Disk brakes dragging
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jere, Aug 14, 2018.
  1. Aug 22, 2018 at 5:32 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Just reading your latest reply - it is probably nothing. Just a light brake drag.
    I'd probably do everything I mentioned because I'm a bit OCD, but again, that's just me.
    If you aren't comfortable doing the above, weigh my suggestion against the possibility of breaking something and the reality of spending one of our few remaining summer afternoons wrenching on your truck.
  2. Aug 22, 2018 at 6:23 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    If it bothers you that much,then put new brake calipers on the truck.
  3. Aug 22, 2018 at 6:28 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Fwiw when I got new pads on mine they didn't fit...I had to tap it in. Of course they dragged and rotor got hot, so I took em back out. I'm had been thinking of getting new calipers and when I put in the new calipers from Autozone, the pads fit perfectly. Same thing happened with my 4runner. I started thinking the spec changed. YMMV
    Quick note to future readers, don't assume brake dragging is normal. Check temps with a laser. Mine were nearly 500 degrees and the other side was 170. Somewhere in there is a normal range. But wheel should never feel hot or sizzle when wet.
  4. Aug 22, 2018 at 6:29 AM
    lynlan1819
    Tacoma
    Lifted
    Never had that problem with factory pads
  5. Aug 22, 2018 at 6:33 AM
    Benny123
    Ben
    South Charlotte, NC
    You may have newer calipers. Mine were from 2005.
  6. Aug 22, 2018 at 6:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Credible.
  7. Aug 22, 2018 at 6:59 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I did. Factory don't mean perfect
  8. Apr 20, 2024 at 3:45 PM
    Vance4
    Vance4 Member
    What if it did smell like a bad clutch? What would be your suggestion? I've been going through a similar problem. Thanks.
  9. Apr 20, 2024 at 5:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the brakes, they could be sticking and getting too hot. Look for big differences in pad wear side to side. That would indicate a sticking caliper or something not clamping evenly
