Disconnecting battery required for seat removal? Leather install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by B737, Sep 4, 2012.
  1. Sep 4, 2012 at 9:05 AM
    B737
    B737 [OP] Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    I'm going to have the seats out of my truck for 6-8 hours while doing a leather reupholster, in a perfect world, I'd like to just disconnect the seat wires and pull the seats.
    Is it necessary to disconnect the battery to not trigger air bag light?
    Also open to tips from those of you who have done leather and worked with the seat sensors and airbags... I've done this on other cars but not w toyota's
  2. Sep 4, 2012 at 12:22 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    if i was gonna disconnect any airbag wiring i would first remove the battery terminals...call me crazy if you like but i wouldnt want one going off in my face....it would be quite a suprise !!
  3. Sep 4, 2012 at 12:51 PM
    B737
    Kevin
    Jersey Shore
    stock
    I've dealt w air bags before, on my BMW, Ford and Porsche... they aren't a big deal or anything to get nervous about, but all require different precautions. None have blown up yet. I know that some cars require disconnecting the battery so it doesn't trip the system, others don't. This is my first toyota.
    I'm sure someone here has pulled their airbag seats from their cab before. if I don't hear first hand experience then I'll just disconnect the battery but I'm not yet convinced its required other than pulling the harnesses and waiting a few minutes.
  4. Sep 4, 2012 at 12:54 PM
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    Not sure if it is required but I disconnected prior to removing my seats so I don't have any firsthand experience NOT disconnecting the battery. I didn't do much research but it was called out in a seat install thread I reviewed.
  5. Sep 4, 2012 at 1:04 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
  6. Sep 4, 2012 at 1:07 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Airbags have CADs. CAD's are sensitive to electrostatic.
    To the op I wouldn't be worried about power so much as I would shunt the plug when you remove.
  7. Sep 4, 2012 at 1:11 PM
    B737
    Kevin
    Jersey Shore
    stock
    Homers truck had no seat airbags... I don't think the 2005 does either...
    Thanks Will, thats prob the course I'm going to take, even though I'd rather not. I'll have a bunch of stuff ill have to set back up once I reconnect the battery.
    I just don't see why the airbag controller would log a fault and trip the light if I unplug them and plug them back in while the truck is off w the doors open... Seems like it might be an unnecessary step.
    Yes, I have caps for the plugs too.
  8. Sep 4, 2012 at 1:12 PM
    Big Tea
    Big Tea WOOOOOOO!!!
    Chesterfield, VA
    08 TRD Sport DCSB 4x4
    Correct me if i'm wrong, but as long as you disconnect the wiring harness from the seat (assuming you are talking about the airbags in the seat of course) then there would be no signal to cause the seat airbag to go off. My seats do not have the airbag so I cannot definitively say whether you will have an issue with those.
    If you are talking about the airbag in the dash/steering wheel, I did not disconnect my battery terminal and completely removed both front seats with no issue.
    I also used
    http://www.tacomaworld.com/forum/tec...-interior.html when installing my leather and had no issues with the steering/dash airbags while only disconnecting the wiring harnesses under the seats.
    All that being said, I did not drive my vehicle while any of my seats were removed, not did I attempt to reupholster while the seat was still in the vehicle. Good luck with it, I love the leather.
  9. Sep 4, 2012 at 1:12 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    I unplugged mine before I removed my seats. Not worth taking a chance.
  10. Sep 4, 2012 at 1:15 PM
    BamaToy1997
    Bill
    Navarre, FL
    Since the SEAT is what is being removed, you should not ever have to worry about an accidental deployment. Those on the Tacoma are positioning sensors. The wires from the seat are to let the computer know if someone is sitting their, and other information such as if the seat belt is latched or not. This is NOT going to cause a deployment.
    This being said, if you disconnect a POSITIONING sensor you sill set a warning code, and the system will disable itself based on system parameters. Some manufacturers such as Cadillac have an actual airbag built into the side of the seat, but the Tacoma is not one of those from what I have seen.
    Now if these ARE the airbags in the seat, then you will want to be cautious, but as you said, if you never turn on the key, and dont apply voltage to the connectors, you will be fine.
  11. Sep 4, 2012 at 1:21 PM
    BamaToy1997
    Bill
    Navarre, FL
    OK, did a tiny bit of research and yes, some of the Tacoma trucks DO come with airbags built into the seat itself. Proper precaution is to disconnect the battery according to Toyota.
  12. Sep 4, 2012 at 1:26 PM
    B737
    Kevin
    Jersey Shore
    stock
    Thank you bill!! :)
  13. Sep 4, 2012 at 1:44 PM
    brian
    Elizabeth City, NC
    I think it was on the Sport models. A little search about seat covers on WetOkoles site will tell ya for sure.
    Were you ever a maintainer or do you just drive the metal tubes? :)
  14. Sep 4, 2012 at 1:53 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    My '09 has seat airbags
  15. Sep 4, 2012 at 3:44 PM
    B737
    Kevin
    Jersey Shore
    stock
    Brian, I'd never go near an airplane w wrench! ;)
    Just drive em', doing my part to keep the mechanics busy...
    My base has seat air bags and sensors. Looks like from what u guys are saying I'll trip the light if I don't disconnect the battery before I pull the seats out.
  16. Sep 4, 2012 at 3:54 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    So does my 07. :cheers:
  17. Sep 7, 2012 at 6:08 AM
    B737
    Kevin
    Jersey Shore
    stock
    the verdict is in... "executive" whos been battling a rattling passenger seat in his 2012 double cab has removed his seat, with the battery connected, and it did not cause an airbag fault light. exactly the info i was looking and hoping for.
    my katzkins should be here next week will update the katzkins thread. thanks guys.
  18. Sep 7, 2012 at 6:14 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I disconnected mine when I pulled mine out since it literally takes less time to do so then it does to type the question in the first place lol.
  19. Sep 7, 2012 at 6:16 AM
    easyeatlanta
    easyeatlanta Artificial Intelligence beats natural stupidity
    Eric
    Memphis
    14 DC Trd Off Road
    yeah ive removed mine many times with no problem, I very rarely disconnect my battery on any electronic install, definitely not removal of seats
  20. Sep 7, 2012 at 6:33 AM
    B737
    Kevin
    Jersey Shore
    stock
    thanks gents.
    i understand in a perfect world removing the battery is just the smart thing to do...
    however i will admit to my laziness, and lack of not wanting to reprogram my remote start, head unit, and radar again :)
    im not worried about setting them off... i just wanted to be sure i wouldnt trip the fault light.
    steering wheel, no doubt disconnect the battery... but i had a suspicion with the seats...;)
    EDIT and Follow up... 9/15/2012
    Left the key out of the ignition, did not disconnect my battery, disconnected the seats, Removed them, and reinstalled. no airbag light or airbag faults.
