Disassembling ICONS?
Discussion in 'Suspension' started by RacerP, Dec 4, 2009.
  1. Dec 4, 2009 at 9:21 AM
    RacerP
    RacerP [OP] Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Alright so here is my problem...the set screw to lock the collar in place is stripped and frozen. I drilled it out a bit and tried a bolt extractor which didn't work.
    My thought is to drill it out completely and retap it. I don't really want to attempt this with the collar on the shock. Is there a way to get the collar off without doing a full rebuild? Maybe compress the springs and slip the bottom perch off so you can get the coils off? They don't need a rebuild, I just can't adjust them.
    Seems like a waste to ship them to ICON for such a simple problem??
    Any suggestions?
  2. Dec 4, 2009 at 10:24 AM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Sorry I cant help you with your problem. I would've tried the same things. Either using a bolt removal kit or like you said having to drill it out and re-tapping. But on another note.. How do you like the ride of your icons?
