Discount gas vs. major chain station's gas?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Caslon, Mar 30, 2020.
  1. Mar 30, 2020 at 9:29 PM
    Caslon
    Caslon [OP] Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Anyone avoid no name gas station's gas? The major stations like 76, Arco and Shell spend millions in advertising that tout the extra little something they add to their gas. It depends on the location of your city, but here in So.Calif. Shell, Union 76 and Arco charge as much as 40 cents a gallon more for their 87 octane over no-name gas stations. 40 cents more seems a bit outrageous if you don't get that much more benefit. I bought a tank full of no-name unleaded 87 octane for my 2003 Tacoma standard cab 5 speed and got a very decent 20 miles per gallon city driving. Is it mostly marketing spending 40 cents more a gallon? Anyone do a comparison?
  2. Mar 30, 2020 at 9:31 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I like the ones that have chocolate milk and a clean restroom
  3. Mar 30, 2020 at 9:36 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Top Tier seems to be the real deal, but I haven't noticed much of a difference. I definitely prefer ethanol free though.
    Other than that, whatever is cheap.
    Arctic Taco, SR-71A and BillsSR5 like this.
  4. Mar 30, 2020 at 9:38 PM
    WhiteTruckMafia
    WhiteTruckMafia Well-Known Member
    TN
    19 TRD PRO
    The only fuel that’s worth the price is SHELL premium. It actually DOES clean a system out great. We don’t need it in our trucks and it detonates slower than needed for our trucks too. I run it in all my high compression bikes.
    CS_AR and gasparic104 like this.
  5. Mar 30, 2020 at 9:51 PM
    WhiteTruckMafia
    TN
    19 TRD PRO
    Correct, just different fuel additives by brand is all. You select which to mix with the fuel depending on what fuel stations you’re delivering to. Really just look out for old af stations. Old tanks in the ground are prone to have water/more sediment in the tanks.
  6. Mar 30, 2020 at 9:52 PM
    WhiteTruckMafia
    TN
    19 TRD PRO
    Then your mid grade is just a blend of your low/high test.
    Gunshot-6A likes this.
  7. Mar 30, 2020 at 10:04 PM
    Caslon
    One station here sells ethanol free gas. Only one. Not been to that station and not sure it's even in business.
    I Googled "Is ethanol bad for your car?", Wow. That bad, huh? Too extreme a viewpoint? The reply below wasn't from a forum.
    "Ethanol can cause several types of damage to the engine in your vehicle. Your vehicle's fuel intake components can be damaged. In addition, ethanol can cause damage to the fuel pump in your vehicle. ... Your engine can actually be destroyed if the ethanol content in the fuel you use is too high."
    robssol likes this.
  8. Mar 30, 2020 at 10:06 PM
    tcjacado
    tcjacado Well-Known Member
    As long as you stick with high volume stations, the risk is small. You almost have a better shot of the delivery guy putting diesel in the unleaded tanks.
  9. Mar 30, 2020 at 10:14 PM
    WhiteTruckMafia
    TN
    19 TRD PRO
    LOLOL. I’d be going to jail if I pumped diesel into my truck.
    tcjacado[QUOTED] likes this.
  10. Mar 30, 2020 at 10:19 PM
    Caslon
    So so true. I once got gas at an ancient gas station and my truck ran like someone had poured sugar in my gas tank. Hehe, afterwards, it made me buy a locking gas cap for that truck. I'm considering buying one now for my present Tacoma. Is it possible they make a locking gas tank door for my truck that uses my ignition key? Probably not.
  11. Mar 30, 2020 at 10:39 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I live by a Citgo refinery and you see every brand of tanker lined up plus a bunch of unmarked trucks at the racks. It all comes from the same place. Now I do know techron from chevron is an actual additive that is injected while the trucks are loading. I know this because I worked at an airport and we had instances were that was accidently injected into jet fuel instead of anti ice additive while the tanker was loading at the refinery rack.
    I buy from where ever, usually a grocery store by my house. I will say never get gas while the tanker is there, its pretty common for them to dump diesel In the wrong tank, or water contaminated fuel, plus it stirs up all the water and crap at the bottom of the tanks.
