Disappearing coolant
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006 putt putt, Mar 8, 2023.
  1. Mar 8, 2023 at 12:34 PM
    2006 putt putt
    2006 putt putt [OP] Member
    2006 Tscoma 2.7L 5 speed manual
    Nove
    No visible leak. Negative block test/dealership (and myself)/coolant resovoir. PSI/ 15psi held 10 minutes/dealership/pressure test. Changed oil in Dec, normal. Drained 1 cup from oil pan today- normal in color. Coolant still disappearing. Full resovoir 12/17, now at 1/3 full. No coolant loss in the past.
  2. Mar 8, 2023 at 2:34 PM
    3X4X4
    3X4X4 Well-Known Member
    JR
    KS
    2006 Indigo Ink Blue TRD O/R
    Snug Top, Toytec Ultimate Lift, SPC control arms, N-Fab light bar with Hella DL, Yakima rack, factory locker, Cooper AT3 265X75X16, TRD exhaust and front skid
    Was the engine warm? Sounds familiar. I never saw any water in my oil either. But the oil level did rise but only on the morning of head gasket failure. What year Taco is this?
  3. Mar 8, 2023 at 2:41 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    I had a similar issue but mine was because the radiator cap failed and it was escaping from the reservoir.
  4. Mar 8, 2023 at 2:44 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    may need more than 15 PSI..
  5. Mar 8, 2023 at 2:45 PM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    A 10 minute pressure test isn't long enough, IMO. Several hours at least with a good tester, overnight if possible. Depending on temperature swings overnight, anything more than 2 psi down is a red flag to me.
    I had a 2.7L go T/U with a bad HG. Primary symptom was a rough start along with sweet smelling exhaust at startup. It otherwise ran fine with no overheating or boilovers. The leak into cylinder 3 would happen overnight, and that's how I confirmed - with an overnight test on a pressurized system.
  6. Mar 8, 2023 at 2:48 PM
    Bishop84
    Bishop84 Well-Known Member
    Headgaskets are odd on Toyotas, they will only leak under certain scenarios.
    You need to pressure it and watch each cylinder with a boresecope. It won't show combustion on a tester.
    Another method I use is coolant funnels. If there's tiny bubbles its almost always a HG.
    https://www.youtube.com/shorts/_oWXDmrs96c (my video of the bubbles)
    HondaGM, GilbertOz and TnShooter like this.
  7. Mar 8, 2023 at 2:57 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    Get a coolant funnel amd put on radiator. See if it bubbles. My coolant never made it to the oil but was sucking air in from exhaust side. Probably being burnt off. With exhaust.
    HondaGM and 3X4X4 like this.
  8. Mar 8, 2023 at 5:12 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    I have a different engine (4.0L) and had the same "disappearing coolant" issue. I could not see any visible leaks anywhere. I also did a block test and it passed. I did pressurize my radiator and did not notice any obvious drop in pressure. It was only until I inspected the cylinders with a borescope that I found out that I had a head gasket leak. Even if I left the radiator pressurized over night and it did drop a few psi, I don't believe I would still feel confident in assuming the head gasket was bad unless I had visible confirmation of coolant leaking into the engine.
  9. Mar 9, 2023 at 10:58 AM
    2006 putt putt
    Nove
    Thanks!
    One online video showed using boroscope while pressurizing the radiator, and could seek a tiny drip into the cylinder, but dealership, won't usu boroscope unless fails radiator pressure test.
    I drained ~1/3 cup oil from oil pan yesterday, oil looked normal, but thinking of trying the boil test. Place 1/2 teaspoon of oil on a heated pan or foil and if bubbles, there is water/coolant in the oil.
    HondaGM likes this.
  10. Mar 9, 2023 at 11:01 AM
    Bishop84
    It burns it doesn’t mix with the oil.
    HondaGM and TnShooter like this.
  11. Mar 9, 2023 at 11:03 AM
    2006 putt putt
    Nove
    Will look online to see how coolant can burn off on the exhaust side and not contaminate the oil. With these aluminum engines, is it worth the trouble replacing the head gasket?
  12. Mar 9, 2023 at 11:08 AM
    2006 putt putt
    Nove
    Will use the coolant funnel too to see if bubbles like in the video provided.
  13. Mar 9, 2023 at 11:09 AM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Yes it's worth it to replace the head gasket.
    What's your mileage? Did you check the water pump as well?
    SR-71A likes this.
  14. Mar 9, 2023 at 11:15 AM
    zguy1
    Midwest
    I assume it is similar in concept to the open deck design of the 4.0L V6. See below.
  15. Mar 9, 2023 at 11:44 AM
    2006 putt putt
    Nove
    114, 000 miles 2006. 2.7 L 4 cinder regular cab.
  16. Mar 9, 2023 at 11:48 AM
    2006 putt putt
    Nove
    No leaking from water pump. Temperature almost at halfway. I think use to run just a little cooler. No overheating.
  17. Mar 9, 2023 at 11:53 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    What about pink crusty residue around the weep hole on the WP?
    Taco 422 likes this.
  18. Mar 9, 2023 at 2:07 PM
    2006 putt putt
    Nove
    No, but will use a flashlight and look again. No, not seeing any crust at all on the water pump.
    I was getting pink crust at both ends of the hose that connects radiator to the coolant resovoir, and replaced the hose and radiator cap, in November. Now I'm seeing a white crusty streak down the fan cover below the coolant resovoir, but dealership said its nothing. How could it be nothing. I wonder if the coolant resovoir might have a small crack somewhere.
  19. Mar 9, 2023 at 2:13 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I pressurize each cylinder with a leak down tester...put a funnel in the radiator...if leaking coolant will bubble or rise
  20. Mar 9, 2023 at 2:15 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Another thing to check is below the thermostat housing on the driver side of the block. See if your truck has the plastic coolant bypass pipe no. 1. Maybe that's slowly leaking? more info here
    https://www.tacomaworld.com/threads/water-bypass-pipe-no-1.201053/
    If your coolant is being pushed out of your radiator and into the overflow reservoir, its typically either a bad radiator cap, or a bad head gasket. Mine would fill the reservoir more when driving on the hwy. After pulling off and leaving it running, you could see bubbles in the overflow reservoir
