Ditch Light Bracket Install
Discussion in 'Relentless Fabrication' started by taczilla, Aug 26, 2016.
  1. Aug 26, 2016 at 6:43 AM
    taczilla
    taczilla [OP] I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    I can't find instructions on the website on how to install these, and no instructions came with the package.
    I know there is a trick to it, but :notsure:
  2. Aug 26, 2016 at 7:13 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    They're super simple.
    Pop your hood open, determine the correct bracket for each side. Passenger side looks kind of like a 'd' and driver like a 'b' with the mounting ears off to the side and the bends of the bracket upward.
    Loosen a hood hinge bolt, slip the bracket in place and start the bolt again in the threaded hole on the hood, next loosen the 2nd bolt and pivot the bracket over until the second hole lines up, thread the second bolt. The hood may try to shift out of alignment, try to keep it where it was to make sure hood/fender/grille gaps are all still the same. When aligned tighten the 2 bolts and then repeat install on the opposite side of bracket. Lower your hood and attach your lights to the brackets, lift the hood back up to do your wiring on your lights and DONE.
    Jeffvt0508 likes this.
  3. Aug 26, 2016 at 7:16 AM
    taczilla
    Marc
    2016 RAM Rebel
    Upper bolt or bottom bolt first?
    Thanks for your quick reply!
  4. Aug 26, 2016 at 7:20 AM
    RelentlessFab
    Eric
    Sparks, NV
    I think with the ditch bracket the lower 1st, with the CB bracket the upper IIRC
  5. Aug 26, 2016 at 7:26 AM
    taczilla
    Marc
    2016 RAM Rebel
    I think that I read that somewhere too. Here goes....
    Thanks!
    EDIT:
  6. Dec 30, 2017 at 10:15 PM
    GYOAZ
    GYOAZ Well-Known Member
    Gary
    Tucson, AZ
    2015 Tacoma SR5 4X4 MGM access cab
    Billies and Eibachs, Camburg BJ UCAs, Demello hybrid sliders SOS HC rear bumper, SOS front bumper, Warn M80000, fully armored, Safari snorkel, No-slip locker, diff breather, bumper and roof mounted light bars, onboard Viair, 275/70 17 BFG ATs, and a badass sound system.
    Can these fit with a snorkel and 2x2 pods?
  7. Jun 29, 2020 at 12:13 PM
    microsnook
    microsnook Well-Known Member
    '20 TRD OR MGM MT
    I can't get the hood hinge bolts loose, mine are extremely tight.
  8. Jun 29, 2020 at 2:27 PM
    RelentlessFabrication
    RelentlessFabrication relentlessfabrication.com Vendor
    Sparks, NV
  9. Jun 29, 2020 at 2:32 PM
    microsnook
    '20 TRD OR MGM MT
    Thanks man. Do you know the size of these bolts? Mine is a bit stripped now I don't think it will go back on. Thanks again
  10. Jun 29, 2020 at 2:44 PM
    Sparks, NV
