disconnect AC compressor without pulling relay?
Discussion in 'Technical Chat' started by tempest766, Aug 22, 2017.
  1. Aug 22, 2017 at 7:38 AM
    tempest766
    tempest766 [OP] New Member
    2009 V6 Tacoma with 4wd, 150k miles
    My AC compressor clutch went out and I have neither the time nor money right now to screw with it...and given that the truck is nearing its EOL I don't really want to do anything with it. However, I will need my heater and it seems that the heater function engages the compressor clutch when the defogger it used. I believe I located the compressor at the bottom driver's side of the serpentine belt and there is a small 2-wire electrical plug coming from the clutch area of the compressor. I cannot seem to get this plug disconnected by hand.
    Am I correct in assuming that if I do pull that plug then the clutch will never engage? Is the clutch engaged whe nthe curcuit is open, or closed? Would cutting the ground wire disable it...since presumably I would need to remove the compressor anyways if I was to fix the system?
    Pulling the compressor clutch plug was how I dealt with this same problem on my high mileage S10 many many years ago.
    Am I correct in assuming that pulling the relay is not a solution because both the heater and AC are run through the same relay?
    I need my heater/defogger but not my AC...How can I keep the heater functioning but disable the AC compressor clutch?
    Thoughts?
  2. Aug 22, 2017 at 7:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, pull the clutch plug.
    Is there something else wrong with the truck that makes 150K near the EOL?
  3. Aug 22, 2017 at 7:59 AM
    tempest766
    @98tacoma27 -- Thanks! My standard vehicle lifetime rule of 10 years or 200k miles...That's how long I expect to keep a vehicle when I buy one new.
    Toyko Joe likes this.
  4. Aug 22, 2017 at 8:02 AM
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
    I'm the opposite...I run them till they can't be reasonably fixed.
    BassAckwards and Toyko Joe like this.
  5. Aug 23, 2017 at 1:22 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It is good people sell there Tacoma`s after just getting them broke in and the bugs worked out
    98tacoma27 likes this.
