Disabling Door Open Chime
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skrankk, Oct 27, 2016.
  1. Jul 6, 2018 at 1:35 PM
    #61
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
    The 2018's have adaptive cruise control, but there's no need to use it if you don't want to. Just press and hold the CC button when activating it and it operates just like "plain ole". Simple.
  2. Jul 6, 2018 at 1:59 PM
    #62
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    cool, thanks, hadn't completed the complete read on all her stuff..................I'll give it a try
  3. Jul 6, 2018 at 2:18 PM
    #63
    GC4x4
    GC4x4 Well-Known Member
    Greg
    2016 Tacoma DCSB Limited 4x4
    Suspension: Front: King Coilovers SPC UCAs Rear: Deaver U402 Stage I King RR 2.5 Shocks Archive Garage Hammer Hangers Other: OME Carrier Bearing Drop Kit Diff Drop Kit Wheels: OEM SEMA 4Runner TRD Pro Wheels 285/70r17 Falken Wildpeaks Other: TRD Pro Grille Chrome Delete (mirrors, handles, badges, fogs) Bike Storage: Dakine DXL Tailgate Pad and RockyMounts
    I open the door as I'm turning off the car and, while I'm trying to grab all my stuff out so I don't have to make multiple trips into the house, I just hear ding..ding..ding..ding..ding..ding.. drives me and my wife nuts.
    I don't want to disable the switch, I just want the dinging to stop when the car turns off-- as it should have been programmed to do in the first place.
    Can anyone who's had the dealer fix this explain more? I searched the Techstream PDF that was attached above and didn't find anything that would help.
  4. Jul 6, 2018 at 2:51 PM
    #64
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    @GC4x4 Dude just turn off the truck FIRST before you open the door. If not, push the "door open" button. The reason it dings and dings is because it need to know the door is shut before it'll lock the steering column. So when the doors open and it's dinging, shutting the door enables the column to lock rotation to help prevent theft. Easiest solution is to wait to open the door before turning the truck off.
    N2DesignsInc likes this.
  5. Jul 6, 2018 at 3:06 PM
    #65
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    Or just get the hell out fast and lock the truck! Or you could alway press that rubber switch on the door jam once and it’ll shut up for that instance. No wiring or programming needed. My first post on this page, post #61.
  6. Jul 6, 2018 at 3:18 PM
    #66
    Alden
    Alden Well-Known Member
    Alden
    Atascadero, CA
    2018 Cement Tacoma DCSB TRD OR AT 4x4
    I learned something new today. Thank you!
  7. Jul 6, 2018 at 3:19 PM
    #67
    dpippel
    Phoenix, AZ
    You bet!
  8. Jul 6, 2018 at 9:36 PM
    #68
    fgeorge097
    fgeorge097 Well-Known Member
    Northeast
    2018 OR AT
    I notice that sometimes when i open the door after turning off the engine it starts chiming, and other times it doesnt. Why does it only chime sometimes?
  9. Jul 6, 2018 at 10:38 PM
    #69
    Paterico
    Paterico Well-Known Member
    San Antonio, TX
    2017 DCSB TRD OR 4x4
    Just turn the engine off before opening the door.
    Also, if you want to keep listening to that awesome song on the radio, just shift into neutral, kill the engine, then shift into park.
    I get it, they are both small annoyances but there are easy workarounds to both.
    Why anyone would cut wires, zip tie, screw, or otherwise fiddle with things to “solve” such a minor thing is beyond me.
    First world problems..
    Littletacotruck likes this.
  10. Jul 8, 2018 at 9:31 AM
    #70
    Skydvrr
    Nick
    YMH
    Black '17 OR
    See my post a few before yours. It's a security thing.
  11. Jul 8, 2018 at 9:39 AM
    #71
    SpeySquatch
    2016 TRD OR DCSB
    Take the rubber boot off. Tape down pressure button with HD tape. Put boot back on. Done
  12. Jul 8, 2018 at 1:38 PM
    #72
    fgeorge097
    Northeast
    2018 OR AT
    Where is,the door open button?
  13. Jul 8, 2018 at 2:47 PM
    #73
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Where the door latches. Left hip area as u exit the truck.
  14. Jul 8, 2018 at 8:19 PM
    #74
    GC4x4
    Greg
    Totally get it, and I do most of the time, but when I open the door and hit the key at the same time it’s bound to happen— and it’s annoying when it does.
    I’d love to correct this if it’s an easy software solution like the dealer fixes suggest, but I would agree— I’m not interested in making work-around physical modifications to solve a software problem.
  15. Jul 8, 2018 at 8:55 PM
    #75
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I sometimes do it too. When I do, I just bump that switch and all is well.
  16. Sep 10, 2018 at 9:08 PM
    #76
    shanejoe
    shanejoe Member
    Shane
    2018 Toyota Tacoma
    where did you find the buzzer? I have looked all over my 2018 for it
  17. Sep 10, 2018 at 9:17 PM
    #77
    tcjacado
    tcjacado Well-Known Member
    I believe there is a setting in the head unit for distance on that feature.
  18. Sep 11, 2018 at 7:32 AM
    #78
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I have a picture in my build thread. Might be different for 3rd gen though...
  19. Sep 11, 2018 at 7:52 AM
    #79
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For the 3rd Gens, it is on the back of the instrument panel. You will lose other sounds such as turn signal and 4Lo not engaging.
    t0nyvalenzuela likes this.
  20. Sep 11, 2018 at 3:21 PM
    #80
    shanejoe
    shanejoe Member
    Shane
    2018 Toyota Tacoma
    SOLVED THE ISSUE COMPLETELY
    Here is how:
    unscrew the door screw that holds on the black rubber piece, unplug the connector, note there is no way to reconnect this because the wire is so short.
    It was a total accident but its awesome.
    SOUND IS GONE EVERYTHING WORKS
    Option 2:take rubber piece off and stuff tape or something inside to hold the button down, note the plug might come out when your putting it back on so be careful
    skonie likes this.
