Disappointing gas mileage?
Discussion in '4 Cylinder' started by paid4c4, Oct 31, 2012.
  1. Oct 31, 2012 at 8:33 AM
    paid4c4
    paid4c4 [OP] Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    I'm new to Taco's and 4 bangers. I have a 2010 Extended cab 2WD 2.7L auto transmission with 44K miles. The truck had been setting since April of this year until I bought it the first week of October. There was some gas in the tank which was at least 6 months old so I added some fuel cleaner and filled it with fresh gas. My first tank with mixed city/highway driving was 18.6. I just replaced all filters and Mobil One 00/30W and 235 75 15 Geolanders. Maybe the next tank of clean fresh fuel will be better, any suggestions?
    Bill
  2. Oct 31, 2012 at 8:43 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    18.6 mpg is not great for a 2TR-FE access cab automatic with 44k miles, but it's not horribly bad either. What are your driving habits? Do you let it warm up for a long time? Idle it a lot?
    The old gas is probably not helping. And because it's been sitting so long and you don't know how the previous owner treated it, I suspect the mileage will get a little better over the next few months. Be patient. It's still breaking in, too :)
    Assuming those new tires are larger than the previous ones, they are not going to help your gas mileage.
  3. Oct 31, 2012 at 9:01 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The question is, "What kind of MPG are you expecting". It's amazing if you look at the EPA ratings of many current vehicles produced that fuel mileage isn't that good unless you get into the compact category of vehicles or hybrids.
  4. Oct 31, 2012 at 9:13 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Mine gets better than EPA rating (19 to 21 with winter gas & 23 to 25 with summer gas) regardless of whether I have on the stock 245/75/16 Dungflops or 255/85/16 BFG KM2s (I lose around 1 with the 33" tires). If running a size other than stock you need to figure your MPGs based on actual miles instead of using odometer (I figure MPGs from GPS miles).
  5. Oct 31, 2012 at 10:39 AM
    jassco
    jassco Well-Known Member
    Boston
    2010 Access Cab 2.7L SR5 5spd, 4x4
    5100 set to .85 w/ rear TSB, 2012 Rear-view Mirror, Grillecraft, Team Trails FJ Wheels, TPMS canister, Rear headrest delete, Rear console delete, Valley Hitch, Frame undercoat, $2.99 Tailgate hose clamp lock, Avid light bar, 4x4 lighted switch ala Biceman.
    Stock tire size according to toyota.com is 15-in. styled steel wheels with P215/70R15 tires. You are running a taller tire so this will throw off your calculations. Use the calulator in the mods/tutorials section at the top of page to figure out your mileage adjustment.
    You should be using 0W or 5W-20 weight oil in the 2TR. 30 weight is old spec and ok to run, but may not give the best fuel economy. Run a few more tanks through before you do more calculations and adjust the mileage with the tire calculator first. Nothing you do will get you above 20mpg if you go above 75-80 and punch it a lot to get up to speed.
    Good luck and enjoy the truck.
    Edit: you are 7% off your mileage with those new tires so you are actually going 7% more miles then your odo reads. They are larger/heavier/wider, so that will take a hit and may even out mileage gains.
  6. Oct 31, 2012 at 10:46 AM
    Manwithoutaplan
    ID
    I dont understand you bought a truck to hual stuff not to get excellent mpg.
  7. Oct 31, 2012 at 12:24 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2010 Access Cab SR5 4x4 5 speed 2.7l
    Fog lights with OEM switch - Heated mirrors with OEM style switch - Cab sound deadening - Lighted 4x4 switch - URD short shifter - Rear backup camera - 2012 rear view mirror (compass, outdoor temperature and backup video mirror) - Heated seats - 2014 Tacoma stereo install - Bluetooth with OEM steering wheel controls, Access roll-up tonneau cover
    Brilliant - I love these threads where guys show concern about their mileage and legitimately ask for advice on how to improve it and what they get is an answer like the one you provided.
    Hell my old man used to have a 1970's era Chevy Impala that got 7 miles/gallon to haul his family around. Now the car I use to haul my family around is more comfortable,safer and gets 34 miles/gallon. Things change, technology improves and while other manufacturers are moving in that direction the Tacoma (as much as I love it) frankly has not been keeping up.
