Zuba987’s DIY high clearance rear bumper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zuba987, Mar 12, 2018.
  1. Mar 12, 2018 at 4:42 PM
    Zuba987
    Zuba987 [OP] Well-Known Member
    Enola PA
    2006 ACLB V6 auto 4x4
    Fully armored, STT Pros and Methods.
    Decided to built myself a high clearance rear bumper for my taco! It's a project. Wayyyy cheaper than buying one. So far everything has costed me less than $225 + labor.
    Not done yet (obviously) I will be adding pics as I work on it some more but figured I'd share with with some people.
  2. Mar 12, 2018 at 5:16 PM
    Redsyota
    Redsyota Well-Known Member
    Denver
    15' SPORT 6 SPEED ACLB MGM
    Some of the things...
    Looks great! A 4xinnovations style like this is the best looking to me. Did you consider mounting the hitch in the tube itself to gain the clearance ?
  3. Mar 12, 2018 at 5:28 PM
    Zuba987
    Enola PA
    Yes I did consider it however I do pull a trailer every once in a while, and with the hitch in the tube it would just be too high for my liking. Also the pre built receiver is already set up nice for the safety chains. I was willing to sacrifice a few inches of clearance for those reasons lol
    Redsyota[QUOTED] likes this.
  4. Mar 12, 2018 at 5:37 PM
    Redsyota
    Denver
    Either way it looks great, I'm anxious to see how you finish it out (the tops of the wings and where they meet the tube). I love to see people taking on these diys it give me motivation lol.
    ArceeCola likes this.
  5. Mar 12, 2018 at 5:40 PM
    Zuba987
    Enola PA
    Thanks! At first I was a little skeptical of building it since I don't have a whole lot of fabrications skills but realistically, its pretty simple and straight forward if you make sure everything gets done right the first time.... like the hc bed cut :eek:
  6. Mar 12, 2018 at 7:48 PM
    Marceleg9
    Marceleg9 Member
    Los Angeles
    2011 Tacoma TRD Offroad 4x4
  7. Mar 13, 2018 at 6:04 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    That looks really nice! Good job.
    Zuba987[OP] likes this.
  8. Mar 13, 2018 at 8:57 AM
    Caboverpete
    Caboverpete Well-Known Member
    Brad
    Chester county, PA
    2006 Sr5 Tacoma, 1994 Dlx Toyota Pickup
    Looks good!
  9. Mar 13, 2018 at 10:39 AM
    Stryker420
    Stryker420 Well-Known Member
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    I am right there with you. I refuse to pay $1000 for a bumper. Could you give some measurements on each piece or is that asking too much?
  10. Mar 13, 2018 at 11:45 AM
    Zuba987
    Enola PA
    Sure, I started put with a 4x4 tube with 3/16 wall, cut it to the length of the tailgate. And used 1/4 plate for horizontal and vertical mounts to the frame. I utilized the factory bumper and hitch holes and bolts. total of 5 bolts in each side. Everything else I used 3/16 plate. Aprox 30" long for the armor plates. Also the gussets used to strengthen the High clearance plates is 1.5" tube with 1/4 wall. If you want any specific measurements beyond that feel free to ask. FYI I'm not done the full bumper yet so I haven't figured out the measurements for little corners and stuff
    msfit, Biscuits and Papa Taco like this.
  11. Mar 14, 2018 at 8:33 AM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    I also plan to go with the 4"x4" 1/4 inch thick square tubing. Just a little overkill. I am getting an exact cut at 52.5" long for 74$. This is the width of the tailgate. My next step is to measure and design the 1/4" plates that will attach to my frame. I want them to poke through the 4x4 so I can attach license plate lighting on the inner edges of each plate as well as strengthening the bumper. Then I will make side plate and gussets just like you did. I wonder if I could use angled steel to make the mounting plates so that I can utilize the vertical and horizontal bolt locations...
    Ak-Alex, Bobcdn and Zuba987[OP] like this.
  12. Mar 14, 2018 at 10:25 AM
    Zuba987
    Enola PA
    I would totally recommend using both bolt locations. I know some people just use the vertical but personally if I was gonna take the time to build a bumper might as well make it as strong as I can while I have the chance. I guess a downside to that would be if I was to get in a wreak having so many bolt locations might cause the frame to bend. I'm willing to take my chances lol
    Caboverpete likes this.
  13. Mar 14, 2018 at 10:32 AM
    Zuba987
    Enola PA
  14. Mar 14, 2018 at 10:38 AM
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Can't wait to see the end result.
  15. Mar 14, 2018 at 10:57 AM
    Stryker420
    Benedict
    Mooresville IN
    2012 Tacoma DCLB
    Yeah I am going to go with angled steel 1/4 inch thick. I just have to get all the measurements correct. Could you tell me A,B,C and D measurements in inches? I really appreciate it!
  16. Mar 14, 2018 at 1:32 PM
    evanimpreza
    evanimpreza Well-Known Member
    Evan
    Joplin, MO
    White 2012 TRD Offroad DCSB
    Icon Stage 6, SCS Ray 10s, 33s, Rigid Lighting
    Pretty brave to cut into the truck without a finished bumper to put on it. Looking good so far.
  17. Mar 14, 2018 at 5:43 PM
    Zuba987
    Enola PA
    Well I sorta needed to cut first in order to get the measurements. Ive never actually had a chance to check one of these bumpers out in person. Going off internet pics and people who have also built one of these themselves just wasn't enough :thumbsup:
  18. Mar 14, 2018 at 5:44 PM
    Zuba987
    Enola PA
    Which pieces are you referencing?
  19. Mar 14, 2018 at 5:56 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Looks great so far!
    verynearlypure and Zuba987[OP] like this.
  20. Mar 14, 2018 at 6:00 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Are those D-ring tabs just surface welded to the box tube? If so I wouldnt trust pulling from them. They should be long enough to be through-welded so they cant simply 'peel' off
