Disabling Tire Pressure Gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DarkKnight87, Oct 22, 2016.
  1. Oct 22, 2016 at 6:50 PM
    DarkKnight87
    DarkKnight87 [OP] New Member
    Nathan
    2010 Black Tacoma PreRunner
    Hello,
    I'm new to Tacoma World but not to owning a Tacoma. I have a 2010 prerunner double cab that I upgraded the tires on. My new tires are bigger and I decided to add pressure to 35 psi. My pressure gauge is of course giving me problems. I have tried to reset it with no luck and yes, the spare is at the correct psi. Anyone know a way to disconnect the sensors or turn off the gauge? Thanks!
  2. Oct 22, 2016 at 7:00 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    About the only thing you can do is replace the TPMS with regular stems and put them in a "pipe bomb". Build an ABS tube with a glued cap on one end and a threaded cap or plug (use teflon tape and sealant) in a coupler on the other. Put a valve stem on either end, insert TPMS, and pressurize.
    moondeath likes this.
  3. Oct 22, 2016 at 7:00 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    This is suppose to be the directions for the reset. If all steps aren't perfect it wont work.
    1. Park the vehicle in a safe place and turn the ignition switch to the “LOCK” position.
    2. Adjust the pressure of all installed tires to the specified cold tire inflation pressure level.
    3. Turn the ignition key to the “ON” position.
    4. Push and hold the tire pressure warning reset switch until the tire pressure warning light blinks slowly three times.
    5. Leave the system with the ignition switch in “ON” position for a few minutes, and then turn the ignition key to the “LOCK” position.
    T4RFTMFW likes this.
  4. Oct 22, 2016 at 7:01 PM
    ecotecin
    ecotecin Wait, whut........
    WV
    2014 DCSB sold (2020 Chevy Silverado Crew Cab)
    Is there anyway to turn it off completely.
  5. Oct 22, 2016 at 7:02 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No.
    You can fool it, but it can't be removed.
    Removing the indicator LED from the instrument panel and not running sensors is about the closest thing, without cutting wires.
    moondeath and ramonortiz55 like this.
  6. Oct 22, 2016 at 7:09 PM
    ecotecin
    WV
    Eeww dont wanna do either.
  7. Oct 22, 2016 at 7:16 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pipe bomb
  8. Oct 22, 2016 at 7:19 PM
    T4RFTMFW
    Reported.
    Ruggybuggy likes this.
  9. Oct 22, 2016 at 7:19 PM
    ecotecin
    WV
    Well crap. I hate having that thing rolling around in my truck.
  10. Oct 22, 2016 at 7:20 PM
    OZ-T
    Peter North
    British Columbia
    Is a piece of plastic and you just store it under or behind the back seat
  11. Oct 22, 2016 at 7:22 PM
    T4RFTMFW
    Wait, whut........
  12. Oct 22, 2016 at 7:23 PM
    MKW
    MKW Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    Just zip-tie or band clamp it somewhere under the truck or in the engine bay and forget about it.
  13. Oct 22, 2016 at 7:25 PM
    ecotecin
    WV
  14. Oct 22, 2016 at 7:42 PM
    Clearwater Bill
    Billy
    Largo Florida
    All your original senors in place? Then bigger tires have nothing to do with it.
    Im not sure about more pressure as i dont know exactly what it is looking for. If you set the pressures at the sticker setting, does the light go off? If not, pressure may not be the issue.
    And bigger tires dont mean more pressure is required. Do a chalk test and see what actually works.
