disconnecting middle seatbelt on bench seat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBeasty, May 10, 2008.
  1. May 10, 2008 at 11:16 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    08 standard cab, 2.7L, 4 sp auto.
    None yet
    Has anyone figured out how to disconnect the middle seat belt on the standard cab, bench seat Tacoma? Sometimes when I try to flip the seat forward, The seat belt locks up and keeps the seat from folding forward. Also, I'll probably never use it, and its just kinda in the way.
    Thanks, JB
  2. May 11, 2008 at 6:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    It should be bolted to the cab. Remove (if you cant slide the seat far enough foward) the bench seat and unbolt the center seat belt. Easy to do. :)
  3. May 11, 2008 at 9:45 AM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    I was afraid of that! I was hoping there was some way to undo it at the pivot point for the shoulder harness. That way I could just have it under the seat in case I ever need it. Toyota sure doesn't make it easy to alter safety features do they . . . :mad:
  4. May 12, 2008 at 12:29 PM
    SPOWERS07
    SPOWERS07 Well-Known Member
    Massachusetts
    2019 DCSB 4x4 off-road
    no you dont have to do that all you have to do is grab a really small flat head screw driver and push the little gray button in then the seat belt disconnects and you can tuck it behind the seat, its where the belt connects to the seat
  5. May 12, 2008 at 3:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Must be different on the newer reg cabs then. I had to unbolt them on mine. Thanks for the correction. :)
  6. May 13, 2008 at 9:29 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    Yeah, I have a little grey "dimple" where the button used to be. I went by Toyota today. The Mechanic was all ready with his little screw driver, then saw there was no button.
    Probably a cost saving measure. Or maybe the button was removed because of some law suit.
    Pisses me off :mad:. Now to get the thing out of the way, I have to eliminate the middle seat belt, rather than just temporarily disconnecting it.
  7. May 14, 2008 at 5:32 AM
    SPOWERS07
    Massachusetts
    thats weird i work at a dealership ill go out to an 08 and look cuz mines an 07 and i have that little dimple
  8. May 16, 2008 at 10:11 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    SPOWERS, Do tell if you find something out about disconnecting the middle seat belt! Thanks, JB
  9. May 18, 2008 at 3:05 PM
    Cusker
    Cusker Member
    You can seperate the two halves of the seat belt to "unbuckle" it but it's a pain in the rear. To save everybody else the trouble simply drill a small hole as shown in the picture below. Once done insert a straightened paperclip into the hole and voila, you have unbuckled the center seatbelt and can do so at anytime without having to pry the two halves apart.
    http://picasaweb.google.com/notnert/SeatBelt
    Trenton
  10. May 18, 2008 at 6:20 PM
    JBeasty
    JBeasty [OP] Member
    Northern California
    None yet
    Thanks Dudes!
    I ended up cutting a rectangular notch just big enough for my key to fit into. Took pics for any one interested (they came out blurry though). Now if I ever need to use the middle seat belt, it's still under the seat.
  11. May 18, 2008 at 6:46 PM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    That was my first mod. Did it after two friends thought I'd drive them both home at the same time. Made the belt disappear and now I have an excuse. Mine's an 08.
  12. Aug 1, 2010 at 7:55 AM
    ruger_shooter
    ruger_shooter New Member
    Welaka, Fl
    09 2WD Regular Cab 2.7L
    I have a 2009 Tacoma Regular Cab and I had the same problem with the second child safe buckle for the middle seat belt. There is a way to properly release the buckle by pushing and twisting but I couldn't figure it out. There is a dimple on the top of the buckle in front of the seat belt slot where I drilled a small whole no bigger than the dimple itself. Then I stuck a jewelers screw driver in the hole and wiggled a bit side to side and out popped the seat belt. When you want to use the buckle again just release the seat belt by using the screw driver in the same manor. When drilling you just want to make an access hole in the top of the plastic housing so be careful not to drill too far. Good Luck.
  13. Aug 1, 2010 at 8:33 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    On my '06 (traded in ... I can't go see) it seems I remember that the key fit in a slot and the shoulder belt came out. I then unclipped it at the top of the seat and had it secured on the back wall of the cab.
  14. Sep 6, 2010 at 3:45 PM
    rromero022
    rromero022 New Member
    pdx
    2010 4x4 reg cab SR5
    This topic was helpful. Just bought a 2010 and mine has 2 little buttons that you push down on the latch with something that is close to the diameter of the holes to separate the plastic cover. I wanted to put a bench seat cover on. The drill hole method is good too.
  15. Apr 3, 2011 at 12:28 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bump! I just needed to do this and Cusker's photos showed me what I needed to do! Thanks.
  16. Aug 1, 2011 at 7:38 AM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    Thanks for the help guys, I drilled a small hole with just the bit and my fingers, got the plastic thin enough and pushed in an awl to disconnect the seat belt! Thanks for the photos Cusker!
    2009 Reg Cab
    Taccat
  17. Jan 24, 2012 at 10:22 AM
    Chuckracer
    Chuckracer Member
    Beautiful! Love this site!
    My '09 came apart as I was drilling the small hole - the tip of the drill bit was enough to pop it apart.
    I stuck the two ends through the seat back and re-connected them behind the seat so they wouldn't rattle.
    Thank You!! :D
  18. Apr 14, 2012 at 11:44 AM
    mjswan
    mjswan New Member
    Georgia
    Tacoma 4WD
    Thanks! This is just the information I needed.
  19. Aug 20, 2012 at 7:46 PM
    orion44
    orion44 Well-Known Member
    Las Vegas
    2012 Reg Cab 2.7L
    Bakflip G2 tonneau cover, Coverking Mesh all-black seat covers, Pop & Lock PL5300 Tailgate Lock, MB TKO 16x8.5" wheels with alternate center cap, Yokohama 580 235/60-16 tires, after-market fog lights, K&N drop-in air filter
    I needed to unbuckle the middle seat belt to install my Coverking cover - poked a hole in the dimple with a tiny screwdriver and wiggled a bit to get it to unlatch - thanks guys!
  20. Nov 26, 2012 at 8:51 AM
    cwtrumpet22
    cwtrumpet22 New Member
    TACOMA
    I just disconnected the center belt in my 2012 with a bench seat. The dimples don't appear to do anything. Pry the plastic cover off. Inside is a slide bar. Slide it to the left and the belt will release from the seat.
