Distance from grille>battery>firewall
Discussion in 'Technical Chat' started by Sam091990, Jul 20, 2020.
  1. Jul 20, 2020 at 10:08 PM
    Sam091990
    Sam091990 [OP] Well-Known Member
    Sam
    BLK '12 DCLB PreRunner TRD Sport V6
    Marsauto LEDs in license tag lights Marsauto LEDs in map lights Yorkim Red LEDs in High mount brake light Zevo LED in dome light (may change that, it is not too bright)
    So, I am wanting to install some Grille accessories (pa system+grille lights). I need to know the distances listed in the title.
    Thanks
    Sam
  2. Jul 20, 2020 at 10:18 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    And you don’t own a measuring tape?
  3. Jul 21, 2020 at 1:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Possible the truck is several thousand miles away from his body??
    You do need the measurements in the Metric system correct??
    Batteries in non stock locations might not help I guess
  4. Jul 21, 2020 at 10:03 AM
    Sam091990
    Sam
    No, I do not own a measuring tape. Battery is in stock location. I am just looking for a quick answer. I need to know how how long the cable needs to be, lights come with 1ft of cable, they have extensions in 10ft and 20ft. I am trying to see if I need the extensions. I know I will definitely not need the 20ft extension since the truck is only like 18.5ft or something from bumper to bumper) . Will be running the lights to a 3 rocker (1 on/off for the 2 grille lights, 1 on/off for the PA, 1 momentary for the light pattern change) panel mounted in my cab near the steering wheel.
    Please no more smart-aleck answers though, I am just a guy without a measuring device looking for the help of other guys that may have done a project like installing LED bars or external speakers.
    Thank you
    Sam
  5. Jul 26, 2020 at 3:54 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    10ft should get you from anywhere on the dash to the grill. 20 ft from dash to back bumper. But if those are you only choices I’d always go too long easier to cut to length needed.
