Disconnected Battery, 5k Maintenance Reset?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Boyk1182, Nov 10, 2017.
  1. Nov 10, 2017 at 6:40 AM
    Boyk1182
    Boyk1182 [OP] Well-Known Member
    Northern Colorado
    Exactly as the title suggests. I noticed quite a few things reset, anyone know for sure if my 5k reminder has now started over, or is it right where it left off? Thanks!
  2. Nov 10, 2017 at 6:43 AM
    Pro Taco 11
    Pro Taco 11 Sitt Head
    Rob
    Joliet, Illinois
    Tacoma TX Pro 2011 4x4
    3" OME, RAAL, TRD Exhaust, Pioneer DBL DIN, Weather Tech's, Bull Bar, AFE CAI, Anytime Fog, Map/Dome light mod, Ultra Gauge, Tail Gate theft mod, Second Set of D-Rings in bed, Dura Tracs 285's, Satoshi deep dish, Leer 100 XQ, Wet Okole seat covers
    Is the light still on on the dash??? If not then it reset. I keep track of mine on trip b, trip a is for my gas mileage plus my scan gauge is set up for 5000 mile service too.
  3. Nov 10, 2017 at 6:44 AM
    Boyk1182
    Northern Colorado
    Trip B was my 5k reminder. It is reset now.
  4. Nov 10, 2017 at 7:22 AM
    Pigpen
    Dan
    Northwest Montana
    The oil change dummy light should not have reset. Just like your odometer, it's one of the things the truck remembers.
  5. Nov 10, 2017 at 8:12 AM
    Boyk1182
    Northern Colorado
    I figured this, just wanted to check, thank you.
    Pigpen[QUOTED] likes this.
