Disconnect Seat Belt Warnings in '09 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by santacruzer, Dec 5, 2008.
  1. Dec 5, 2008 at 3:31 PM
    santacruzer
    santacruzer [OP] Active Member
    Santa Cruz, CA
    09 Tacoma Double Cab TRD
    Anyone found an easy way to disconnect the seat belt lights and buzzers in the new 2009 Tacomas? I use the vehicle a lot on a ranch, and it's driving me nuts when my passenger gets in and out to open and close gates. It's not always easy to just connect the belts behind, either. On my '01 I simply pulled the plug under the seat, but this vehicle has occupant sensors (passenger) and seat air bags, and I don't want to risk triggering something unpleasant. Dealer service departments aren't wiling to do it.
    I have the schematic, but am not an EE!!
  2. Dec 5, 2008 at 3:36 PM
    crawfishsoul
    crawfishsoul Look at my member
    Removed front mud flaps.
    Bump. I've been looking for the same info.
    How can I get my hands on that schematic?
  3. Dec 5, 2008 at 3:40 PM
    santacruzer
    Santa Cruz, CA
    Here' s the schematic as a jpg, it's just how I received it.
  4. Dec 5, 2008 at 3:46 PM
    crawfishsoul
    Thanks. I'll see if one of my smart friends knows what the hell it says. :)
  5. Dec 5, 2008 at 3:50 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Some one posted it a few weeks ago. The light still flashes but the ringing stops.
    It worked on my 08.
    If I remember right and this sounds crazy:
    Push on break, turn key so gauge lights go on, press the od & trip button, cycle around trip 1 & 2 back to od and hold it and count to 12 slow. Then it will read d-off still holding it down, buckle the belt (I pulled the belt across,it's hard to hold the button & buckle the belt) Then turn off the ing.
    I think that was it.
  6. Dec 5, 2008 at 3:54 PM
    Mr.Ed
    Wilbur's Barn
    Just found it I was wrong.
    How much are you willing to pay for me to tell you the code that turns the seat belt chime off?
    No, I'm not kidding. I have the code and tested it on my '08 Taco.
    No takers??? Fine then! Hope you enjoy listening to that endless, annoying seat belt chime.
    OK, I give. Here it is. BTW you guys are no fun :
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
  7. Dec 5, 2008 at 4:08 PM
    Okkine
    Okkine Well-Known Member
    Vancouver, BC
    2009 Magnetic Grey Access Cab - 2.7L I4 - 4x2
  8. Dec 5, 2008 at 4:09 PM
    santacruzer
    Santa Cruz, CA
    Does this do anything of a permanent nature to the odometer reading?
  9. Dec 5, 2008 at 4:10 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    to the OP, this one will work for sure.....if you remove battery power, then u'll have to redo it
  10. Dec 5, 2008 at 4:11 PM
    jhodge83
    SC
    17 XLT Sport
    a seatbelt chime has nothing to do w/ the odometer, besides using the trip reset button to make the chime go away
  11. Dec 5, 2008 at 4:13 PM
    Okkine
    Vancouver, BC
    It doesn't do anything to the odometer, or to the trip meters. If you change your mind, you can undo it by switching it back to b-on. It was the first thing I did when I picked up my truck.
