Disrespected by a 4-banger
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stocklocker, Nov 26, 2023.
You gonna let that new turbo 4-banger disrespect you?
  1. Yes
    75 vote(s)
    56.8%
  2. No
    57 vote(s)
    43.2%
  1. Nov 30, 2023 at 10:36 AM
    #181
    Dinasour73
    Dinasour73 Active Member
    Rickard
    2020 Tacoma Barcelona Red
    None
    Yep. Sometimes 400+. But you better
    But you better be at the gas pump.
    LOL
  2. Dec 1, 2023 at 9:55 AM
    #182
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    How about people that go and install turbos on engines that were never designed to have turbos ? At least Toyota has, I would think, redesigned their I4 to withstand the added heat and compression etc - maybe even over engineered them for reliability a Toyota selling point for decades. I am on the fence with the whole turbo/hybrid technology for now and really won't be in the market for a new car or truck for several years so I can afford to take a wait and see approach. But yeah, I really like my naturally aspirated V6 - actually if $$$$ were no object I would love to have a Tundra naturally aspirated V8 in my Tacoma just for the extra torque on the trail and to compensate for all the extra armor and BIG tires I would love to have . . . but all that is just fantasy on my budget.
    Stocklocker[OP] likes this.
  3. Dec 1, 2023 at 10:05 AM
    #183
    Blaze Creek
    Blaze Creek Well-Known Member
    2012 Tacoma trd sport
    Yes, the Tacoma V6 is a great truck but talking about winding out an engine towing? This what happens to both the 4.0 and 3.5L Tacoma when towing heavier loads. Higher rpms continuously and the engine gets worked.
  4. Dec 1, 2023 at 10:37 AM
    #184
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    JFC,
    Are people trying to tow 5k+ trailers with their Tacos?
    I've towed our Off road OGT trailer more than 5,000 miles (2k-3k loaded) with my DCLB and it's been wonderful.
    I don't think you have any idea what "terrible at towing" actually means.
    Try towing something that is actually terrible at towing like my previous JKRU, and you will find the Taco tows really well.
  5. Dec 1, 2023 at 11:08 AM
    #185
    Blaze Creek
    Yes, but 2-3 thousand pounds is considerably lower than the max towing capacity, with a Tacoma having the towing package.
    5,000 pounds is actually under the max towing capacity with the tow package, and a Tacoma does not do well with this much weight.
    Most people don’t buy a Tacoma with the expectation that it does well towing 5,000 pounds, but it doesn’t change that a Taco struggles with this weight. In the mountains? Really bad.
  6. Dec 1, 2023 at 12:49 PM
    #186
    Out2gtcha
    Brian
    Omaha, NE
    I've towed many other heavier things besides our current OGT trailer including my brothers fairly loaded 5,100 lb enclosed cargo and it did just fine, including up the pass in CO, especially when in manual mode, 3-4. Certainly no worse than any other vehicle I've owned, and considerably better than some.
    Again, the point is, if you are realistic in any capacity about your towing the Tacoma does just fine, and having done a considerable amount of towing, those are facts.
    Try towing something even remotely close the the towing capacity on a JKRU and you will definitely find out the meaning of "real bad". The Tacoma isn't the world's best towing platform, but it certainly isn't anything remotely close to "real bad".
  7. Dec 1, 2023 at 1:06 PM
    #187
    Blaze Creek
    Can’t argue with your experience. Will have to wait and see what towing reports are like with the new turbo.
    Out2gtcha[QUOTED] likes this.
  8. Dec 1, 2023 at 1:58 PM
    #188
    Out2gtcha
    Brian
    Omaha, NE
    I'm definitely not saying the Tacoma is the perfect towing platform and certainly has issues loaded up +5000 lbs going up the mountain pass, but I've found that I don't even need to keep it in man 3 or 4 going up the pass now that I have an OTT tune.
    Again, far from perfect, but once you experience a vehicle that is truly terrible at towing like my JKRU was, that had similar HP numbers and included a manual trans, you really dont see the Taco as being that bad.
    Would I choose something different if I regularly hauled my brothers dual axle box trailer that was over 5000lbs? Yes, for sure. But if you stick to realistic towing numbers the Taco does just fine.
    Blaze Creek[QUOTED] likes this.
  9. Dec 1, 2023 at 4:03 PM
    #189
    Blaze Creek
    Yeah, I know what you mean for sure. I have a 2012 second gen, just thought it was working hard to tow but can still get it done.
    Tell me about the OTT tune. I have a buddy with a 2022 Taco and just told him about the possibility of a tune.
  10. Dec 1, 2023 at 4:48 PM
    #190
    Out2gtcha
    Brian
    Omaha, NE
    Whole. Different. Truck. Literally the way it should have been from the factory, and has fixed nearly everything I had issue with in the 3rd gen power train.
  11. Dec 1, 2023 at 5:31 PM
    #191
    Blaze Creek
    Good to know.
  12. Dec 1, 2023 at 10:19 PM
    #192
    Stocklocker
    Stocklocker [OP] Well-Known Member
    17TRDORDCSBAT
  13. Dec 1, 2023 at 10:27 PM
    #193
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    What it really needs is a v8
  14. Dec 1, 2023 at 10:36 PM
    #194
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    Respectfully, I disagree.
  15. Dec 1, 2023 at 10:38 PM
    #195
    Oreo Cat
    I guess it would really depend on what v8 and I6
    I’d gladly take the b58 in a Tacoma, maybe even over the tundra 5.7
  16. Dec 1, 2023 at 10:41 PM
    #196
    Out2gtcha
    Brian
    Omaha, NE
    I've taken two long trips with my brother......
    One with his 2018 WK2 towing a large pop up, and one with his 2021 (2022?) WL towing a 5k+ trailer, both with Hemis
    The first trip I had a smaller trailer towed by my JKRU.
    The 2nd trip I had my DCLB towing our 3200(ish) OGT off road trailer.
    On both occasions he got better gas milage than me.
    :confused::(
  17. Dec 1, 2023 at 10:42 PM
    #197
    Stocklocker
    17TRDORDCSBAT
    The 4.7L v8 out of the 4G 4Runner would be awesome. Maybe updated.
  18. Dec 1, 2023 at 10:43 PM
    #198
    Cetacean Sensation
    PNW
    I’m admittedly biased here, but a B58 Tacoma would be one of the most rad machines on the road. But I wouldn’t kick that 5.7 out from the engine bay.
    And while we’re talking about two things that will never happen, give me a stick with either. Thank you.
    amyracecar and Stocklocker[OP] like this.
  19. Dec 1, 2023 at 11:16 PM
    #199
    Oreo Cat
    tacoma v6 = I4 power with v10 mpg
  20. Dec 1, 2023 at 11:25 PM
    #200
    Oreo Cat
    I I thought about it when replacing my engine, but its not worth the trouble for such low power gains especially being 200 lbs heavier. I dont know for sure how wiring would be as I don't have the experience but I imagine the only good thing about the 4.7 would be that it might be very plug and play especially if you bought a totaled 4runner to pull everything out of.
