Disabling Button Illumination?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Okkine 2.0, Sep 13, 2023.
  1. Sep 13, 2023 at 7:15 PM
    #41
    Taco Monster 20
    Taco Monster 20 Well-Known Member
    2020 Silver Tacoma TRD OR DCLB
    Yeah. Like me, bought mine as a lease turn in. No manuals. But I did download them.
  2. Sep 13, 2023 at 7:17 PM
    #42
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    You held the switch until the illumination progress bar on the center display made it all the way to the left?
    I imagine the Body Control Module behind the OBDII port controls illumination. Since the switch that adjusts illumination is literally a switch, then it's likely the BCM programming that determines what the low-end or "floor" value for illumination can be in the instrument cluster and any other place that can be dimmed with that switch. Maybe it can be modified with the proper programming tool. Maybe not. Possibly the LEDs in the cluster are replaceable... If so, maybe you can increase the resistor value if there is a small resistor on the led/bulb assembly.
  3. Sep 13, 2023 at 7:19 PM
    #43
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol cutting a wire won't fix your obsession.
    stftaco likes this.
  4. Sep 13, 2023 at 7:21 PM
    #44
    Taco Monster 20
    Maybe check the part number of the module and see if the US version is different than the CA one. Just a thought.
    stftaco[QUOTED] likes this.
  5. Sep 13, 2023 at 7:37 PM
    #45
    stftaco
    For example:
    https://www.ebay.com/itm/394778562329?fits=Year:2022|Model:Tacoma
    If those T3 bulb replacements have a resistor SMD (surface mount device), maybe you can hack them by changing the resistance value. Or, you pull your instrument cluster, and perhaps you put some kind of plastic filter or mark them with a permanent marker so they only let a portion of light through. That's it, I'm out of ideas.
    #45
    Okkine 2.0[OP] likes this.
  6. Sep 13, 2023 at 7:48 PM
    #46
    Okkine 2.0
    Okkine 2.0 [OP] Well-Known Member
    2022 TRD Sport, Lunar Rock
    I removed those annoying stickers on the sun visor.
    That's the long term goal. I'd like to swap them to red LEDs, actually. But that's a project for later. I'd just like to eliminate some of the light in the meantime.
    Really, I don't want those buttons illuminated, regardless of how bright they are.
    #46
  7. Sep 13, 2023 at 8:08 PM
    #47
    stftaco
    I see.
    Well, first off, for buttons, you can pull them, and the wiring to them for illumination can be cut, and you'd tape off the ends with electrical tape, or heat shrink tubing. Should be reverseable.
    For the RED illumination:
    https://www.ebay.com/itm/314768391791?fits=Year:2022|Model:Tacoma
    Projects, yes, I've got some things that will be going into the truck. Just haven't had the time.
    #47
  8. Sep 13, 2023 at 8:24 PM
    #48
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    HA! that's what I have done at home. I have a fan in the bedroom that I sleep with every night, but it has three bright A blue LED's, I just used a black marker to tone them down. Without the marker-mod it the light beams off the white ceiling and is annoying.
    #48
  9. Sep 13, 2023 at 8:37 PM
    #49
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    My '17 doesn't go completely dark and all of the switches dim with the dash, to a very comfortable level...all except the damned shifter light. It's annoying AF. Installing the seat-jackers changed my position enough to help a little but the damned thing still reflects off of both side windows.
  10. Sep 13, 2023 at 8:50 PM
    #50
    Okkine 2.0
    Well, I figured that's the case. Without the wiring diagrams, I just don't know which wires to cut. Some of those harnesses have two dozen wires in them.
    Thought if somebody here has already done it, it might save me some poking and prodding with the meter.
    #50
  11. Sep 13, 2023 at 9:12 PM
    #51
    stftaco
    OK, the standard Toyota switch has a connector on the back and the one you need to cut should be really easy:
    See the images in this Amazon product:
    https://www.amazon.com/CH4x4-Small-Switch-Toyota-Tacoma/dp/B07KM9M6MP?th=1
    For rotary controls, like for climate control, or for 2WD/4WD/4L, you might have to put your multi-meter to service, but you could google them, and see what turns up.
