DIY 1st gen angle iron Bed/Light Bar
Discussion in '1st Gen. Tacomas (1995-2004)' started by geoff06, Mar 24, 2011.
  1. Mar 24, 2011 at 7:37 PM
    geoff06
    geoff06 [OP] 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    Well, I completed my project for a total of about $50. This is my first writeup, so please bear with me
    Necessary for this project are--
    -6' length of 2x2" angle iron
    -2 6" stainless handles
    -2 3/8" dia. bolts/nuts
    -4 3/16" bolts /washers/nuts
    -power drill with a 3/8" and 3/16" metal cutting bits
    -sawzall
    -right-angle grinder
    -a pair of 55w fog lights (or any other aftermarket lights)
    I started out with buying a 6' angle iron
    I next measured and cut the angle iron to fit the width of the entire bed top (60.5”—it almost reaches to the outside of my drop-in bedliner on each side). Then I notched out a 3.25” section on each side of the bar with a sawzall. Used a grinder to smooth/even out the cut area.
    Then I dryfitted the angle iron to see what I was up against with the position of the future mounting holes
    Next, it was time to drill the holes. I initially felt around under the top of the bedsides at the front of the bed and realized that there was an opening in the “inner” element of the 2-piece bedside. I used this as a starting point for where to drill the mounting holes in the bedsides. I drilled one 3/8” hole on each side exactly 4-3/8” back from the front edge of the bed.
    After drilling the bed holes, I drilled 5 3/8” holes in the top of the angle iron. 2 mounting holes—1 hole 1” in from each side. 2 holes for mounting my 55w fog lights—1 hole 6” in from each side. And finally 1 hole about 1’ in from the left side for mounting my CB antenna later down the road. Then I drilled the 4 3/16” holes to mount the handles in the rear facing edge of the angle iron.
    Next, I sanded the bar down with 220 sandpaper, then sprayed the bar with Duplicolor Truck Bed Coating.
    After the bedliner spray had cured, I mounted the lights and handles on it. To ground the lights, I found it convenient to just have the built-in ground wire ends bolted to the bar on the outermost handle bolts. After everything was tightened up, it was time to mount the bar to the bed, using the 3/8” bolts. I held each nut in a socket extension in a bedliner opening just under the bed holes so I could put the bolts through without losing anything under the drop-in liner.
    Now time to wire everything up. First I used about 3.5’ of wire with an inline fuse, leading from the engine bay fuse box through the firewall to the switch (I put this switch next to my aftermarket front light switch in my in-cab fusebox cover). 12’ of wire leading from the switch to the drivers side bed light, running back through the firewall, down near the transmission area, along the frame through openings in the bodymounts, and in between the cab/bed with a “Y” terminal at the end (I put this run in a ridged plastic sleeve to protect it from the elements). 4’ of wire from drivers side light to passenger side light.
    Here’s my colorful switch setup
    And that’s pretty much it. I’m happy with the outcome, as the whole bed bar/light setup doesn’t draw too much attention to itself. Can be used camping, emergency situations, running tailgaters off the road…(JUST KIDDING!)
    Thanks for reading!
  2. Mar 24, 2011 at 7:40 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    pics are uhh... :confused:
  3. Mar 24, 2011 at 7:46 PM
    geoff06
    WI
    fixed. can u see em now?
  4. Mar 24, 2011 at 7:54 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    :thumbsup:
    Nicely done!
  5. Mar 24, 2011 at 9:44 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
  6. Mar 24, 2011 at 9:47 PM
    stevenstaco
    stevenstaco B A N N E D
    steven
    sacramento ca
    o7 trd sport sr5 4x4/06 4runner sr5 4x4
    1.5 aal,Tacomaworld sticker,Blacked out tail lights,bhlm,.dumped exhaust,relocated 7 pin ,rear diff breather mod,bed lights,hella 500s behind the grill,plastidipped lower vallance,mag light mod,debadged,black billit grill,bedmat mod,airaid intake,vynil armrests and back rests,tailgate theft mod, ipod interface,backseat cargo mod,front 5100s
    looks good ...gotta love ange iron:D
  7. Mar 25, 2011 at 7:57 AM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    I like that a lot. Unfortunately I just got a new camper so I won't have any use for this really. Had I not have just bought the camper, I would be doing this today.
  8. Mar 25, 2011 at 10:48 AM
    geoff06
    WI
    thanks guys!
  9. Mar 25, 2011 at 10:50 AM
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Ha... I am doing the same thing! Nice wripte up and pics!
  10. Nov 24, 2011 at 9:42 AM
    geoff06
    WI
    A note to anyone who might make this bar for their truck:
    I'm sure most of you will realize that only one mounting bolt per side is not enough to make this thing very stable and usable. A couple months after I made this, I installed an additional mounting bolt on each side. It is way more usable now and solid as a rock
  11. Feb 15, 2012 at 2:25 PM
    TacoSurf4x4
    TacoSurf4x4 Well-Known Member
    Seal Beach
    4x4 board truck
    3 inch lift
    Great write up! simple and informative...
