Ditch lights stolen, Any anti theft hard ware?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SailinTacos, Dec 18, 2023.
  1. Dec 21, 2023 at 5:39 PM
    #61
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I can't be the only one thinking another ser of cheap lights and a rifle......
  2. Jan 3, 2024 at 1:20 AM
    #62
    SailinTacos
    SailinTacos [OP] Well-Known Member
    2018 Black Tacoma TRD Off-Road
    I don’t live in any type of dangerous or high crime area, i mean anything can happen. Was just asking a simply question but you got your panties in a twist.
  3. Jan 3, 2024 at 1:22 AM
    #63
    SailinTacos
    i use mine every single day, so i wouldn’t say useless
  4. Jan 3, 2024 at 1:24 AM
    #64
    SailinTacos
  5. Jan 3, 2024 at 3:08 AM
    #65
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Taking this comment with a grain of salt because locational area not disclosed. The county I live in has 3 towns/cities but you go 1 mile and your in the woods. So city slicker comment not valid.
    Good for you using them every day. Like I said in my 1st post someone you know or they live in your close area.
    Sorry this happened to you.
    I look forward to seeing your resolution to your predicament.
  6. Jan 3, 2024 at 7:59 AM
    #66
    SailinTacos
    I live in the same type of area, i just welded them on in the places i needed them to be so if someone wants them it’s going to be a lot harder, plus i got some cameras set up but definitely looking for a garage
    Tiedie[QUOTED] and wilcam47 like this.
  7. Jan 3, 2024 at 9:23 AM
    #67
    TheDanimal
    TheDanimal Well-Known Member
    Daniel
    DFW
    2024 Silver TRD OR 6MT 2019 MBM TRD OR 6MT (RIP)
    How did you know they tried to take your Cats?
  8. Jan 3, 2024 at 10:08 AM
    #68
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    Swap all your hardware out with anti-tamper torx hardware sometimes that will deter it. Although I've seen where they mess up the persons hood and fender and just bend the bracket back and forth till it snaps off.
  9. Jan 3, 2024 at 10:30 AM
    #69
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    OP sorry. Did you email the landlord and or post on the facebook community page? You need to put this in writing (emails to the landlord) in case it gets worse and you have to leave the complex. My friends had lots of their stuff stolen at their APT complex & it got so bad, they got a lawyer & got out of their lease. They had good documentation in case the APT wouldn't let them out of their lease. Did you file a police report? Do you have any documentation that this happened? I'd start because its going to happen again & it's time for you to move out of that shitty complex!!!
    If you get a negative response from the APT company, then turn to google and tell ppl online that this is not a good place to live. That is always helpful
  10. Jan 3, 2024 at 2:47 PM
    #70
    mattsolnitzky
    mattsolnitzky Well-Known Member
    2021 TRD Sport
    Put a blob of JB Weld on the nuts/bolts. Certainly not fool proof, but makes it hard to get a wrench on it. Sometimes just simply making it annoying like that is enough to get someone to leave it alone.
  11. Jan 3, 2024 at 5:51 PM
    #71
    Pinatacoma
    Pinatacoma Well-Known Member
    Vancouver Island, BC
    2020 ACOR
    I've been looking for creative solutions to make some mostly side-facing light and for this and other reasons have avoided the ubiquitous "ditch light" brackets. There are some nice alternatives highlighted in this thread so far.
    I have an access cab, and was thinking maybe there's a way to stick a light on the back door WINDOW from the inside, with a shield around the works to keep light outside. I haven't checked if there's existing wiring in these doors, but I doubt it. This could complicate wiring for lights. The windows are fixed, so no worries about when they open like on the double cab.
    Thoughts on this?
  12. Jan 3, 2024 at 6:03 PM
    #72
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Those tamper torx aren’t much of a deterrent, you can find the hollow torx bits in just about any hardware store which means if the thief has a hex wrench/allen then they probably have those security torx bits. That or I’ve heard a thief can just fit a slim flathead screwdriver in the angle between two of the Torx corners on those and twist the hardware.
    Chew and Pinatacoma like this.
  13. Jan 3, 2024 at 6:19 PM
    #73
    Pinatacoma
    2020 ACOR
    Agreed 100%
    I have a pretty complete set of "security" bits that get me past almost all of those "no user serviceable components inside" stickers. Most often, these are the MOST serviceable. They're just trying to protect their intellectual property.
    One-way fasteners are a different story, I think. You often see these on restroom divider structures.
    Complete PITA if _you_ ever want to remove them though. I'd use a generous amount of permanent Loctite along with it to deter the use of vice-grips, though the rounded head and stupidly tight will probably make it almost permanent without anything else.
  14. Jan 3, 2024 at 6:27 PM
    #74
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
  15. Jan 3, 2024 at 6:30 PM
    #75
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    The only t-55 bit at my hardware store was a security bit.
  16. Jan 3, 2024 at 6:34 PM
    #76
    Pinatacoma
    2020 ACOR
    TacoJoeBro[QUOTED] likes this.
  17. Jan 3, 2024 at 6:42 PM
    #77
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    If you’ve got the tool, you can cut the brackets, no fasteners will help.
    Pinatacoma likes this.
  18. Jan 8, 2024 at 9:06 PM
    #78
    TacoTuesday1
    SD CA
    would cheap ones be useful?
    -easier to buy
    -less incentive to be stolen
    -easier to replace
    I see similar slim yellow ones on Amazon around $35 with good reviews
    auskip07 likes this.
  19. Jan 9, 2024 at 5:12 AM
    #79
    sb0623
    sb0623 Well-Known Member
    DFW
    2022 Toyota Tacoma TRD Sport
    Limo tint, hitch step, grill guard, chrome running boards, running board lights, bed cover, dash cam, interior LED bulbs, MBRP cat back dual exhaust w/chrome tips, MillerCAT cat shield
    If you add a Viper alarm, they won't get very far without setting it off.
  20. Jan 9, 2024 at 5:56 AM
    #80
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I have these in amber. They are cheap they work relatively well for the size.
