disconnecting tpms???
Discussion in 'Technical Chat' started by dabighi, Dec 4, 2008.
  1. Dec 4, 2008 at 7:27 PM
    dabighi
    dabighi [OP] Well-Known Member
    anyone know how i can disconnect the tpms. im getting my wheels and tires installed this weekend and i honestly dont think i need to have it switched over. it costs 68 for all four to be installed without the tpms and 170 with the tpms. plus another 100 or so for the alignment. damn 4wheel parts so friggin expensive.
  2. Dec 4, 2008 at 7:43 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    put the 5 tpms sensors in a pressurized pipe to whatever the stock pressure is and leave that pipe behind a seat or in storage...no light and ur still able to use the sensors if u want to
  3. Dec 4, 2008 at 7:47 PM
    dabighi
    sounds like it might work.anyone done it? thinking maybe just a 3" diameter by 6-8"long pvc with some sealed end caps and a valve of some sort to pressurize? or is that too macguyver and not gonna work?
  4. Dec 4, 2008 at 7:52 PM
    The_Hodge
    SC
    i think thats pretty much what most have done...pvc pipe, end caps, and some sort of valve to connect to a compressor
  5. Dec 4, 2008 at 9:26 PM
    dabighi
    sweet. any recommendations on what type of valve i can use. kinda havin a brain freeze moment
  6. Dec 4, 2008 at 9:28 PM
    The_Hodge
    SC
    u can prolly find like a half inch threaded valve to put into the pipe somewhere....maybe find a cap that has that same threading in it
  7. Dec 4, 2008 at 10:41 PM
    SmootDog
    SmootDog Active Member
    Oklahoma
    2009 D-Cab TRD Sport 4x4
    Drill a hole in one of the caps and pull a valve stem into it.
  8. Dec 5, 2008 at 5:24 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    i like the tpms, it lets me know when i need to fill air... perfecto!!
  9. Dec 5, 2008 at 7:14 AM
    lsarg27
    lsarg27 Member
    Cape Cod.
    4x4 double cab long bed
    Tonneau, cold air intake, TSB
    How about getting some of those Heavy duty long zip ties and strapping the monitor to the inside of the rim before mounting the tire. That way you would still have a working TPMS without having to buy new monitors that fit the new rims.:rolleyes:
  10. Dec 8, 2008 at 12:08 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    unless you ever change your rims. the sensors are about $115 ea when they go bad or the battery in them dies.
  11. Dec 8, 2008 at 12:18 PM
    bcmedic
    bcmedic Well-Known Member
    i went n bought a really small tire/rim from home depot, a wheel barrow wheel. dropped all 4 into it and pressured it.
  12. Dec 8, 2008 at 12:19 PM
    crawfishsoul
    crawfishsoul Look at my member
    Removed front mud flaps.
    Instead of the whole pipe thing, why not just take them out and go through the TPMS reset steps as if they are in the tires?
    I read this from 007Tacoma:
    So wouldn't resetting the TPMS while the sensors are sitting in a plastic baggy in your glove compartment do the same as sticking them in something that looks like a pipe bomb in the back of your truck?
  13. Dec 8, 2008 at 2:28 PM
    bcmedic
    ^ clever idea...has anyone actually tried it? i personally would like to get ride of my wagon wheel in my truck. reset it at ambient air pressure....hmmm
  14. Dec 8, 2008 at 2:33 PM
    crawfishsoul
    I'm also wondering if the truck cares of the sensors aren't near the rig. If it can't "see" the sensors then it can't report back low pressure can it?
    Maybe if it doesn't sense the monitors nearby it sets off an alarm telling you your wheels have been stolen? :p
  15. Dec 8, 2008 at 2:55 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    The truck is in constant communication with the sensors. Therefore if they aren't close to the vehicle then the light will come on.
    One member even had the wheels in the garage by the truck and every night the sensors and truck got together and said hey, lets shut this light off. Then, when he started the truck at work away from the sensors they had seperation anxiety and flipped the light back on.:D
    As far as setting them alone without pressure, I'm not sure. You would probably have to remove the one in the spare and reset it as well. Can't remember seeing anyone do this. Maybe it can be done..........
    Remember, you will have to pay the dealer to do it....
