Disassemble 07 fuse box? PLs help
Discussion in 'Technical Chat' started by wfletcher3, Dec 4, 2010.
  1. Dec 4, 2010 at 4:53 PM
    wfletcher3
    wfletcher3 [OP] Member
    Wayne
    Ridley Park
    07 TRD 4L $WD
    I blew the 140 amp Alt fuse. How do you take the box apart pls!.. 07, 4WD, $L V6 TRD Sport, Double cab.
    Many thanx up front
  2. Dec 4, 2010 at 4:54 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    :popcorn:i didnt even know they had a 140amp fuse
    good luck a pro will chime in soon im sure
  3. Feb 26, 2011 at 1:52 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    just did this to my truck made a crappy paint image to show how to take the fuse box apart to change the 140 amp Alt fuse
  4. Feb 27, 2011 at 3:51 AM
    wfletcher3
    Wayne
    Ridley Park
    07 TRD 4L $WD
    Thanx, I need to do some rewiring. I just put in a second battery and isolator. Ended up taking it to a garage to get it fixed. Going to try again when it gets warmer.
    How did you get the clips to release? I tried a screw driver, but couldn't get anything to release.
  5. Feb 27, 2011 at 10:46 AM
    Burgman
    Stephen
    Ric VA
    I pulled on the two wire looms closest to the fender up while unclipping the clips with a flathead... getting the two pieces seperated to get to the inside bolt for the Alt fuse was a pain and only got it half of where I highlighted it but it was enough to get a socket in there
    pinktaco808 likes this.
  6. Feb 2, 2017 at 7:40 AM
    pinktaco808
    pinktaco808 Hot Steppa
    How many clips? 3?
