Disconnecting the battery on a 2015 model...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rreed1900, Nov 1, 2016.
  1. Nov 1, 2016 at 6:22 AM
    rreed1900
    rreed1900 [OP] Member
    Bob
    Westminster, MD
    2015 Toyota Tacoma
    I am starting to see some signs of corrosion on the terminals and bracket and would like to disconnect the battery, clean the terminals and install some NOCO washers to reduce corrosion. I have a NOCO Settings Keeper (a 9v powered device that plugs into the cigarette lighter jack that is suppose to retain radio and ECM settings) but I tried on my wife's Honda Fit and it didn't work as expected. I don't know where I put the Tacoma's radio code, so I really want to avoid locking it. Does anyone know if I need to have the key in the accessory position when using the settings keeper?
  2. Nov 1, 2016 at 6:39 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Those little 9v battery deals don't usually work on newer vehicles, the ones that do work use a jump box and plug into the OBD port.
  3. Nov 1, 2016 at 7:55 AM
    shotgunshooter3
    shotgunshooter3 Well-Known Member
    Somewhere in the Southwest
    2025 DCLB TRD OR, Blue Crush Metallic
    Mud flaps
    I recently swapped batteries on my '14, didn't use a memory saver, and the vehicle retained all my radio presents, Bluetooth link, etc.
  4. Nov 1, 2016 at 8:40 AM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I run jumper cables from one of my trolling motor batteries for when I swap batteries or do terminal maintenance.
    1. attach jumper cables to trolling battery
    2. attach jumper cables to somewhere on the positive terminal other than the part that goes around the battery terminal and the negative to ground somewhere.
    3. keep in mind the terminal is HOT (electrically) so DO NOT TOUCH GROUND ANYWHERE ON THE TRUCK WITH THE POSITIVE SIDE
    4. clean, replace or whatever battery maintenance you need to perform at your leisure.
    5. put everything back then disco the jumper cable from the truck.
    I've done this method for years. I used to attach the jumpers to a motorcycle ( easy to park beside the truck) and once I attached to a tractor battery.
  5. Nov 1, 2016 at 9:36 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    I added fog lights on my '15 and disconnected the battery. I didnt lose any settings.
  6. Nov 1, 2016 at 9:40 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think hes more concerned about his security code not the presets..
  7. Nov 1, 2016 at 10:04 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Disconnected my ground the other night. did not have to re-enter my stereo code or do any presets. all I lost was my trip meter mileage.
  8. Nov 1, 2016 at 4:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    The 9 volt plugged into the jack will work as long as the jack is connected to the power circuit. In other words the key needs to be on the position that normally provides power to the jack socket. ON
    That is probably why it didn't work on the Honda Fit.
    EDDO likes this.
