Disabling Door-open buzzer w/ key in Acc position.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ADVBedouin, Feb 5, 2011.
  1. Feb 5, 2011 at 9:38 AM
    ADVBedouin
    ADVBedouin [OP] Well-Known Member
    Central CA Coast
    '10 Preunner Acc Cab 2.7L 5spd
    2" CCM front spacers, secondary airfilter gone, OEM 16" alloys, Trailer hitch gone, Seat belt buzzer gone, Ignition key buzzer gone, shortened fact. antenna.
    I'm SO STOKED to have disabled my door-open chime when the key is in the acc position. Thanks to JPMorrisvb for the awesome link. It's so easy & took maybe 15 minutes, most of that was just being careful not to damage anything;
    http://www.toyotanation.com/forum/showpost.php?p=2643003&postcount=27
    The only thing I'd recommend is that you don't even have to move the top half of the steering column cover. You don't even need to fully remove the lower half, just pull it down a few inches & it's easy to pop out the sensor/plug: There's tiny tab at the front of the white plug (facing toward front of truck) that only needs a light squeeze & it pops right out. I just connected a tiny ziptie on the wires next to it to secure it.
    Voila, no more annoying door chime/buzzer with the key in the ACC position. Just remeber to stash a hide-a-key somewhere in case of lockout. This really should be a Cheap Mod/DIY sticky on here.
  2. Apr 30, 2011 at 10:51 PM
    rendog
    rendog i miss my 04
    Hawaii
    2011 4x4 TRD Sport
    works like a charm. thanks man.
  3. Apr 30, 2011 at 11:23 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subd for tomorrow.
