Disc mode wont work any help??
Discussion in 'Audio & Video' started by adamv22, Jul 2, 2011.
  1. Jul 2, 2011 at 8:06 PM
    adamv22
    adamv22 [OP] Well-Known Member
    adam
    29 Palms, California
    06 tacoma Sport
    6" Rough Country lift, Toyota roof rack, Tepui RTT, Hidden 12000lb winch Pioneer 6.1 DVD stereo, Cobra III CB radio,
    I have a stock 6 disc changer in my 06 tacoma, and today i was wiring my RCA adapter into the speaker harness, not a huge process at all , but now after putting everything back together, the cd mode of the head unit isnt working. when i hit the eject it says no disc, when i know for a fact there are 6 cds in it. any help would be great!!
  2. Jul 3, 2011 at 5:02 AM
    lbridges
    lbridges Well-Known Member
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Can't tell for sure over the 'Net, but I think you're gonna have to pull the unit out, take off the top and mess with the CDs. It seems powering down and playing with the headunit while CDs are still in the changer can cause problems.
    This advice is not based on first hand experience, but on reading something here or on TN, can't remember where, might try searching for jammed CDs or something similar.
  3. Jul 3, 2011 at 9:16 AM
    adamv22
    adam
    06 tacoma Sport
    awesome, thanks i appreciate it
  4. Jul 3, 2011 at 9:34 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I've taken out my head unit with cds in it and it worked when I plugged it back in.
  5. Jul 3, 2011 at 9:37 AM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    It's been a while since I've seen/used my stock head unit, but does it have one of those tiny reset buttons anywhere?
  6. Jul 3, 2011 at 4:10 PM
    lbridges
    Lee
    Indialantic, FL
    '11 PreRunner SR5
    Nope. Have to disconnect the battery, or pull the plugs on the rear. I haven't a clue as to how long - 30 seconds?
    To the OP, before taking the unit apart, this is a good idea to check and see if a reset would help any, I should have suggested that first.
  7. Jul 5, 2011 at 5:24 PM
    adamv22
    adam
    06 tacoma Sport
    Well i ended up taking the entire unit out, taking it apart and i found that two of the cylinders that hold the discs inside werent lined up, so i took a small screwdriver, and pryed them back into place, works goos as new now, thanks for everyones input i appreciate it!
