Disconnected battery now alarm wont stop and truck won't start
Discussion in 'Technical Chat' started by TWN76, Jan 22, 2021.
  1. Jan 22, 2021 at 12:37 PM
    TWN76
    TWN76 [OP] Member
    Tom
    2009 Blk Tacoma DBL cab 4X4
    I have a 2009 DBL Cad 4x4. I disconnected the battery Wednesday to clean the posts and terminals. When I reconnected the battery the alarm started going off and hasn't stopped. I lost the FOB years ago. I removed the door lock cleaned it and turned the key three times with the door closed and another time open, I turned the key in the ignition from ACC to ON quickly back and forth five times, I put the key in the ignition turned to ACC and held the reset button beside the hood release (not the tire presser sensor reset. well, in frustration I tried that too later) NOTHING has worked! The truck started once but went right back to blaring horn and flashing lights when I turned it off on Thursday. Any help would be greatly appreciated. I can't get to work without my truck.
  2. Jan 22, 2021 at 12:39 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    I assume this is an after-market alarm system?
    Key-Rei likes this.
  3. Jan 22, 2021 at 12:42 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Try turning the ignition on and press and hold the valet button for 10-15 seconds
  4. Jan 22, 2021 at 12:52 PM
    TWN76
    TWN76 [OP] Member
    Tom
    I think so. I thought it was factory until I found the reset button last night.
  5. Jan 22, 2021 at 1:08 PM
    TWN76
    TWN76 [OP] Member
    Tom
    This might be a stupid question, but where is the Valet button? I looked on the column and don't see anything.
  6. Jan 22, 2021 at 1:10 PM
    tirediron
    I'd just get rid of the whole thing!
    Mastertoytec and Wyoming09 like this.
  7. Jan 22, 2021 at 1:14 PM
    TWN76
    TWN76 [OP] Member
    Tom
    I've been seriously considering that, but it's not an option
    doublethebass likes this.
  8. Jan 22, 2021 at 2:04 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Didn’t you say there was a “reset button” mounted beside the hood release. Assuming that’s your valet button you’re talking about. This is an aftermarket unit correct?
  9. Jan 22, 2021 at 2:27 PM
    TWN76
    TWN76 [OP] Member
    Tom
    Yes I did. I just tried it in the ON position, that didn't work either.
  10. Jan 22, 2021 at 2:30 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    We can't help you very well unless you dig around under the steering wheel and identify what brand and model the alarm is. Then we can start giving you better answers, @TWN76
    Wyoming09 likes this.
  11. Jan 23, 2021 at 2:52 PM
    TWN76
    TWN76 [OP] Member
    Tom
    It is an Avital 2300.
  12. Jan 23, 2021 at 4:50 PM
    JasonLee
    15 TRD OffRoad
  13. Jan 23, 2021 at 4:56 PM
    TWN76
    TWN76 [OP] Member
    Tom
    Thanks! I was able to get the alarm to stop. Apparently, I wasn't pressing the reset button fast enough. Now she tries to start but doesn't turn over and I don't have dome lights. This is turning into a real joyride.
    JasonLee[QUOTED] likes this.
  14. Jan 23, 2021 at 5:02 PM
    JasonLee
    15 TRD OffRoad
    Knowing that the alarm has been going off a bunch, I'd try charging your battery to make sure it wasn't drained too low for the starter to work. The dome lights part is hopefully unrelated.
  15. Jan 23, 2021 at 5:11 PM
    TWN76
    TWN76 [OP] Member
    Tom
    I put a new battery in this evening. It's tight and secure.
