DIY 270 Awning for Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by davzx, Nov 22, 2021.
  1. May 16, 2022 at 9:34 AM
    #81
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Absolutely, I'm putting the DXF files you'll need to send to SendCutSend in the Google Drive folder that @davzx has linked in the original post.
  2. May 16, 2022 at 10:04 AM
    #82
    nanserb
    Elliott
    2019 ZR2 Colorado
    Awning bag is done, it ended up much bigger than I expected. I'm going to tighten up the end dimensions so that it's more of a snug fit.
    Otherwise, the awning worked fantastic.
    PXL_20220514_152722259.jpg PXL_20220515_014107996.jpg PXL_20220515_014036037.jpg PXL_20220514_230328784.jpg
    50Buck, Taco Camper, bot102 and 5 others like this.
  3. May 16, 2022 at 10:25 AM
    #83
    davzx
    davzx [OP] Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Hell yeah!
  4. May 17, 2022 at 7:58 AM
    #84
    nanserb
    Elliott
    2019 ZR2 Colorado
    @Taco Camper I updated all the cut files you can upload to Send Cut Send to have cut for the slot and tab version of the brackets that @davzx made.
    It's reversible (passenger/driver) until you weld the angled tabs on.
    Let me know if you have any questions.
    Taco Camper likes this.
  5. May 17, 2022 at 12:52 PM
    #85
    jessiescribner
    jessiescribner New Member
    Jessie
    I am re-creating this assembly in SolidWorks. I have most of it completed, but would like to confirm a couple areas. Would someone be able to export the entire assembly in a SW format, or in a .XT, .STEP file?
    thanks!!!
  6. May 17, 2022 at 12:58 PM
    #86
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    I am not positive what you are asking, but step is the typical file used so most people can use it with the most software's. I can probably help if that wasn't your question.
  7. May 17, 2022 at 1:06 PM
    #87
    davzx
    CO
    Just uploaded a .STEP version to the drive. Let me know if that worked for you...
  8. May 17, 2022 at 1:12 PM
    #88
    jessiescribner
    Jessie
    davzx[OP] likes this.
  9. May 17, 2022 at 1:36 PM
    #89
    nanserb
    Elliott
    2019 ZR2 Colorado
    @jessiescribner I put a step file of the slot and tab brackets in the drive folder as well if you want that variant.
    The arms I made for mine are @davzx design.
    jessiescribner likes this.
  10. May 17, 2022 at 1:53 PM
    #90
    jessiescribner
    Jessie
    I now have most of this drawn up and ready to start fabricating. A couple questions that someone can hopefully answer (maybe a couple photos)
    There is a "Rain Arm Tab" in the DXFs. Photos of this installed & in use?
    The "Front Sandwich Bracket". is this simply a securing point for stowage?
  11. May 17, 2022 at 7:33 PM
    #91
    Taco Camper
    Taco Camper Well-Known Member
    Got them and they look good. Thank you!
  12. May 20, 2022 at 3:12 PM
    #92
    nanserb
    Elliott
    2019 ZR2 Colorado
    The front sandwich bracket is there to sandwich the vinyl bag to the front bracket. I opted to use a third "intermediate plate" instead in order to save money with SCS.
    Here's the rain arms, I just finished welding mine up. I'll post pics with them installed. The ones in these CAD photos might be an earlier version.
  13. Jun 2, 2022 at 7:19 AM
    #93
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Did you ever weigh your awning to see how much weight savings you got from aluminum? Just wondering if it’s worth it vs just doing steel.
  14. Jun 5, 2022 at 8:27 PM
    #94
    nanserb
    Elliott
    2019 ZR2 Colorado
    I did not, but I meant
    I didnt, but I had meant to.
    I'm sure I will end up taking it back off in the coming weeks and I'll weigh it then
    Sub_Par[QUOTED] likes this.
  15. Aug 4, 2022 at 10:37 AM
    #95
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    This is awesome! How much did it cost to get the bracket cut by SCS?
  16. Aug 6, 2022 at 7:00 AM
    #96
    nanserb
    Elliott
    2019 ZR2 Colorado
    For all the brackets it was $120
    Another $20 if you have them bend the brackets.
    Afilao[QUOTED] likes this.
  17. Nov 19, 2022 at 10:47 PM
    #97
    jmartin2076
    jmartin2076 Well-Known Member
    Tacoma WA
    Here is my awning based off the plans in this thread. Jessiescribner did ask the hard work, I just asked and did the sewingPXL_20221119_210406627.jpg PXL_20221113_230324617.jpg PXL_20221113_230312028.jpg
  18. Nov 20, 2022 at 4:02 AM
    #98
    davzx
    CO
    Sweet! Nice work.
  19. Nov 20, 2022 at 1:38 PM
    #99
    davzx
    CO
    I weighed mine today while I have it off my truck to make some modifications and improvements. Sewed a new canopy with the same material I’m making my V2 wedge camper tent with. 600D Waterproof Ottertex Canvas. The cheap Amazon tarp I used first got a bunch of holes in it over the year - was way too thin.
    36 lbs. for the all-steel version and this heavier fabric. Not bad.
    SR-71A and 50Buck like this.
  20. Nov 21, 2022 at 10:34 AM
    #100
    nanserb
    Elliott
    2019 ZR2 Colorado
    Awesome! Way less weight than the commercial ones too!
    I'm curious how my part aluminum weighs