  12. Sep 14, 2023 at 4:34 AM
    #52
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    In mine, the illumination circuit is purple. It's also negative polarity (the switch gets it's power from whatever it's switching, then a separate ground wire goes through the rheometer to provide illumination).
    Most switches will technically function if you cut the purple wire, it's just generally not recommended. Some switches are on the positive end of their respective circuits, others are on the negative side. Im sure it makes sense to the engineers. Cutting the illumination wire shouldn't disable any of them, but that's not a guarantee. Some circuits are wired in a creative way.
    ... I've had my hands behind the dashboard once or twice. :cookiemonster:
  13. Sep 14, 2023 at 5:53 AM
    #53
    stftaco
    That's an important observation and caution.
    I suppose for the standard switches with one of the connectors in the diagram I linked to, the OP could create a simple "breakout box" with individual switches for each wire. You could then put the device inline with the wires going to the switch who's illumination one wishes to illuminate to verify which wire to cut, and if it is a workable thing to do so.
    OMMV (one's mileage may vary)
  14. Sep 14, 2023 at 9:55 AM
    #54
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    To be that sensitive to the dash lights on their lowest setting, I can't imagine what oncoming headlights from other cars must do to your eyes!
    The switch illumination should be on one circuit. If there is a place to locate the source of that circuit, you could cut one wire there and kill the lights to everything on that circuit. Much better than cutting dozens of wires at the switches. Maybe put in a switch where you cut the circuit so you could turn them on again as needed.
    stftaco and Chew like this.
  15. Sep 14, 2023 at 10:08 AM
    #55
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    So far, in the six years of reading here every day, you have been the first one to even want this. What do you do about oncoming headlights?
  16. Sep 14, 2023 at 10:17 AM
    #56
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Drive backwards.
    I could be wrong (never tried it), but I think the "panel" fuse is what controls illumination in the 3rd gen. I do not know what other systems would be disabled by that fuse. But at least its easier than going to town with the clippers. It would also be a good starting point if, say, one were inclined to go experimenting with adding a resistor.
    stftaco and hiPSI[QUOTED] like this.
  17. Sep 14, 2023 at 11:36 AM
    #57
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    Anybody checked if the dimming circuit is analog or digital (PWM)?
    If analog a resistor as metioned above sounds usable or maybe put an adjustable voltage regulator inline with a separate pot to control it or add a cheap adjustable PWM circuit off Amazon. If digital, you can remap the PWM duty cycle to have less on time using a low pass filter into an analog input of a simple microprocessor that has a PWM output which drives a low-side mosfet. Under $10 in parts total regardless of how it works.
    I'll try to scope the dash lights voltage sometime to understand how it functions.
  18. Sep 14, 2023 at 1:31 PM
    #58
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    The switches are going to be dimmed by choking down the amperage on the downstream (negative) side. The guts of the switch aren't that sophisticated. I have added a few aftermarket switches that illuminate from the positive feed but still tapped them into the downstream purple circuit. That's probably why the OEM switches in my lower dash won't 100% diminish - there is a tiny amount of escape current going through my aftermarkets.
    Similarly, if anyone has tapped aftermarket devices into the illumination line that provide less resistance than the rheometer, their dash isn't going to dim anymore. The tiny led's in my added switches are still bigger resistors than the original ground path, so everything that isn't aftermarket still dims as it should.
  19. Sep 14, 2023 at 4:49 PM
    #59
    caribe makaira
    Caribbean, Puerto Rico
    OP, there is a fuse labelled "PANEL", remove it. Test. Report back...
    Or not...:rimshot:
    Chew and hiPSI like this.
  20. Sep 14, 2023 at 4:52 PM
    #60
    stftaco
    It's a switch for rotations clockwise and counterclockwise and also for push isn't it?
