DIY 270 Awning for Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by davzx, Nov 22, 2021.
  1. Dec 1, 2021 at 7:29 AM
    #41
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Can't wait to see it!
  2. Dec 1, 2021 at 7:43 AM
    #42
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    Agreed. Very cool and looking forward to more pics/info. Thanks.
  3. Dec 9, 2021 at 7:21 AM
    #43
    davzx
    davzx [OP] Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Got the materials for the bag yesterday, only took 1.5 hours to make.
    Should be good to mount it up this weekend. I’ll follow up with a more thorough process.
  4. Dec 9, 2021 at 4:52 PM
    #44
    nanserb
    Elliott
    2019 ZR2 Colorado
    Awesome! What material is it and where did you get it from?
  5. Dec 10, 2021 at 7:46 AM
    #45
    davzx
    CO
    18oz. vinyl coated polyester from Rockywoods. It's pretty hefty and rigid - really easy to cut and fold a straight line. I used a 100/16 (medium-heavyweight) needle in my sewing machine with ease. I ordered 3 yards, which can easily make 2, potentially 3 bags total (61" width, and this bag is cut at 21" before hemming). You could make a bag out of 1 yard with a lateral seam in the middle to reduce costs.
    https://www.rockywoods.com/18-oz-Vinyl-Coated-Polyester-Fabric-Black
    I used a #10 coil zipper. Didn't think waterproof was necessary, as it's on the underside, and I don't really care if residual water gets in. The #10 is very easy to pull - it's not as sensitive as the #5s on the wedge tent.
    SR-71A likes this.
  6. Dec 10, 2021 at 7:52 AM
    #46
    nanserb
    Elliott
    2019 ZR2 Colorado
    Was the pattern pretty simple?
  7. Dec 10, 2021 at 7:54 AM
    #47
    davzx
    CO
    Oh yeah. Just a rectangle cut at 21" x 104"(?) with 1" hems all around, so the finished bag is 19" x 102".
    Left side is the raw edge - made a line 2" in to fold to for a 1" hem. Right side has been basted.
    After Hemming all 4 sides, I basted the zipper on - the tape adhesive backing is removed under the material, just left the ends attached.
    Folded around and basted the other half.
    Only after basting both sides, I separated the zipper and stitched them in place. Once the long edges were stitched, I zipped up the bag to baste the short tails of the zipper up the ends. Then again separated the zipper to stitch those short runs. I didn't order enough zipper - ideally those would have gone up the side completely, but what I have will do.
    M61guru likes this.
  8. Dec 10, 2021 at 12:48 PM
    #48
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I know a lot of folks like plastidip but I'm not impressed with it, especially if there will be any contact as it'll rub off. If you want to go inexpensive, look at using appliance epoxy paint and just make sure you do a good prep then let it cure for the recommended time.
  9. Dec 10, 2021 at 12:52 PM
    #49
    davzx
    CO
    Haha, yeah. I did go all the way with Plastidip and regret it - contact points suck. I may attempt to strip it and go with your recommendation. I should have just gotten a quote for powdercoating.
  10. Dec 10, 2021 at 1:03 PM
    #50
    Bajatacoma
    SC
    I figure if the cheap bastards who built AKs like the stuff it must hold up pretty well. :anonymous: The inexpensive spray on bedliner sucks in my experience as well. This past summer I'd planned to blast the roof basket I made (since the paint I used isn't holding up) and try the appliance paint but I forgot about it.
    When I had my sliders powder coated I dropped them off and told them I was in no hurry, just do them whenever they did another run of black so they shaved a little of the price- always worth asking.
  11. Dec 11, 2021 at 7:47 PM
    #51
    davzx
    CO
    Took me about an hour and a half to peel all the Plastidip off. I was dreading it a bit, but it wasn't terrible. I left the two 8020 brackets on the wedge with the dip, but everything in the bag is epoxy now. Also gave me the opportunity to weld on my tabs to the popup arms, as they were bolted initially. That appliance epoxy recoats super fast, which was great - 3 coats a few minutes apart. Should be able to finally mount tomorrow if all is cured.
    Thanks for the suggestion @Bajatacoma
  12. Dec 12, 2021 at 8:47 AM
    #52
    Bajatacoma
    SC
    Cool, be interested in seeing how it holds up. I've read on AKfiles where it's held up even under the selector switch when it's been baked after application so I'd say that's a pretty good indication.
  13. Dec 12, 2021 at 5:59 PM
    #53
    davzx
    CO
    Still have to finalize the attachment points on the two corners not attached to the arms, but it’s on!
    50Buck, M61guru, sdshack and 4 others like this.
  14. Dec 14, 2021 at 7:40 PM
    #54
    nanserb
    Elliott
    2019 ZR2 Colorado
    Legit, strong work!
    I'm hoping to tackle the awning in the spring, and make a pattern for the canvas. I'll share when that happens.
    sdshack likes this.
  15. Dec 15, 2021 at 4:08 PM
    #55
    asanelli
    asanelli Well-Known Member
    Tony
    Golden CO
    3rd Gen Tacoma TRD Offroad
    wow crazy I use to be your neighbor. Nice looking rack.
  16. Apr 2, 2022 at 4:31 PM
    #56
    nanserb
    Elliott
    2019 ZR2 Colorado
    So after using it for a bit, how would you say it has done?
    Anything you'd change?
  17. Apr 2, 2022 at 5:17 PM
    #57
    davzx
    CO
    I haven’t used it at all in any real capacity. I’ve just opened it up a few times to show people, and a couple times for a few minutes. But it blocks the sun so, I guess pretty good? I know it won’t be great in the wind, but that’s mainly because of the tarp I used. Once this tarp tears a bit, I’ll sew a new one from something heavier duty. Tarp was good as a proof of concept, but ideally it’s not the long term solution.
  18. Apr 2, 2022 at 6:07 PM
    #58
    nanserb
    Elliott
    2019 ZR2 Colorado
    I purposefully ordered a bunch of extra ottertex canvas with the DIYGFC build for an awning this shape and size.
    Hopefully it'll suffice and fit in the bag well. It's definitely going to bring up the weight so 3/16" or thicker is probably going to be a must.
  19. Apr 2, 2022 at 8:16 PM
    #59
    davzx
    CO
    You should have plenty of room in the bag.
  20. Apr 11, 2022 at 4:33 PM
    #60
    nanserb
    Elliott
    2019 ZR2 Colorado
    Did the flip up rain arms and caps end up working out well?
    I only ask because the 9565K45 listed seems to be for smaller tube, maybe the 9565K46 is better since it fits 0.709"-0.805"?
