semantics. :D
  4. Aug 28, 2009 at 4:27 PM
    Tacoyota
    08 4wd
    i agree standard pressure is 14.7.. but rememberits compentated for at the guage , so 0 is 0.
  5. Aug 28, 2009 at 4:29 PM
    Tacoyota
    08 4wd
    :eek:but wait , what if its p-metric, then u HAVE TO USE BARS ..right?:p
  6. Aug 28, 2009 at 4:39 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    I kinda did this. I took out the gauge cluster though, took off the clear plastic shield, lifted the black thin backing and slid electrical tape over the light. Then let the thin black backing back down, snap back together the plastic cover onto the gauge cluster, and viola! Make sure you use two pieces though. I used only one piece at first and it was still faintly visible in the dark...
  7. Aug 28, 2009 at 4:43 PM
    Tacoyota
    08 4wd
    after firestone owners, (the idiot ones) and our government deciding on TPMS (hey why blame an idiot, right?) we should feel lucky they didnt ban tires alltogether:eek:
  8. Aug 28, 2009 at 11:28 PM
    Inked Tacoma
    Inked Tacoma GOT INK?????
    Jeremy
    Central Coast Cal
    2019 Tacoma TRD Sport DCLB
    2019 Tacoma TRD Sport DCLB De-Badged, Tent done Coming soon Bilstein set at 2 inch fronts rear 1.5 AAL 17 inch wheels and 265 BFG AT..... Speaker replacement sub and amp and of course window tent! Gone but not forgotten 08 Prerunner TRD Rugged Trail ICON Coil-overs/2.5 V.S. Series Remote Resi Shocks ICON Uni-Ball arms Camburg lift spindles ( Removed Swaybar) Dever 3 inch Lift Springs & Flip Kit, KMS XD Enduro 16x8 258/75 Mickey Thompson BAJA ATZ TRD Cat-Back Tint 30% side/Limo in back. The one that started it all 1999 Tacoma Preunner 6 inch Fabtech drop-bracket with custom kings all the way around AllPro 5 inch springs 35's custom paint and one bitch-en Alpine seystem for sound!!!
    Try this link and go to page 5 post #126 its a good deateld pic bypic write up enjoy... http://www.ttora.com/forum/showthread.php?t=26691
  9. Aug 28, 2009 at 11:35 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Yes, I remember some people trying that. I think it only works on 05-06's, no 07's 08's or 09's if my memory serves me correctly. All I know is I have an 08 and was warned by someone else who has an 08 and tried it, that it does NOT work on 08's.
    Black tape is much more comforting to me... nobody could find my black tape mod even if they were sitting in the drivers seat looking for it.
    EDIT: I even believe someone looked up the diagrams by model year and confirmed this.
  10. Aug 29, 2009 at 5:02 AM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    It would be like 30 PSI or so and the sch40 pipe will take a lot more than that to fail.
    Fasten the "bomb" to the frame near the spare if it bothers you to have it inside the cab and make the valve accessible in case the pressure ever drops.
    Cheap and easy mod that I'll do if I ever change my OEM rims.
  11. Aug 29, 2009 at 6:39 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
  12. Aug 29, 2009 at 7:29 AM
    Mr. T
    Mr. T Well-Known Member
    Gulf Coast, Texas
    06 4x4 SR5 Black
    There are some pretty good ideas on here. But as for me I know that when my light came on it was simply my spare tire pressure that had affected it. Once I pumped that back up problem solved. I'd say check that first.
  13. Aug 29, 2009 at 2:26 PM
    Mandy3206
    San Juan PR
    The bomb or small tire tricks is for vehicles with new wheels that doesn't accept the sensors, if you have the OEM wheels and sensors, I don't see why this would be needed.
    I've corrected my low pressure tires before they even start to show the bulge thanks to the TPMS system.
    OEM tires lasted 40k with even wear so it makes sense to monitor your tires.
  14. Aug 29, 2009 at 4:59 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    My light only flashes when I get too far away from the stock sensors mounted in my steel winter tire set stored in the garage.
    When the light comes on, here is my disable light mod.
    Works great & I have card ready to hand out when I'm travelling thanks to neontrail :thumbsup:
