Ditch Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RaunchBox, Apr 9, 2018.
  1. Jul 21, 2019 at 5:06 PM
    #81
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I like having ditch lights just not on the hood for me. Even tho they are not quite as bright due to size I really like my stealth mirror ditch lights. :notsure:
  2. Jul 21, 2019 at 6:25 PM
    #82
    Blkdmax
    Blkdmax Well-Known Member
    Tennessee
    2017 DCSB 4X4 V6
    Pics?
  3. Jul 21, 2019 at 6:33 PM
    #83
    20tacoma17
    2017 DCLB Sport AT
  4. Aug 6, 2019 at 6:29 AM
    #84
    HappyGilmore
    HappyGilmore LambTek Innovations
    Huntsville, AL
    2013 SC’d DCSB TRD OR 4x4 | 2012 Lexus IS-F
    Yes
    What lights did you use? Really digging this.
  5. Aug 6, 2019 at 7:02 AM
    #85
    20tacoma17
    2017 DCLB Sport AT
    Thanks, Rigid ignite floods.
  6. Aug 6, 2019 at 8:34 AM
    #86
    sagexp
    sagexp Well-Known Member
    Back home, AZ
    2002 Tacoma DC 4X4 2017 Tacoma DC 4X4
  7. Aug 20, 2019 at 9:38 PM
    #87
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
  8. Aug 20, 2019 at 10:00 PM
    #88
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I thought the S2's are really bright?
    Did you mod that snorkel intake?
    The best one was what safari snorkels made for my old pathy, swept back over the roofline
  9. Aug 20, 2019 at 10:04 PM
    #89
    helix66
    DPRC
    2017 DclB TRDor MgM
  10. Aug 21, 2019 at 1:14 AM
    #90
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    Cali raised brackets and rigid SRQ2’s
  11. Aug 21, 2019 at 10:18 AM
    #91
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    helix66[QUOTED] likes this.
  12. Aug 21, 2019 at 11:21 AM
    #92
    Dornbox
    Dornbox Brrrrrap!
    Maine
    Cement 2019 TRD OR
    TRD Pro Hood
    That is one clean install! Who or how did you cut those out of the mirror backs? They look perfect like they where done on a water jet and re sprayed. I need to know! :spending:
    helix66 likes this.
  13. Aug 21, 2019 at 12:19 PM
    #93
    sagexp
    Back home, AZ
    Here's the original thread by robmpii.
    https://www.tacomaworld.com/threads/mirror-mounted-baja-s2-diy.599067/page-2#post-20915027
    Took a bit of detail work, won't lie. Rob got his to fit tight and look right with the use of body filler. I was not as confident in my abilities to work with that, so I scribed out my cuts, opened a rough cut, then worked carefully out from there with small Dremel on slow speed and hand files. Actually worked out good because once I was close I just relaxed with the Dremel and files and took it slow and careful until they fit just the way I wanted. Thanks to his work, I knew where the cut outs had to be, so other than time, patience, and a steady hand, it wasn't all that difficult.
    Dornbox[QUOTED] likes this.
  14. Sep 13, 2019 at 5:52 PM
    #94
    patdeezy
    patdeezy Well-Known Member
    souLcaL
    '19 OR 4x4 SuperWhite DCSB
    which SRQ2 model did you get? Hyperspot or spot?
    Thanks! Those lights look good!
  15. Sep 13, 2019 at 6:49 PM
    #95
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Game wardens in these parts go bonkers if they see folks using these in the forest and they have a bow or firearm in the truck. They suspect you might be jacklighting game.
    Therefore I pass. They would be nice to use though.
  16. Sep 14, 2019 at 3:46 PM
    #96
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    What kind of bed rack are you running there? Looks good
  17. Sep 14, 2019 at 5:01 PM
    #97
    Mad Mark
    18 TRD 4x4 off-road
    They’re driving pattern.
  18. Sep 14, 2019 at 5:11 PM
    #98
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
    Yakima overhaul hd
    crazyfingers[QUOTED] likes this.
  19. Sep 14, 2019 at 5:15 PM
    #99
    crazyfingers
    Chuck
    Annapolis, MD.
    How much did it set you back?
  20. Sep 15, 2019 at 6:19 AM
    #100
    ATXJoshL
    ATXJoshL Well-Known Member
    Josh
    2018 Tacoma TRD Pro Black
    1-1/4” Spacers, Tires: Goodyear Wrangler Duratrac, hard bed cover, Fuelpax custom-mounted on bed rail.
    That’s 1 thing I really like about the Caliraised brackets, they’re low profile. Everyone else’s stick up pretty high.
    Nothing wrong with cheap pod lights. If you’re happy with the light output, who cares. The issues you might have past that is eventually the clear plastic will yellow and they might leak.
