Discontinued Clock Spring - will other models fit? 96 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoV6, Dec 1, 2022.
  1. Dec 1, 2022 at 7:19 AM
    TacoV6
    TacoV6 [OP] New Member
    Hiya Guys,
    I'm on the search for a 96 clock spring with cruise control i've been searching high and low for this item with no luck,
    i was hoping you wise and experienced Tacoma legends might know of a clock spring that would work from a different year or model Toyota, i've tried going down the OEM route but unfortunately they have discontinued that item and ive had no luck finding any alternative.
    i did read that maybe a 93 corolla clock spring might work
    i really appreciate any help you can provide
    thanks
  2. Dec 1, 2022 at 9:31 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Hard to remember just what might work unless some one is in the middle of the same job.
    I have had good luck advancing in years with Toyota Parts .Till I found the part still in stock.
    Toyota likes to use different part numbers for different vehicles for the same part.
    CarPart.com for what you need.
    Just what is wrong with yours it needs replaced ?? Have you tried cleaning?
  3. Dec 1, 2022 at 11:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have one for a 96 if you’re interested in buying it
    Bivouac likes this.
  4. Dec 1, 2022 at 8:47 PM
    TacoV6
    absolutely ill send you a message right now
  5. Dec 4, 2022 at 10:07 AM
    TacoV6
    Bump
