Dissent offroad aluminum rack system interest
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dissent86, Aug 20, 2018.
  1. Aug 20, 2018 at 7:34 PM
    Dissent86
    Dissent86 [OP] Well-Known Member
    Ben
    2016 trd offroad Tacoma.
    Hey guys, have a 1st gen double cab in the shop now that I'm doing a custom over canopy rack setup on and would like to see if there would be enough interest to make this a production rack?
    The production rack would be about $$1090 for the bed rack, $650 for the cab rack and $800 for the accessory door set.
    This includes powder coating.
    I would have a long and short bed version of the bed racks but not sure if I would do an extended cab rack. The cab rack would need rails installed to the roof. IMG_1294.jpg
    970btu and opteron like this.
  2. Aug 20, 2018 at 9:01 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Lots of pictures could definitely pieqe interest.
  3. Aug 20, 2018 at 9:22 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    Sweet. I was hoping some of your stuff was going to trickle down to us first gens. Put me on the list for at least the cab rack. Busted the back window on my cap and it can't be replaced, so I may be looking for a soft top.
    @Fernando @FirstTimeFirstGen @Dan8906
    opteron, Dan8906 and Dissent86[OP] like this.
  4. Aug 20, 2018 at 9:24 PM
    Dissent86
    Ben
    Will get more pics as we make more progress, still in the beginning stages.
    Mainly just trying to see if it worth the time in fine tuning every little detail for a production rack or if this will be a one off.
    Bigdaddy4760 likes this.
  5. Aug 20, 2018 at 9:29 PM
    2BeersPlease
    Ben,
    The bed rack is just for softtops, correct?
  6. Aug 20, 2018 at 9:32 PM
    Dissent86
    Ben
    Should fit some hard shells as well.
    This customer is going to try and install his hard shell.
  7. Aug 20, 2018 at 9:35 PM
    2BeersPlease
    That makes things interesting. My soon-to-be-replaced cap is the Leer 100XQ. It has a bit of an arch front to back. If I replace it with another fiberglass shell, it will have a flat roof.
  8. Aug 20, 2018 at 9:38 PM
    License2Ill
    Ian
    Softopper's are about about 2" wider on each of the sides than the cab. No idea about bestops... And are's match the cab.
  9. Aug 20, 2018 at 9:39 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    I have an access cab so I dont think this setup would work for me, but if you made a rack for a hard shell or one that mounted to the bed and went out and around the shell to accommodate more weight, I'd be interested
  10. Aug 20, 2018 at 9:41 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  11. Aug 20, 2018 at 9:42 PM
    2BeersPlease
    :gossip: It's designed to go over the shell and mount to the bed.
  12. Aug 20, 2018 at 9:42 PM
    FirstTimeFirstGen
    David
    Pacifica
    I demand access cab!
    And more pics
    2BeersPlease[QUOTED] likes this.
  13. Aug 20, 2018 at 9:48 PM
    Dissent86
    Ben
    Are you sure the softtopper is 2" wider on each side? with how they mount I can't see how it would be possible to be 2" wider on each side. I know on the 3rd and second gen the softtopper is considerably narrower than the cab.
  14. Aug 20, 2018 at 9:49 PM
    2BeersPlease
  15. Aug 20, 2018 at 9:54 PM
    License2Ill
    Ian
    Positive. They start spreading out about 3/5ths above the bed top.
  16. Aug 20, 2018 at 9:55 PM
    License2Ill
    Ian
    2nd gens use the exact same softopper. And they're what? An 8" wider truck?
  17. Aug 20, 2018 at 10:14 PM
    Dissent86
    Ben
    They look pretty flush.
    If the second gen is the same topper than it will fit. This bed rack is the same width as my 3rd and second gen racks.
    FirstTimeFirstGen likes this.
  18. Aug 20, 2018 at 11:15 PM
    License2Ill
    Ian
    Alright. Well good luck. More pictures!
  19. Aug 20, 2018 at 11:20 PM
    License2Ill
    Ian
    I've owned two softoppers on my 1st gen btw. Trust me. They sit pride over the sides of the cab.
  20. Aug 21, 2018 at 6:21 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd like to see an extra cab roof rack for sure!
