disable TPMS in 15 seconds????? fact or fiction
Discussion in 'Wheels & Tires' started by TacoTitan11, Jun 23, 2012.
  1. Jun 23, 2012 at 2:51 PM
    TacoTitan11
    TacoTitan11 [OP] Well-Known Member
    Mr. C
    North Carolina
    2012 Tacoma
    another member wrote this: is this true?
    "to completely disable it all you have to do is hold down the TPMS button for about 15 secs while you are driving. I did it awhile back and it has never come back on, even when the weather got about 35 degrees cooler over the weekend and i know the pressure went down. The guy at the Toyota service center told me how to do it, but he told me it would be about $70 for them to reset the sensor if i ever wanted it to work again. I didn't need it, i check the tire pressure every so often anyway, so i am ok without it. But do at your own risk."
  2. Jun 23, 2012 at 2:54 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Hold the TPMS button down for 15 seconds and find out for yourself.
  3. Jun 23, 2012 at 2:56 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    well mine is not on....im checking to see if anyone has heard of this procedure
  4. Jun 23, 2012 at 2:57 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Where's the TPMS button?
    Edit: Oh down below. nvm
  5. Jun 23, 2012 at 7:00 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    i think he was talking about the reset button underneath the steering wheel
  6. Jun 23, 2012 at 7:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    No, it does not work.
    All the other guy did was reset his system. 35 degree temperature drop will not be enough to trigger it.
    My light comes on flashing for the first block or two, then remains on solid.
    I've aired everything up to 35 and held the reset button while parked, driving, beating my meat, etc... aired down to 25, held the reset button while parked, driving, beating my meat, etc... then pumped back up to 35.
    Nope... it doesn't disable it.
  7. Jun 23, 2012 at 7:09 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    whats so funny?
  8. Jun 23, 2012 at 7:09 PM
    TacoTitan11
    Mr. C
    North Carolina
    2012 Tacoma
    ok, thanks :)