    RANT OVER.
  8. Oct 31, 2012 at 12:59 PM
    Manwithoutaplan
    ID
    I wouldn't normally say anything but their are Crap load of thread's about ppl complaining about mpg's and what to do to improve it. Just ask whippersnapper02 :D
  9. Oct 31, 2012 at 1:10 PM
    4Wheelin4Banger
    Randy
    Good luck with that he's banned.
  10. Oct 31, 2012 at 1:18 PM
    Manwithoutaplan
    ID
    but he is with us in spirit.
  11. Oct 31, 2012 at 3:15 PM
    paid4c4
    Northern KY
    Guys, thank you for the responses both positive and stupid. I can fix my mileage but you can't fix stupid. I hadn't considered the difference in travel distance the tires would make. I'll use the calculator and see how it changes. While the tires will change the mileage believe me they are worth it. The stock tires rode bad and held the road bad, heck the hole truck just looked bad. What a difference the larger tires make in the handling and looks of the truck. I'll report back after another tank or two and I'll calculate with my GPS and see what difference it makes. I purposely didn't affix a name with the "stupid" tag, if the shoe fits wear it if it doesn't don't worry about. I've always found forums have some great members who try to provide good information and others who prefer to berate threads and act childish. What goes around comes around.
    Bill
  12. Oct 31, 2012 at 3:44 PM
    Manwithoutaplan
    ID
    wow Really
  13. Oct 31, 2012 at 5:40 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    -Airaid Intake -Weathertech's -Rear camera anytime -xmods mounting plate w/ bluesea fuse block -Magnaflow -Morimoto 5500k HID -Morimoto XB LED Fog Lights
    That's a little harsh isn't it???
  14. Oct 31, 2012 at 6:13 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    OP
    Did your truck have the Firestone or the Dunlops. The Firestone LE will give the best mileage as they only weigh 23 lb. Right now my driving patterns have changed to where most of my trips are 3.3 miles and never top 45 MPH and lot of stop and go, my Ultragauge shows about 19 MPG under those conditions. When my trip were 25 miles of urban interstate at 65 to70 MPH i would get 25-27 depending on the season. Remember on any truck speed kills mileage. Which brand of 235-70-15's did you get? using xw-20 oil will give you about a full MPG increase.
    Edit: you have geolanders.:frusty:
  15. Oct 31, 2012 at 7:31 PM
    paid4c4
    Northern KY
    My truck had the OE Firestones which were slick when I got the truck, they were so bad I couldn't drive it far without changing the tires. I went with 235 75 15's instead of 70's. I'll have an Ultragauge soon and that should show me some numbers and my driving habits. I might regret using 00-30W instead of 00-20W.
    Bill
  16. Nov 1, 2012 at 3:29 PM
    paid4c4
    Northern KY
    Better MPG report for today. 147 miles yielded 22.01 MPG which I'm happy with for the time being. The truck is running better from just getting used and fresh fuel. Once I learn more about it and how it drives and shifts I think the mileage will get better. The 22 MPG was about a 70% highway, 30% city driving. I'm hoping the Ultragauge will help the MPG's.
    Bill
  17. Nov 1, 2012 at 3:41 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Just to clarify, you are multiplying your mileage by 1.07 to correct for 7% difference in tire circumference, correct?
    For the record, I don't think his "you're stupid" post was harsh at all, one of the answers given was a stupid one, so he called it stupid, big whoop.
  18. Nov 1, 2012 at 3:44 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    You buy a V6 (Taco) to haul stuff only, and a full size truck to haul real loads, you ever think mayhaps he bought a 4 banger pickup to haul some stuff whilst getting decent gas mileage as well :eek:
    I love working to improve my gas mileage when I can, what about it? :rolleyes:
  19. Nov 1, 2012 at 3:48 PM
    Manwithoutaplan
    ID
  20. Nov 1, 2012 at 3:53 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot, Just Depends
    Cam
    Clemson,South Carolina
    05 PreRunner and 2004 Lexus IS300 Sport Design
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    That escalated quickly...
    I got the truck for a truck.
