Diving into Home Brewing
Discussion in 'Homebrewing' started by Mr Souc, Jan 1, 2015.
  1. Jan 1, 2015 at 5:30 PM
    Mr Souc
    Mr Souc [OP] Well-Known Member
    Joel
    Topsham Maine
    2011 Tacoma TRD Off Road
    - TacoME Satoshi - Hella Supertones - TRD front skid plate - TRD CAI - TRD cat-back exhaust - TRD short throw shifter - TRD 6 speed ball knob - Baja Soft 8 16" wheels - 285/75/16 BFG T/A KO2s - Pioneer AVH-P2400BT - OEM roof rack - Thule Aero roof rack - TSB Add-A-Leaf - 1" Level spacer up front - 5100s front & rear - Eibach 620lb coils - Toytec 2" add-a-leaf - Plasti-Dip bumper, badges, & roof
    Happy new year everybody!
    For the last few years I have been enjoying local beers from all these local breweries that have begun to pop up around my area. There have been 4 or 5 that have popped up at the in the last two years in the Portland Maine area that have done real well for themselves and are brewing some stellar beers. I have been inspired by this and all these awesome beers I've tried, I decided I want to try brewing my own at home. It's always been something I wanted to do but never thought I had the space, time, and honestly I've been a little intimidated by it. I have been reading, researching, and even visited several local breweries to soak in some information and inspiration and I'm gearing up to take the plunge.
    I wanted to reach out to the collective knowledge base here on the forms and ask for some advice or just simple tips from folks who have done it before. Should I start out with just getting a homebrew kit from an outfit like Austin Homebrew Supply and buy the ingredients separately? Or maybe just buy a complete kit for my first batch to feel it out?
    The space I have to work with is very limited as we have a very small house. We do have a small crawlspace downstairs but it's not exactly livable space and its mostly used for storage. Can I use the crawlspace basement that's not the most ideal climate for the fermentation process? Also, it's the dead of winter here in Maine too so I will have to keep my outdoor boiling activities to nice sunny days as I don't have a garage either. Should I be worried about colder temperatures or just wait for nicer weather?
    Any tips, advice, online suppliers, or just general words of wisdom are appreciated as I take the plunge into what I'm guessing might become my new favorite hobby!
    Thanks in advance and cheers!
  2. Jan 1, 2015 at 5:49 PM
    sbates
    sbates Well-Known Member
    NJ
    2011 Tacoma TRD Sport Double Cab
    Extang Tonneau Cover, aFe Pro Dry S air filter, Weathertech Floormats, De-badged, Plasti dipped Toyota emblem black, Plasti dipped a/c control panel black, 48-led Dome Light, Tailgate Damper,
    I have about 15 home brews under my belt so far. If you're just starting out I would suggest one of the all in one brewing kits from northern brewer or Austin homebrew supply. It will include everything you need to start brewing (minus a kettle). Tubing, sanitizer, capper, fermenter, bottling bucket etc. A small stainless steel kettle will do the trick (about 4 gallons). As for a beer kit, start off with one of their basic kits to get the feel of how the brewing process works. I'd actually suggest using several of those kits before deciding on making your first custom brew. My first was a basic IPA and it's still one of my favorite brews I've made. Ale fermentation needs to take place at a constant 68-72 degrees. I wouldn't suggest putting anything in your crawl space. Putting a 5 gallon fermenter in a closet has always worked well for me. Basically anywhere that's dark and keeps a constant 70 degree temperature. Lagers are a completely different story because they utilize cold fermentation. I wouldn't attempt those unless you had proper equipment.
  3. Jan 2, 2015 at 2:04 PM
    Mr Souc
    Joel
    Topsham Maine
    Thanks for the reply! I appreciate it! Sounds like I might be better off waiting for the spring and warmer weather to roll around before I jump in. The temp of our house fluctuates from 62 to 70 during the winter months and that doesn't sound conducive to fermentation. I think I will read up and shop around and at least get all my equipment and supplies lined up during the winter months. That way I can hit the ground running come the thaw!
  4. Jan 2, 2015 at 2:19 PM
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    I agree with getting a "Beginners Kit" for equipment that'll have most of the hardware you need. Retailers that I use often include Northern Brewer and Midwest Supplies -- both often have deals on such kits.
