Ditch light wiring help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Sep 7, 2016.
  1. Sep 7, 2016 at 6:34 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I have two LED ditch lights that I need to wire up tonight. Can I wire them in series? They're only 18 watts so I'm going to run them through my 25 amp switch for now.
    My thought was to wire from battery negative to a fuse holder, to pod #1, to pod #2, to the switch, then to battery positive. Does that sound right?
  2. Sep 7, 2016 at 6:36 PM
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    So you're putting the fuse on the negative side? That's usually donee not the positive. Other than that it sounds ok... Remember though that watts and amps aren't the same, what's the rating on your switch?
  3. Sep 7, 2016 at 6:47 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Your 25 amp switch is way over kill. 18 watts at 13.5 volts equates to 1.33 amps of draw and at 14 volts it's less, 1.28 amps of draw. These values are per light.
    Best way in my opinion is running power to a relay and using a small current charge to switch on the main power to the lights after going through a 7 amp fuse.
    5 amps may also be sufficient but over the years corrosion may play a role in increasing the resistance value and increasing amp draw.
    Your best bet is wiring both lights in parallel (each having its own power lead). That way when one dies the other can still operate.
  4. Sep 7, 2016 at 6:56 PM
    2.7taco
    Texas
    I'd get a 4 pin or weatherproof 5 pin relay and base.
    On post 30: will be supply voltage from battery to the relay. (7 amp fuse before the relay to protect both the relay and lights).
    Post 87: power out to lights from the relay.
    Post 87A: Unused.
    Post 86: low amp supply from in Cab fuse box behind cubby hole on lower drivers side dash to switch to the relay.
    Post 85: to body ground from the relay.
    Power in automotive applications goes positive to negative(ground).
    Hope that helps bud.
    03f5sp[OP] likes this.
  5. Sep 7, 2016 at 8:15 PM
    03f5sp
    Bill
    Wisconsin
    I decided to pick up a relay and do it right the first time. How do you suggest I split the wires coming from the relay?
  6. Sep 7, 2016 at 10:17 PM
    03f5sp
    Bill
    Wisconsin
  7. Sep 7, 2016 at 10:58 PM
    kn61408
    kn61408 Retired old fart
    western washington
    09 PreRunner DCLB sport pyrite mica
    12v always on power point mod, tailgate anti-theft, Addl bed tiedowns, flyzeye dash lights, map lites with dome lite mod, bed stiffeners, air bags, brake controller, always on fog lights,
    Best way is to solder the wires, the less connections the better. That means strip the ends off of the wires going to the lights, twist them together as one, slide on heat shrink tubing, then solder them to the relay terminal and slide the heat shrink down to cover the connection. Sorry for the long wait for a reply, forgot to hit "post reply" button:cool::rimshot:
  8. Sep 7, 2016 at 11:12 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    do not wire them in series, eventhough they arent like an incandescent, you still get voltage drop. meaning the farther down the line you go, the dimmer they will get.
    they need to be wired in parallel.
  9. Sep 7, 2016 at 11:37 PM
    03f5sp
    Bill
    Wisconsin
    Thanks guys. I'm in the process of wiring them per 2.7taco's instructions in parallel.
  10. Sep 8, 2016 at 1:41 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Series circuits will have a voltage drop across each load.
    The lights get wired in parallel to the hot and the ground so they get the 12 volts to each. The switch gets wired in series with the hot and the fuse feeding the switch.
    I wouldn't solder to the relay personally, insulated sta-kons and dielectric grease will keep any corrosion out. I'd also just twist the wires feeding the lights and put them into a sta-kon.
    Connecting to the lights themselves, I'd use a 2 pin connector similar to a 4 wire trailer connector soldered and shrink tubed. Individually and overall. You will see that one red wire has the pin exposed, attach that half to the light. Stagger the solder joints, so that it doesn't look too pregnant. Use #18 gauge appliance,"zip" cord. Now look at and feel the cord; one side will have ridges or maybe a squared corner. In the electrical trade, "the grounded circuit conductor," must be identified, and that's how they do it. Here, it's an easy way to keep track of the wires without labeling each and every one.
    Use an add a fuse. Fuses are not there to protect what you're connecting to them as much as they are to protect the wires from over heating and breaking down the insulation.
    On that note, if you decide to forgo or do something different... The following is a true story I'm so glad it wasn't me. Going back a few years, a friend bought a new car and about 1200 watts of amps, speakers, head unit. Nakamichi, a/d/s, Alpine, he spent a chunk of change. He had everything but the fuse blocks and was in a hurry to get his car back together and hear his new toy. He didn't think anything of the sparks when he vise gripped the wires for the amps to the positive battery terminal. When he put the back seats back in, he pinched the wires. When he climbed in, he smelled something burning.The wires were burning through the rug and back seat. Nice black lines where he ran the wires along the drive shaft hump.
    Don't forget the fuse! 5 amp for those light will be plenty.
    Be cool, be safe, good luck and enjoy the final product.
