Dispersed Electrical Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by aemsfactory, Nov 6, 2024.
  1. Nov 6, 2024 at 6:28 AM
    aemsfactory
    aemsfactory [OP] Well-Known Member
    2001 Black Tacoma TRD w/ extra rust
    I've slowly accumulate various electrical issues with my 01 Tacoma. Things like the cruise control, radio, side mirror adjustment, horn and now most recently the turn signals. The other ones I could deal with, but the turn signals are a bit more important. The turn signal indicator on the dash isn't showing up, so I think it's a deeper issue. Any help on where to start and what to look for would be greatly appreciated.
  2. Nov 6, 2024 at 6:37 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Start simple. Clean up your grounds. Bad grounds will cause strange things to happen. You have a 24 YO truck. Generally, clean up the contacts.
    TacoSR523 likes this.
  3. Nov 6, 2024 at 7:44 AM
    aemsfactory
    Great suggestion, thank you. Where could I find the ground locations? Or should I just do all the connections?
  4. Nov 6, 2024 at 9:08 AM
    rnish
    Tacoma 2nd gen
    I would start in the engine bay. My Highlander had multiple grounds going from the chassis to the engine block and head. Bad ground caused half my instrument panel to go dark.
  5. Nov 6, 2024 at 9:42 AM
    aemsfactory
    Ok will do, thank you
  6. Nov 6, 2024 at 3:15 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Aemsfactory
    look for critter wire chewing…..especially if taco parks outside
    just bc I just found this out after 23yrs of paying for critter damage….all manufacturers use freakin corn starch on outside of colored wires inside the wire sheath to promote easy movement/less pinching of said harness
    UGH
    RustyNut1996 likes this.
  7. Nov 7, 2024 at 6:10 AM
    aemsfactory
    So it ended up being a fuse :facepalm:
    Idk why I didn't check those before, but the turn signal and ACC fuses were blown
    But after replacing them last night, the blinker fuse blew again this morning. Any thoughts?
  8. Nov 7, 2024 at 8:36 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    you have a short somewhere if it's blowing the fuse after just changing it.
  9. Nov 8, 2024 at 1:20 PM
    aemsfactory
    Yep, did some digging and found the short. All good now, thanks
  10. Nov 8, 2024 at 5:33 PM
    CrippledOldMan
    David
    2003 TRD Crew Cab
    None
    Glad you found it and all is good now. Pat yourself on the back for a job well done!!!
