disk vs. drums ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hans17, Dec 16, 2007.
  1. Dec 17, 2007 at 2:42 PM
    hans17
    hans17 [OP] Well-Known Member
    san juan puerto rico
    tacoma xtra cab v6 sport 2007
    3"ez-lift kit , 1" spacer , stock wheels 17" , 285/70-17
    well i just tried my wife's rav4 emergency brake and even pulling it all the way it won't hold so good , maybe the tundra has it updated
  2. Dec 18, 2007 at 1:50 AM
    hans17
    u are absolutely wright :)
  3. Dec 18, 2007 at 4:45 AM
    beondwacko
    beondwacko Well-Known Member
    West Palm Beach, Florida
    08' X-Runner , Sirius radio, fog light mod. Much more to go.
    So I've had my X-Runner for a few days now and I'm being easy on everything for break in purposes including the brakes, but from what I had read before I bought the truck about the pedal being a little soft,,,,,,, it's true.
    I Will for sure be doing the braided line upgrade. I had done this to a few of my other vehicles in the past and it really makes for an improved pedal feel. For $100- how could anyone go wrong? The only pita part of it is the bleeding. Let me offer one tip to those who are considering this. Buy a vacumn bleeder. It's the easiest way to do the job and more effective than pumping the pedal from my experience.
  4. Dec 18, 2007 at 4:52 AM
    hans17
    how about calipers are full floating calipers better than non full floating? what do you guys think about this ?
  5. Dec 18, 2007 at 7:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Non floating calipers? Is there such a thing? Never heard of it - sounds like old technology.
    The reason why they float, is so you get even pressure on both sides of the rotor and even pad wear on both sides. Not only that - but they 'self adjust' to compensate for pad wear. With disc brakes, the pads are just barely touching the rotors....(unlike drum brakes).
    http://auto.howstuffworks.com/disc-brake.htm
  6. Dec 18, 2007 at 7:13 AM
    hans17
    yeah but the tacoma calipers in front are not full floating
  7. Dec 18, 2007 at 7:38 AM
    Janster
    Jandy
    Lancaster, PA
    Just did some research - cuz I was curious to know....
    http://www.hotrodheaven.com/tech/brakes/brakes1.htm
    And went out and looked at the truck. There are 4 pistons - 2 on each side.
    Hmm...and this allows for less pressure & volume to operate.
    This will be an interesting learning experience changing pads on these things. Never worked on a non-floating caliper before.
  8. Dec 18, 2007 at 7:48 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's easier than you could ever imagine. Compress the pistons in the caliper with a C-Clamp, pull a couple of pins, and the pads slide out the top. Drop the new ones in, reinstall the pins, pump the brakes, and you're done!
  9. Dec 18, 2007 at 8:50 AM
    hans17
    now we are talking i know how to replace the pads my porsche has this kind of calipers but my question is full floating is better because when disk get hot they twist in a strange form and full floating calipers adjust to the disk while it is twisting , that is why when the disk get hot and twist if they get cool to fast they stay bent , that's when you feel the brake pedal go up and down while you brake.
  10. Dec 18, 2007 at 11:57 AM
    Janster
    Jandy
    Lancaster, PA
    Thanks - sounds pretty easy.
    Does that mean there's 2 bleeder screws for each caliper? or is there a single one near where the fluid comes in? Not that I'll ever be bleeding my brakes anytime in the near future....
  11. Dec 19, 2007 at 8:01 AM
    mjp2
    NJ
    You'd think I'd have paid more attention when I was under the truck, wouldn't you? I have no idea on this one. (Of course, ignorance isn't going to stop me from upping my post count by 1. ;))
  12. Dec 19, 2007 at 8:14 AM
    Janster
    Jandy
    Lancaster, PA
    :D
    I have this tendency to *think* too much about stuff .... and yap and yap about wanting to know about things that really aren't important at the current time. I can thank my dad's genes for that. :rolleyes:
