Dixie Horn- Wiring Help?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tomatosouptaco, Jul 26, 2017.
  1. Jul 26, 2017 at 1:57 PM
    tomatosouptaco
    tomatosouptaco [OP] Active Member
    Jimm
    2017 OR DBCB - inferno
    I got a Wolo dixieland horn for the Tacoma and mounted it and ran the wires through the fire wall. I then bought a CH4x4 Tacoma switch to put in the shapeway cubby replacement insert next to my light bar switch.
    The horn works by interrupting the ground to stop the compressor.
    https://wolo-mfg.com/media/wysiwyg/pdfs/specialty_horns/Eng5horn.pdf
    The CH4x4 doesnt seem to be designed this way.
    I'm not sure what the best way to hook it up is. Any help would be appreciated.
  2. Jul 26, 2017 at 2:07 PM
    SRQ_TACO16
    SRQ_TACO16 Well-Known Member
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    Had one of these in my 77 Camaro however it was just wired with the switch it came with. Just a bit of warning it worked for about 2 months then the little motor broke... Was fun while it lasted. Why not just use the switch it came with and mount it under the dash?
  3. Jul 26, 2017 at 2:20 PM
    tomatosouptaco
    Jimm
    Yeah it doesn't seem like its built to last, but I would still prefer to not to put the autozone button on the truck ( even if i cant see it)
  4. Jul 26, 2017 at 2:26 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I cannot recall exactly how I did it but I used a similar horn and a similar switch in my dads tundra
    I don't have the wiring drawings I did, but ultimately I had to try a couple different ways until switch would light up, momentary would play the horn as long as it was pressed, and horn would stop when button was released
  5. Jul 26, 2017 at 3:08 PM
    SRQ_TACO16
    David
    Sarasota, FL
    2008 Tacoma
    3rd gen SR5 wheels
    I didn't like that button either, but didn't seem to mind it if I couldn't see it. I feel like most switches designed to snap into those slots aren't going to act the same way.
    I think you should be able to still use one you would just push it once to have it on then push it again to turn it off not hold the button? I'm not the best with wiring though...
  6. Jul 26, 2017 at 4:51 PM
    JimBeam
    JB
    2015 Tundra
    You can find oem style momentary switches that function the same