  12. Mar 30, 2020 at 10:40 PM
    gasparic104
    gasparic104 Trusty Spotter
    Cayleigh
    Instagram: @NotSo_JDM
    2015 Tacoma TRD Sport DCLB; 21 & 03 Corolla
    If it helps, my dad manages a gas station and my step-mother is a district manager for Circle K, like people are saying, if you stick chain, there's little risk. Stations that just use branded gas but are their own independent shops are more likely to have water in their gas tanks. The inside of their store and their management are usually pretty telling if they care about their quality of gas or not.
    I try to avoid filling when the tanker is there personally, it's not terribly important, especially at a reputable gas station.
    I personally try to find a chain that I like going inside of, that's abundant in my area, so I can stick with fueling with the same type of fuel. I can't attest to how important that is, but I know it's supposed to be better to run the same gasoline. You'll find more stability with a chain for sure.
    I live in the midwest, and personally like QT. I'm from Wisco though, and have to say my favorite chain ever is KwikTrip, so that's who I use when I'm there (If you know, you know). On road trips, I tend to gravitate towards Love's, or where ever the truckers are going.
    If you're looking to get the absolute best out of your gasoline, you can look up who uses what additives. I don't really research that kind of stuff. Shell gas is supposed to be some of the best, but I know other branded gas uses different additives as a draw. I really don't know much about all of that. Since my parents work for Circle K, they rant and rave about the Shell gas, but I don't know enough personally.
    Big life hack if you're a pay at the pump kinda person; if the lot is clean and the receipt tape is stocked, you're much less likely to get your card info stolen. A lot of stations don't replace their receipt tape which means they're probably interacting very little with the machine, and it's pretty easy to get a skimmer in there. Someone who's maintaining pumps is more likely to check that.
    Fun fact: half the time gas stations post their prices, if it contains a 3, it's upside down. It's really hard to tell at first, but once it's pointed out to you, you never unsee it.
  13. Mar 30, 2020 at 10:52 PM
    tcjacado
    Yes. But when the tanker is there adding fuel, it stirs up the sediment.
    Hamer95USA and robssol like this.
  14. Mar 30, 2020 at 10:59 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    Heres the thing though gas gets contaminated and when it does your car will seize up, a no name brand will not stand behind its product or its ways it contains the gas if you sue them or go after them, if you get bad gas as in water in your gas tank to the engine by a big name brand theyll have no choice but to atleast go to court and resolve things as they are a “known” brand
  15. Mar 30, 2020 at 11:37 PM
    gasparic104
    Cayleigh
    That doesn't stop movement of sediment. As the pumps pull fuel, what's around may come up, but not everything, given the pipe that pulls gas is usually at one side of a holding tank. That's not what's keeping you safe.
    The main reason people shouldn't typically worry about sediment is the fact that there are filters in the system so crap doesn't end up in your car.
    You can still avoid these times of day for peace of mind. There's no problem with that. Errors can always be made. Another reason to stick with corporate stations.
    Anyone who's worried about it can always get a fuel testing kit, or even check jerrycans, pump fuel into a jar, whatever.
    BillsSR5 and Caslon[OP] like this.
  16. Mar 31, 2020 at 12:03 AM
    Caslon
    After reading replies about filling station practices, I'm gonna change my fuel filter. Been about 40,000 miles now, mostly discount station gas. I run my tank to empty a lot. Big tank same as small tank? Lol.
  17. Mar 31, 2020 at 12:10 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    I’ll pay 10 cents more a gallon for gas with cleaning additives but I’ll never go out of my way for a specific brand. Just whatever is convenient/ good price. Now if I had a Porsche I would probably be more anal about what goes in my tank.
  18. Mar 31, 2020 at 12:25 AM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    When my Passat was new, I only filled up at chevron or shell. Premium only.
    With my trucks (03 and 19), I fill up at qt, and circle K as well. I stopped going to shell because some stations here post the cash price and with CC it’s like 30¢ more
  19. Mar 31, 2020 at 1:47 AM
    Caslon
    What year? Why?
  20. Mar 31, 2020 at 2:55 AM
    luis25
    luis25 Member
    Jose Luis
    Arizona
    2002 Tacoma Prerunner 3.4 AT 2wd
    Arco is the cheapest gas around here.
