Dissolving Paint on a Super White 2019
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Charlie Marlow, Mar 27, 2021.
  1. Mar 27, 2021 at 5:21 PM
    #41
    Charlie Marlow
    Charlie Marlow [OP] Well-Known Member
    Georgia
    19 TRD OR
    Yeah, I'm afraid you are right, but I really am scared to find out what's in there. :( They sticking lead acid batteries in there for some reason? :)
    As an aside on the lubing locks side of things, the few times I've done that in the distant past, I used graphite. Come to think of it, I've never even used the key to unlock the doors on this truck; I've always used the fob.
  2. Mar 27, 2021 at 5:25 PM
    #42
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So this is kind of a long shot, but look at the paint where the hinges of the door are, and where the fender meets the rocker.
    I have a thought that is hopefully 100% wrong, but its a idea. Brake fluid spilling out of the reservoir due to a bad or missing cap can make its way along the firewall till it finds a drain, then wind could blow it to the rocker.
    Its a crazy idea, but this is a crazy situation.
    HP11 and jmneill like this.
  3. Mar 27, 2021 at 5:29 PM
    #43
    Charlie Marlow
    Georgia
    19 TRD OR
    Will do when it gets light again. If that turns out to be the case, then it's going to be on the dealership as the truck has just shy of 20k miles and I've let them handle all of the service so far under the free maintenance plan. Not that I can even think of why anyone would pop the cap on it at its current mileage.
    5nahalf[QUOTED] likes this.
  4. Mar 27, 2021 at 6:19 PM
    #44
    mabupa
    mabupa Well-Known Member
    Miguel
    2021 trd off-road 6 speed manual
    If your truck has the “predator” steps Toyota puts on them, those look powdercoated. at least ones on my truck. Powdercoat is very very durable stuff. Either way, looking forward to seeing what the outcome is and hope you end up happy with the resolution and your truck goes back to looking great.
  5. Mar 27, 2021 at 6:30 PM
    #45
    Charlie Marlow
    Georgia
    19 TRD OR
    They are N-FAB ones, but I was wrong and they are powder coated.
    mabupa likes this.
  6. Mar 28, 2021 at 9:38 AM
    #46
    Charlie Marlow
    Georgia
    19 TRD OR
    I checked and it's definitely not an issue with brake fluid from the master cylinder reservoir. Everything under the hood behind and below the reservoir is fine and the damage doesn't extend to the front of the door. It looks like the worst of it lines up pretty well with the front weep hole in the door, so definitely looks like it's from something running through the door.
    That said, I'm still fairly baffled. There's no damage to the exterior of the door and the paint on the door below the weep hole is okay (there is damage to the paint on the edge that I noted earlier, but not right there). As has been noted, the next step is to pop the door panel and see what's going on back there as there isn't much more that can be gleaned before that.
  7. Mar 28, 2021 at 9:41 AM
    #47
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Damn I would be furious
  8. Mar 28, 2021 at 9:42 AM
    #48
    Charlie Marlow
    Georgia
    19 TRD OR
    Well, I ain't happy, but it doesn't look like it's Toyota's fault.
  9. Mar 28, 2021 at 9:46 AM
    #49
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Manual transmission? Is there any sign of fluid around the clutch master cylinder pushrod on the inside of the firewall?
  10. Mar 28, 2021 at 9:49 AM
    #50
    Charlie Marlow
    Georgia
    19 TRD OR
    It's a manual, but whatever got in there came through the door from the looks of it.
  11. Mar 28, 2021 at 9:51 AM
    #51
    Charlie Marlow
    Georgia
    19 TRD OR
    On the subject of it being a manual, I had the clutch pedal replaced a few months ago because it was creaking a lot, but I can't imagine any reason they would have had brake fluid inside the cab while doing that job.
  12. Mar 30, 2021 at 12:49 PM
    #52
    5nahalf
    Erik
    Minnesota
    Any update for us?
  13. Mar 30, 2021 at 1:27 PM
    #53
    Charlie Marlow
    Georgia
    19 TRD OR
    Not yet. It started raining before I got a chance to pop the door panel and nothing from Toyota yet (for the fuel pump they ordered nor the paint).
    5nahalf likes this.
  14. Mar 30, 2021 at 1:29 PM
    #54
    stuka
    stuka Well-Known Member
    21 Taco TRD Pro 6 speed
    Not just white paint, Taco paint.
    I metered the entire truck and it's mid to low 3 mils.
    That is ridicuously thin even for a budget brand.
    My old 16 STI which is a comparably budget brand is at least in the 4 mil.
    I like how ford does it on my Focus RS, you can pay for tri coat like the Nitrous Blue and get 8.x mils factory, so winning.
  15. Mar 30, 2021 at 1:30 PM
    #55
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    At what thickness is it too much?
  16. Mar 30, 2021 at 1:35 PM
    #56
    stuka
    4 is really pushing it, having been around autobody business my opinion is that anything under 4 is just needlessly cutting cost at the expense of quality.
    Let's take Dodge even, aside from sometimes having shells that weren't acid dipped properly, Challenger shells are 6 mil like my last hellcat which I metered at delivery. Even BMW back in its hay days of mid 90's only had 5.x.
    If Toyota really wants to cut cost, they should at least offer a $500 option for Tri Coat, that's what it was for the Focus RS to get 8.x mil.
  17. Mar 30, 2021 at 1:57 PM
    #57
    doublethebass
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    So what’s in a tri-coat? Would that be what seems to be dissolving here? Or the primer / undercoating?
  18. Mar 30, 2021 at 2:24 PM
    #58
    stuka
    A different paint process than what is on most regular cars.
    TLDR version is it's thicker.
    3.2 to 3.5 on my Pro is ridiculously unnecessarily thin.
  19. Mar 30, 2021 at 2:54 PM
    #59
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    That's effing nuts. My 2006 Xterra has been in salty ass.ohio ever since i got it. I literally have driven it across the country multiple times all conditions. The paint down there is still fine. You shouldn't have this.
  20. Mar 30, 2021 at 3:08 PM
    #60
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I love that she immediately gravitates to you screwed it up. People like her are why dealerships get such a bad rap. Hopefully Toyota makes this right.
