Disaster After Dealer Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by unclemike, Feb 2, 2014.
  1. Feb 6, 2014 at 1:16 PM
    #261
    BamaToy1997
    Bill
    Navarre, FL
    The difference here is that this is NOT an offer by Toyota. This is an offer by a franchised dealer only. So yes, if this dealership were to go belly up, then Toyota itself is not involved. (assuming that the information is correct in that this is an extended offer from the dealership, and not Toyota)
    Remember, this is NOT the fault of Toyota at all, and they are not responsible for the engine being damaged due to negligence of a dealership.
  2. Feb 6, 2014 at 1:32 PM
    #262
    imatacomaowner
    imatacomaowner Well-Known Member
    cali
    tacoma 6 cyl 4wd
    Wow, this is why my mechanic told me not to get serviced at the dealership. They aren't mechanics changing oil over there, its lackeys. Having just bought a brand new truck and going through the experience what a friend said rings truest: they can't possibly have your best interests in mind. In terms of sales anyway. Not sure how that relates to the service depts there but I think having a mech you have a personal relationship with is best.
  3. Feb 6, 2014 at 2:57 PM
    #263
    junkman
    junkman Well-Known Member
    Erik
    Louisville
    '13 SR5 4x4 5 speed Access Cab
    I believe they use a third party warranty firm so it wouldn't matter if the dealer goes belly up.
    Obviously, the warranty firm believes that 1) what they are covering (drivetrain only) is pretty bullet proof these days if properly maintained, 2) most people don't keep their vehicles long enough to make claims 3) Those that try to make claims may not be able to prove up the maintenance, 4) they have a limited tail of liability as even if you keep the vehicle 15 years, the book value will eventually decline so that they won't be liable.
  4. Nov 10, 2014 at 8:10 AM
    #264
    Treeman1942
    Treeman1942 Well-Known Member
    George
    Evart, Michigan
    Limited 4x4, DoubleCab Short Box
    Factory running boards WeatherTech floor mats
    Since ordering my new Tacoma, I've been lurking here. In my opinion, you truck wasn't damaged,
    A few years ago, I changed the oil in my beloved 1997 T100. Afterwards, I took about a five mile drive before hearing a rattling sound from the engine. I stopped, looked under the truck and saw oil splattered all over the place. Zero oil on the dipstick, etc.
    Anyway, upon crawling under the truck, noticed that the oil had escaped around the oil filter area. Towed the truck home. After inspection I found that when replacing the oil filter, the old gasket has remained on the block, and the double gasket had caused the leak.
    I was etremely worried, but didn't seem to have any issues after that, no oil usages, still same oil pressure, etc. I recently sold the T100 with 100,000. I had to have driven at least a couple of miles with zero oil.
    Learned some lessons. Check to see if the old oil filter gasket stayed on the block, and monitor oil pressure gauge after changing oil. Plus, double and triple check everything. My new Tacoma, when it arrives, will get more attention!!!
    Glad to hear that you have a solution to your problem.
  5. Nov 10, 2014 at 8:43 AM
    #265
    Kevinztaco
    Kevinztaco Well-Known Member
    none yet
    I may sound like I'm looking for evidences to support my "distrusts" is the stealerships but this sort of incidents is exactly why I refuse to have the dealer change my Taco's oil. Can't trust them people. I'd demand for a new engine or a new truck.
  6. Mar 31, 2015 at 7:41 AM
    #266
    LIRR
    LIRR Member
    Brian
    Pa
    02 SR5 Taco w/alts
    BONEHEADS!!!
  7. Mar 31, 2015 at 7:48 AM
    #267
    TacoNumber6
    TacoNumber6 6 TIMES A CHARM
    what a bunch of idiots !
  8. Mar 31, 2015 at 7:55 AM
    #268
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I thought most people cleaned off the oil filter mounting base before installing a new filter. This is when the stubborn old gasket would be discovered and removed.
    Glad to hear your T100 still ran fine after the incident.
  9. Mar 31, 2015 at 8:44 AM
    #269
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Now think about this one, those same people will be working on replacing frame (disassembling truck and reassembling. )
    :cool:
    Can't wait for that...
  10. Mar 31, 2015 at 9:29 AM
    #270
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    A valid point, however, I doubt this will turn out badly. Toyota is taking great pains to remedy a huge error with the frames. They wouldn't take this much time and spend this much money just to screw it up in the end. Much is on the line and I have faith Toyota will do right by us the customers.