    For your first brew... maybe your first dozen... I'd also recommend an "extract" ingredient kit from same suppliers. All the ingredients for a proven recipe in one box that you can do on a stovetop. Extract kits use... wait for it... malt extract, which is in syrup or powder form. It's an alternative to "full grain" kits where you get a bag of malted grain and need to mash it yourself. A worthy experience for sure, but not for beginners -- and it needs a lot more equipment.
    Three tips I often give new brewers:
    1) Clean, clean, clean, sanitize... then clean some more and sanitize again.
    2) Don't be disappointed if your first batch needs to go down the drain due to nastiness, it happens, learn from it.
    3) When you open that last bottle from your first drinkable batch... it's time to open the first one. Very easy to be over-anxious and start "sampling" before it's quite ready. That last bottle will likely be the best one!
    OH! One last thing... I've an uncle in Mass. who got into brewing thru a local supply shop who did group brewing. Wasn't so much a class, as a group event where you can go brew, and learn, and use the shop's equipment. Something to look into before laying out a pile of cash for gear.
    Good luck!
  5. Jan 2, 2015 at 2:30 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    Its a ton of fun. Th wife and I use to brew together all the time then kids happened.
    Like stated earlier, besure to clean everything very very well.
    watch your fermentation temps and don't take shortcuts. You will taste it. I know people that have skipped the step of checking the gravity before and after and sometimes, the beer is not done, even though it has "stopped burping".
    Have fun and experiment. Your pallet will grow as you start to understand how small changes in the brew, make big changes in the taste.
  6. Jan 14, 2015 at 7:44 PM
    Jib Bandits
    Jib Bandits Pork eating crusader. An "infidel".
    Ari
    Cedar Fort, UT
    06 Access TRD Sport
    Red devil horn emblem, All-Pro Expo leafs, Fox shocks, K&N CAI, aFe throttle body spacer, Flowmaster american thunder dual exhuast, Defender roof rack, Hell Bent steel level kit, Rigid Dually LED lights, smoked halo headlights, smoked LED taillights, Cobra CB, red badge mod(+30 HP), Spider-Trax wheel spacers!
    Once you start brewing your own you won't look back! a bit redundant at this point, but yes; I'd recommend a starter kit and start with 2-3 gallon extract boils and a brew bucket, then step it up from there as you get more interest and love for the hobby. as far as space goes, don't worry! I'm doing 5-10 gallon all grain batches in a 2 bedroom apartment haha. and if you have trouble with steady ferment temps, just wrap your fermenter in a sweater, jacket or wet towel to help regulate temps.
    oh and check out The Brewing Network, an amazing resource for homebrewing! good luck and keep us updated
  7. Mar 10, 2015 at 5:41 PM
    hamburglar
    hamburglar Swollen Member
    Oregon
    Taco Supreme
    many
    As long as your water hose isn't frozen its brewing weather! I'm in Oregon and it rains all the time so I brew in the garage. The late summer months are the hardest as it can be difficult to cool things down to correct temps and to keep them there.
    Stable temps are the most important, you can search around for different yeasts that can fit the environment. There are ale yeasts that can take 55F and others up to 74F or so. Lager yeasts can go down to lower 40's and still be effectively making your booze.
    How to brew by Palmer is a book for a good understanding of all things beer. So is brewing classic styles by Jamil Zainasheff (mentioned by Jib Bandits on Brewing Network). Their radio shows are pretty funny when they record 2 back to back and drink too much in the process.
  8. Mar 24, 2015 at 2:30 PM
    Mr Souc
    Joel
    Topsham Maine
    Thanks for all the responses! I'm happy to report that my wife got me nice home brew starter kit complete with a 6 Gallon gall carboy for my 30th B-day last week. Super pumped to give it a go! I have been reading up and talking to the folks at the local brewing supply store and feel I have a good handle on things.
    One ice fishing season ends, I will have to make my first batch! Thinking of calling it "Cellah Watah" or "Sump Pump Ale" in honer of spring in Maine.
    Cheers, and I'll be sure to keep you posted!
  9. May 17, 2016 at 5:38 PM
    cgm
    cgm Well-Known Member
    NBPT, MA
    2014 TRD Sport 6 Speed DCSB
    Did you brew yet?
    I really need to brew another batch or two soon!
