diy 2001 shock replacement help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shikkapow, Jan 14, 2010.
  1. Jan 14, 2010 at 8:38 AM
    Shikkapow
    Shikkapow [OP] Active Member
    Sunny Florida
    01 sr5 4x4
    Is there a DIY somewhere for replacing shocks/ struts on a 2001 4x4?
    Mine has 130k miles and AFAIK it still has the original parts.
    the rear seems straightforward, but the front struts are just a tad beyond what I have ever done before.
    Recommended parts?
    Im going to keep the ride height the same.. no reason for me to change it
  2. Jan 14, 2010 at 8:41 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Just the shocks. The rears are a simple two bolts and they are out. The fronts require you to remove the coilover assembly. You can take both assemblies to a shop and have them swapped out for you for around $40. Or you can DIY if you have access to a spring compresser.
  3. Jan 14, 2010 at 8:46 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  4. Jan 14, 2010 at 9:05 AM
    Shikkapow
    Sunny Florida
    01 sr5 4x4
    oh... so you CAN replace just the shocks. I have access to (the neighbors) spring compressor and technical knowledge. so I'll just go that route.
    I dont think I need to replace the springs. she's been 90% on road, and only off road in the sand, so not a whole lot of wear and tear on the suspension other than mileage.
    Thanks for the links!
  5. Jan 14, 2010 at 9:06 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No problem. :thumbsup:
    Good luck and becareful compressing those springs.
  6. Jan 14, 2010 at 12:27 PM
    Shikkapow
    Sunny Florida
    01 sr5 4x4
    Any preferred brand?
