Disconnect day time running lights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ham Bone, May 20, 2014.
  1. May 20, 2014 at 2:57 PM
    Ham Bone
    Ham Bone [OP] Welder at Kaufman Trailers of N.C
    Lexington, N.C
    09 / Double Cab SR5 / 4x4 / 6 Speed Manual
    4" lift / T Rex billet grill / Spyder halo projection headlights / Bully bull bar / OEM running boards
    Is there any way to disconnect my daytime running lights without losing the turn signals? I installed halo headlights on my truck and they don't have an inner lens over the running light so when it is on the amber color is so bright that it drown out the halos and leds. I want them to stay amber but I don't want them running constantly. Any ideas?
  2. May 20, 2014 at 3:14 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Put a resistor on it before the bulb?
  3. May 20, 2014 at 4:21 PM
    Ham Bone
    Lexington, N.C
    Not sure? It only has two wires, a positive and negative. somehow they run both the turn signal and the running lights. I do know that when I first start the truck in the morning the running lights don't come on until I release the parking brake. I wonder if I could bypass that switch or do you think that the running lights will still come on, like say when I reach a certain speed or put it in reverse????
  4. May 20, 2014 at 4:58 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Do a search and you will find out how to disable them. I disabled mine a long time ago to prevent melting the headlight lenses.
  5. May 20, 2014 at 5:32 PM
    Ham Bone
    Lexington, N.C
    thank you. I will try that
  6. May 21, 2014 at 5:48 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    X2 ^ .
  7. May 21, 2014 at 7:06 AM
    pepper07
    pepper07 Well-Known Member
    Roger
    Tn.
    10' access cab
    I disabled mine a few months ago. On the back side of the fuse bock is 2 connectors. One has a green/red striped wire. Cut or remove this wire and you will lose your running lights without losing your signals or anything else.
  8. May 24, 2014 at 7:58 AM
    tacoma guy
    Joe
    Phoenix Az.
    This is the one I did and it worked great !!!
  9. May 25, 2014 at 8:34 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I snipped mine too. My green wire had a different color stripe. Maybe yellow (09)
