Ditch Lights Worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kgarrett11, Aug 16, 2016.
Would you do ditch lights again?
  1. Without a doubt! They kick ass
    129 vote(s)
    49.2%
  2. Most likely, they are ok
    66 vote(s)
    25.2%
  3. Ehh probably not
    36 vote(s)
    13.7%
  4. No, wate of time, money, etc...
    31 vote(s)
    11.8%
  1. Aug 16, 2016 at 10:05 PM
    kgarrett11
    kgarrett11 [OP] Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I'd like to open this up for a general ditch lights discussion, since I've been thinking about installing them recently. I already I have a couple of lightbars but looking for more light on the sides. Do these put out a lot of light? Spots or floods? Do they stick out so much that they block vision while driving? If you have these I want to hear your opinion!
  2. Aug 16, 2016 at 10:18 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,YOKAHAMA MT'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
    I just ordered the CBI brackets along with the ROUGH COUNTRY BLACK SERIES pods. Im going to install this weekend, but the brackets dont look like they obstruct vision while driving.
  3. Aug 16, 2016 at 10:36 PM
    LXAbuckeye
    LXAbuckeye Well-Known Member
    Nick
    Cleveland/Columbus
    2008 Tacoma TRD Offroad
    3 inch OME lift, BFG All-Terrains NWTI front plate bumper, KC LZRs mounted on Relentless Fab mounts, color-matched 2011 honeycomb grille, Spyder halo headlights, Depo LED tail lights, 2012 A/C and heater controls, 2012 touch screen headunit
    I had a set of Osram 3 inch pods and just changed them out to 4 inch KC LZR lights on CBI brackets. They really don't obstruct/interfere at all, and the light output for when you're off roading at night is absolutely worth it
  4. Aug 16, 2016 at 11:15 PM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    Yes
    Spots
    No
    I have Rigid D2 Spots with the smoked lenses.
    I have Relentless Fabrication mounts.
    I installed a Mictuning Factory-style push switch in a blank on my dash.
    I like them very much.
    I have mine pointed straight forward right now, because I'm upgrading my electrical system prior to installing the big bar above my windshield. I will angle them to cover any dark spots in my new pattern once I install the big bar.
    They completely overtake my stock headlights when I use them, but I only use them off-road; because I am not a dickbag who uses his offroad lights while on a normal road, which as reflectors and shit on it.
    I'll post a pic of the view I have from within the cab after I get some sleep.
  5. Aug 16, 2016 at 11:43 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    The light on the side is flood ditch lights pointed out so they shine into the turn before I get there. Very useful for me.
  6. Aug 17, 2016 at 3:45 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    I use spot pattern, Cheapo auxbeam and they throw more light than my headlights on hight beam.
    They're not in my line of sight because I chose cbi ditch light brackets, they sit behind windshield pillars.
    THROTTLE231 likes this.
  7. Aug 17, 2016 at 5:27 AM
    Flannel_Lover
    Flannel_Lover Your resident questionable advice giver
    Lucas
    Greenville, IN
    2011 sclb base 4x4
    Alpine component speakers Rockford Fosgate 10" sub Pioneer DEH-X6800BT Kicker CX 300W amp Extang Trifecta Big Country Brush Guard
    I've been thinking about getting some to compliment my 23" on my brush guard. Just to get more spread on back roads
  8. Aug 17, 2016 at 5:29 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    love the extra side lighting and not in my way driving at all. SOS makes some brackets too, no cutting of shroud needed.
  9. Aug 17, 2016 at 8:37 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Pics when you get em!
    Floods?
    Straight to the point, I like that. I will definitely be using the same switch. Pics would be much appreciated!
    Ya i most definitely have enough light straight ahead... these puppies are gunna be sideways for sure. That pic might have done it for me thanks!
    Thanks guys, glad to hear it isn't in the line of sight much
    ChadsPride likes this.
  10. Aug 17, 2016 at 8:43 AM
    LunaticConcepts
    LunaticConcepts Well-Known Member
    Georgetown, TX
    2015 Tacoma TSS
    TC LT, Kings, OME, Billies, ARB, stuff
    I run a set of TWF pods on Relentless brackets. Love em, one of the first mods I did to the truck.
  11. Aug 17, 2016 at 8:45 AM
    LunaticConcepts
    Georgetown, TX
    2015 Tacoma TSS
    They sit good too
    TacoDoe858 and ChadsPride like this.
  12. Aug 17, 2016 at 8:57 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Problem with ditch & light bars is how quick they disappear off your truck when you park at places other than your house.
    Light bars behind bumpers are a better investment.
  13. Aug 17, 2016 at 9:04 AM
    Wiggins
    Jacksonville
    How would OP put ditch lights behind his bumper?
    It would be super frustrating to get your shit stolen, but that's not the topic of this thread.
  14. Aug 17, 2016 at 9:10 AM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    I love mine. CBI brackets with Baja Designs Spots. I get comments all the time at the gas pump or fishing hole about them; they work as advertised. No glare but I drive a black 04. I understand there may be a bit more glare on different colors but wanted something that augment the headlights and function if I lost my headlights (offroad hit, malfunction, et). Youll love em
    Yes they put out great light, they do not stick out (in fact I think CBI went through a slight redesign) and they sit nicely to the sides.
    I used security nuts and bolts for the lights but never had an issue with theft/vandalism. Planning on putting Baja Amber chase lights on my Relentless bar in the bed.
  15. Aug 17, 2016 at 9:37 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    That's what the Remington and Smith n wesson mods are for...:spy:
    Taco Addiction and ChadsPride like this.
  16. Aug 17, 2016 at 9:45 AM
    Taco Addiction
    Houston, TX
    True dat.
  17. Aug 17, 2016 at 9:53 AM
    Jrobertson
    Jrobertson Well-Known Member
    James
    green valley (Henderson)
    2010 Tacoma off road. 4x4
    Stock. For now.
    Made my own brackets for all of about 10$ tops. Really help lighting up the corners going into a turn.
  18. Aug 17, 2016 at 12:40 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    I want to try and get them lined up with the pillar as much as possible as these will be pointed out at a good angle. I've noticed there is a lot of placement differences that have been posted so far...
  19. Aug 17, 2016 at 12:44 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    I've been wanting to do a set of these and I always thought a flood beam would be better. Seems like most of you who went spot, how do you like it and why'd you go spot beam over flood beam?
  20. Aug 17, 2016 at 2:34 PM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    ^^^ What he said!
