Disaster Changing Oil Today! (pics)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freeskier989, Feb 9, 2014.
  1. Feb 11, 2014 at 2:16 AM
    #41
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Yes. Oil filter wrenches are made to remove oil filters. NEVER to install them. Just a thought..If I had that threaded oil filter pipe in my hand, I'd look for a nut with threads that fit and use the nut to tighten the fitting into the block. I'm not sure how easy it would be to find such a nut, but I'd look.
  2. Feb 11, 2014 at 6:38 AM
    #42
    freeskier989
    freeskier989 [OP] Well-Known Member
    Mark
    Newport Beach, CA
    2012 Access Cab Off Road 4x4 V6
    ABS Switch Icon Stage 3
    Yes that was what is mentioned by someone else using two nuts butted up to provide you a way to torque it down into the block.
    Im also thinking, there is a gap in the middle where its smooth - no threads between the two sides. Wonder if it will only take one nut down to that and it will be forced to stop and then i can use it to get it in tight. Hope my part comes in today!
  3. Feb 11, 2014 at 6:52 AM
    #43
    TheGreatPear
    TheGreatPear Well-Known Member
    Alex
    Gunsan, South Korea
    2013 DCSB TRD OR 4x4 V6 6 Speed
    Id reccomend using a strap wrench or, even better, a pipe extractor (also called a internal pipe wrench, nipple extractor).
    Check the male and female threads on the nipple to make sure they're good.
    The nipple should thread in with little resistance for the first 1/4 or so if it's threads are intact.
    Its most likely the filter itself that is cross threaded.
    Like others said, throw some loctite on there once you get it back in.
  4. Feb 11, 2014 at 7:07 AM
    #44
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    I never had to use tools to remove any oil filter (fingers crossed) usually use some sandpaper around the filter to get a better grip. I hope toyota didn't put it on too tight when I do my first OC on the taco...
  5. Feb 11, 2014 at 9:23 AM
    #45
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Double nut method, just like a stud. Rich had it the first page.
  6. Feb 11, 2014 at 10:53 AM
    #46
    Roundarc
    Roundarc Born again Tacoma Owner
    Allan
    Virginia
    2025 TRD Sport Premium
    I was only pointing out an alternative method.
    In case the OP didn't have any nuts laying about. :D
  7. Feb 11, 2014 at 12:27 PM
    #47
    Ehc0720
    Ehc0720 Active Member
    Happened to my GF a few weeks ago changing the oil in her Harley. She came and got me and I got it off the filter and put it on the new one and just screwed it back in by hand.
  8. Feb 11, 2014 at 8:26 PM
    #48
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The nut will jam against the bottom of the threads with as much torque as you apply to install the nipple.
    IE: It will either remove the nipple from the soft aluminum housing when you try to back the nut off, or it will at least back off some of the torque... leaving you where you are now a couple of oil changes down the road.
  9. Feb 11, 2014 at 8:36 PM
    #49
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Just a quick question regarding op's situation. But is it possible he could get that nipple at lowes or hd? I know they have an abundance of male male nipples. In the event toyota doesn't have it in stock?
  10. Feb 11, 2014 at 8:47 PM
    #50
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
  11. Feb 11, 2014 at 8:48 PM
    #51
    joes06tacoma
    Joe
    Central Coast, CA
    That sounds kind of scary, it's likely metric, and the part it screws into is $$$. But I suppose it might be possible.
    I've seen what happens when someone tries to install an SAE fitting into a Metric one, not pretty, and not something you want to happen to your engine, of all things.
  12. Feb 11, 2014 at 8:49 PM
    #52
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Didn't mean to post it is. Meant is it. I meant it as a question. Wasn't sure if you could get metric at lowes. What about fastenal?
  13. Feb 11, 2014 at 8:52 PM
    #53
    joes06tacoma
    Joe
    Central Coast, CA
    Sorry, didn't take it that way. I have no idea if Lowes, etc have metric. I also don't know if it would be pipe thread or regular bolt/screw thread. Just seemed to be a big risk to take using anything other than OEM.
  14. Feb 11, 2014 at 9:02 PM
    #54
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You mean like this part? :D
    http://www.lowes.com/pd_22030-29760-20500_0__?productId=3418898&Ntt=nipple&pl=1&currentURL=%3FNtt%3Dnipple&facetInfo
    Drawbacks vs OEM
    - No allen key wrench flats
    - Thread quality looks very poor, may break more easily than OEM.
    EDIT: Lowes part is pipe thread, likely wouldn't fit.
  15. Feb 11, 2014 at 9:21 PM
    #55
    Rich91710
    Rich
    Los Angeles
    08 Base
    Even if they have metric that big, it's a 3/4-16 thread on the filter side.
    Hardware store definitely will not have that.
    Dealer item, or turn your own on a lathe.
    And FWIW, Lowes and Depot do not have anything in 3/4 machine thread.
  16. Feb 11, 2014 at 9:23 PM
    #56
    Rich91710
    Rich
    Los Angeles
    08 Base
  17. Feb 11, 2014 at 11:58 PM
    #57
    freeskier989
    Mark
    Newport Beach, CA
    Go figure, they did not have the part anywhere around so now the quote is they will not get it in until Thursday at the earliest... Back to the mini van for now... :(
  18. Feb 12, 2014 at 9:25 AM
    #58
    KenLyns
    Belly of the Beast
    ^Not as bad as a suspension bracket I bent on my previous car (Mazda Millenia) - had to be dropshipped from Hiroshima.
    I see. Aside from the different thread form, 3/4 NPT is 14 TPI rather than 16, so it wouldn't work.
  19. Feb 12, 2014 at 10:22 AM
    #59
    freeskier989
    Mark
    Newport Beach, CA
    The 3/4-16 nuts i should be able to get at Home Depot correct?
  20. Feb 12, 2014 at 11:33 AM
    #60
    RCKT82
    RCKT82 Well-Known Member
    Mid-West U.S.
    2013 PreRunner AC SR5 V6
    ^this... or JB Weld and you'll be good to go