  11. Mar 31, 2015 at 3:59 PM
    #271
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Do our 4.0l have this system protocol ? I just went out and unplugged my oil pressure sending unit by the oil filter mount. The truck started and the oil pressure light did not come on ?????? WTF ?
  12. Mar 31, 2015 at 6:02 PM
    #272
    BlueT
    NorthEast
    lets hope, My dealership could not change transmission fluid correctly so I have little faith in their frame replacement ability.
    I am pretty sure they gonna f something up badly. lucky with new frame I will just fix their f up and move on. Just need new frame and this time I want that crap painted by body shop with real paint. :rant:
    I am pretty sure our oil pressure switch is desigend to close\open circuit. When is 0 psi than its closed, it opens at 4 psi if I am not mistaken. So disconnecting cable makes it think it has correct psi.
  13. Mar 31, 2015 at 8:18 PM
    #273
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The prints show it as a Normally Closed Switch so when it is actively under pressure it would be open.
    In order to test the shutdown of the engine on loss of pressure you will need to unplug the wire from the switch and connect the wire to a ground point.
    This should illuminate the Oil Pressure LED in the Combination Meter and shut down the engine if that feature exists. I don't know about the shut down feature??? Try it and let us all know!
  14. Apr 2, 2015 at 3:58 PM
    #274
    tinker2
    I just went through the unplug a little while ago. Started the truck with the oil pressure sending unit plugged in. While running, I unplugged the sending unit and used a pointed test light plugged into the wire with the alligator clip grounded.
    The oil pressure light did light on the dash, it DID NOT kill the engine. So it appears my 08 does not have the no oil pressure shut down feature.
  15. Apr 2, 2015 at 10:12 PM
    #275
    Jimmyh
    SC
    2012 Prerunner SR5
    I didn't think that it did as per the prints it appears to only go to the idiot light in the dash.
  16. Jun 2, 2015 at 5:05 AM
    #276
    dunwur
    dunwur Active Member
    toronto Canada
    2011 tacoma sr5 4x4
    Unreal. I once had my oil changed at the dealer and when I tried to check my oil a couple of weeks later , There was no dipstick . I went back to the dealer ( Pissed ) and they tried to tell me that I probably checked my oil level and didn't put the dipstick back in the tube . they wanted to charge me for a new one . I was so mad I had trouble talking , Then the wife got involved ( a red head ) and it didn't take them long to give me a new dipstick just to get her out of there .
    TRDSport10 and tcBob like this.
  17. Jun 2, 2015 at 6:00 AM
    #277
    tbird71
    tbird71 Member
    Tom
    2015 Tacoma Double Cab Prerunner
    Too many rookies in service bay. I want to physically WATCH them do service at the very LEAST
    If I cannot supervise them they can piss off. If it's free i typically ask for the oil and filter to take home
    You want a job done right DO IT YOURSELF
    My new taco is too precious to gamble with rookies screwing with it
  18. Jun 2, 2015 at 6:11 AM
    #278
    JackAttack
    JackAttack Well-Known Member
    Grantville, PA
    Stock Blue TRD Sport
    Had mine in for the 20,000 service in January. Left right after the oil change on a 150 mile trip and noticed a clicking sound coming from under the hood whenever the heater fan would kick on. Popped the hood to see why and found an empty oil quart bottle under the oil filter drain hole. By this time the belt had worn two holes in the bottle and there was no oil left in the bottle.
    Obviously have done the oil changes myself for the 25,000 and 30,000 intervals. Took it in for inspection in April and told the service advisor what happened and demanded the serpentine be changed. They agreed to change it but wrote it in the log as 'customer complained of squeeling belt'.
    On a side note I put 32,000 miles on it since it was purchased new on April 28, 2014.
  19. Jun 2, 2015 at 6:26 AM
    #279
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    I just pulled 3 styro cups out from under the hood of my buddy's Baja. The dinks left em under the oil filter drain and they were rubbing against the belts causing a slight chirping noise. Dealers are whack. DIY....
  20. Jun 2, 2015 at 8:38 PM
    #280
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    You're a better man than me. I would have had someone over the hood of a new vehicle in the showroom whipping their ass with my belt..
