Discount Tire conundrum
Discussion in 'Wheels & Tires' started by Tscott, Jul 22, 2016.
  1. Jul 22, 2016 at 3:12 PM
    Tscott
    Tscott [OP] Active Member
    Scott
    Texas
    2014 Tacoma 4x4 SR5
    Recently, I went from a from a 16 inch wheel to a 17 inch wheel with 265/70/17 tires. I told the guys at Discount Tire that I didn't want anything to rub. They said my mudflap might be a problem so I took it off. When in reverse something else still rubs. I'm taking it back to Discount Tire tomorrow as I understand they have a really good return policy and customer service -at least I hope so. What size tires should I go down to?
    I relied on them to fit the tire to the truck but perhaps I should have done a better job on research myself.
    My new tires are Cooper Discovery ATP if that matters.
  2. Jul 22, 2016 at 3:21 PM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Just trim your fenders some of your inner fender hommie, Everyone on this site has dealt with this problem haha
  3. Jul 22, 2016 at 3:21 PM
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    That's odd, as that size of tire should clear no problem (as a general rule). Only thing I can think of it's related to the wheel/rim specs. What are they?
  4. Jul 22, 2016 at 3:22 PM
    Nighthawk
    Levi
    Casper Wyoming
    That message made very little sense, I'm not drunk, its just approaching 5 pm on a Friday at work
  5. Jul 22, 2016 at 3:33 PM
    Tscott
    Scott
    Texas
    2014 Tacoma 4x4 SR5
    I don't know the wheel size other than 17 inch. I'm pretty ignorant about this stuff.
  6. Jul 22, 2016 at 3:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you still have those tiny little mudflaps on it on the front?
  7. Jul 22, 2016 at 3:39 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    I put the ATP's on my truck from Discount. 265/75 16. Have my flaps and only slightly rub on full lock.
  8. Jul 22, 2016 at 3:40 PM
    Tscott
    Scott
    Texas
    2014 Tacoma 4x4 SR5
    Yes on the tiny front mud flap. Do you think it needs to go?
  9. Jul 22, 2016 at 3:41 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Most definitely. I guarantee 100% thatll fix your problem.
    JDM likes this.
  10. Jul 22, 2016 at 3:46 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Considering this is only a 31.6" tire you shouldn't be having rubbing issues.
    You might need to look at your alignment and make sure your caster is right (or move it forward).
    I had 265/75/16 (also a 31.5" tire) and never had rubbing issues with mud flaps on. And that was prior to lifting the truck.
  11. Jul 23, 2016 at 6:15 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    It is your new wheels. The offset is pushing the wheels out more and causing the rub. That size should fit, it is not discount tires fault, it was your wheel choice or alignment as stated already.
  12. Jul 23, 2016 at 10:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Did you remove the tiny front mud flap?
  13. Jul 23, 2016 at 11:37 AM
    Tscott
    Scott
    Texas
    2014 Tacoma 4x4 SR5
    Yup, and I think that fixed it. You were right. Thanks for the help.
