Disabled TPMS light on my 2008
Discussion in 'Technical Chat' started by bama trd, May 21, 2010.
  1. Nov 19, 2012 at 9:27 AM
    #41
    Spark2002
    Spark2002 Member
    Worcester, MA
    2008 Tacoma Access Cab, 1998 Tacoma (R.I.P)
    Hella 500 FF, eBay OEM fog lights, Tonno Pro bed cover
    This works just as described, I just finished doing it on my 2008 Tacoma, I broke one of the valve stems because I used steel caps on them. A coupole things I encountered...
    1. The red TPMS module is really in there and mounted to two metal tabs it slides on, I had to remove the radio and and middle dash to get a good grip on it.
    2. Wire the hot lead to the fuse box, I tried tapping in to a hot lead on the blower control and every time I put the fan on, the TPMS light would come back on.
    AxisCab likes this.
  2. Dec 26, 2012 at 8:01 PM
    #42
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    when i change tires for winter always have lite on,,not worth $ to put on 2nd set on rims.it is a pain but black tape works as well.
  3. Sep 22, 2013 at 4:18 PM
    #43
    camit34
    camit34 Well-Known Member
    Aaron
    CO
    '08 Mostly Stock
    Just did this - Worked perfect! Thanks!
  4. Oct 31, 2014 at 12:21 PM
    #44
    circleba3
    circleba3 New Member
    Bernie
    New Jersey
    06 Tacoma
    I think the easiest thing to do is put a small piece of tape over the light. Just don't be lazy and forget to check the tire pressure and I ball them daily.
  5. Feb 23, 2016 at 6:21 PM
    #45
    ThrSitRep
    ThrSitRep Member
    Greg
    Puna, Hawaii
    hilomoto.com
    Frantz bypass oil fiter
    I have a 2012 and tried all of the various things to get that light off finally just said screw it and took the instrument cluster out and subdued that Mofo with a sharpie. worked like a charm. LOL
    AxisCab likes this.
  6. Mar 29, 2018 at 2:49 AM
    #46
    Orphanadam
    Orphanadam Member
    2008 tacoma
    2" suspension lift
  7. Mar 29, 2018 at 2:50 AM
    #47
    Orphanadam
    Orphanadam Member
    2008 tacoma
    2" suspension lift
    I know this thread is kind of old, but what size fuse should I use in the fuse link from blue wire tapping into yellow wire?
  8. Mar 29, 2018 at 3:20 AM
    #48
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Fuse size should be reliant on wire size as if too amperage is sent through the wire you want the fuse to blow before the wire melts, wires make pretty lame fuses and are harder to replace when they blow.
    So assuming that wire is 16-18 gauge and 16-18 gauge wire can carry 10-6 amps I would run a 5amp or 2.5amp fuse if you can find one in that atc size.
    That tpms system probably only really uses .1 amps.
    AxisCab likes this.
  9. Mar 29, 2018 at 1:22 PM
    #49
    Orphanadam
    Orphanadam Member
    2008 tacoma
    2" suspension lift
    Thank you key.
  10. Mar 31, 2018 at 8:52 AM
    #50
    Orphanadam
    Orphanadam Member
    2008 tacoma
    2" suspension lift
    Thanks bama, this worked great and pretty easy to do also.
  11. Mar 31, 2018 at 8:53 AM
    #51
    Orphanadam
    Orphanadam Member
    2008 tacoma
    2" suspension lift
    tcBob likes this.
  12. Apr 7, 2019 at 9:22 AM
    #52
    08RC
    08RC Well-Known Member
    Makes me feel good to undo something Obama was behind making mandatory.:drevil:
    AxisCab likes this.
  13. Apr 10, 2019 at 6:50 PM
    #53
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
  14. Oct 20, 2019 at 11:17 AM
    #54
    tacom08
    tacom08 Well-Known Member
    Isaac
    Simpsonville, SC
    08 DCSB 2WD Rugged Trail Edition
    Flowmaster Super 10, K&N CAI, bumpers, LED taillights
    So I tore down the dash but I wasn’t able to unplug the wiring from the red box. Am I supposed to pull up on the red box to disconnect it?
  15. Feb 6, 2020 at 5:48 PM
    #55
    Scott Wally
    Scott Wally New Member
    ‘09 Tacoma 2WD
    Subbed for later - thanks!
  16. Oct 9, 2020 at 10:07 PM
    #56
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I'm overhauling my car stereo and decided to try this tpms disable mod since my dash light is on due to dead tpms batteries.
    I'm glad to say that it works as advertised on my '08 TRD OR.
  17. Oct 30, 2020 at 11:54 AM
    #57
    scoostraw
    scoostraw Well-Known Member
    Ken
    Wisconsin
    1995 Tacoma 4x4 Ext Cab 6cyl 5-Speed
    I was going to try this, but my red/white wire does not have 5V on it(??)
  18. Oct 31, 2020 at 7:56 AM
    #58
    scoostraw
    Ken
    Wisconsin
    Thank you to the OP and to everyone for all the follow-up for this thread. I recently acquired a 2008 that has had the wheels replaced and does not have wheel sensors, hence the light is always on.
    To get to the TPMS module, I removed the radio as well as the surrounding bezel. Everything just pulls off.
    I found a wire with +6v at the radio, so I tapped into that to tie up the blue wire. It worked perfectly. Below is a photo which shows a green test lead connecting the two wires as I tested this:
    This saved having to run a wire elsewhere in the dash.
    Thanks again to all. Happiness is having that frigging light off!
  19. Jan 27, 2021 at 1:58 PM
    #59
    hazard2600
    hazard2600 Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    Worked Like a charm! My TPMS was actually blue in my 2009.
  20. Dec 24, 2021 at 8:31 AM
    #60
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    I've got a dumb question, is there not a hot wire on the plug that goes to the TPMS ecu?
