DIY 2nd Gen Water pump replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05sctaco, Feb 24, 2012.
  1. Dec 20, 2015 at 1:33 AM
    #41
    freeflight
    freeflight Member
    I just received the AISIN WPT802 water pump from RockAuto. A few questions
    1. There is a obvious etch/cut on the part, seems to remove some serial no. Is this normal?
    2. Plenty of machining marks on the bottom mating surface, some deeper marks around bolt holes can be felt by running finger over them. Would these marks affect sealing capability?
    3. There is absolutely nothing warp the pump inside the AISIN box, not even a plastic bag. As you can see from the picture, those bolts not only made a big hole in the box during shipping, they also punched through the shipping box. Is this typical AISIN packaging? Does this look like a new part to you or someone's returned part?
    Thanks,
    Kevin
  2. Dec 20, 2015 at 4:26 AM
    #42
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    That ground out spot on the casing is probably where they poured in the liquid metal into the mold. It's just ground down a little rough. The mating surface is ok that's why they give you a gasket or a liquid gasket to seal the mating surfaces. As far as a tear in the box, I assume it was packed inside another box. With such a sharp edge along with the 4 bolts sticking out. I can see why their be some kind of rip/tear in the box from shipment. Does the box have grease marks or looks like it's been open several times? If not I wouldn't worry about it. If you're really that concern, I'm sure Toyota OEM pump would be a little prettier and come in a nicer packaged box. At a much higher price! Don't worry about it'll be ok.
  3. Feb 22, 2016 at 12:10 PM
    #43
    john81892
    john81892 Member
    2007 Indigo Tacoma 2.7 L 4x4
    My '07 2.7L 4x4 Tacoma's water pump just failed at ~95k miles. This is a great reference! I'll post a reply once I have completed this job.
  4. Feb 27, 2016 at 11:33 AM
    #44
    chrisduncansb
    chrisduncansb Member
    Portland, OR
    2013 Tacoma TRD Sport DCLB
    6" lift with 35x12.5 M/Ts. Lift is coming off soon though.
    My '08 4.0L TRD is at 115k miles, coolant still looks and smells great and no noise from the pump. I'm starting to wonder if I should take this project on as a preventative measure or just see how far I can take this pump. Any opinions out there?
  5. Feb 28, 2016 at 2:17 AM
    #45
    NJ_Tacoma
    NJ_Tacoma Member
    Vic
    Warren County NJ
    2006 Silver Tacoma TRD 4x4 Access Cab 6-Speed Manual.... Original Owner
    New frame courtesy of Toyota on 10/2015. A $12,000 job all on Toyota's dime. After 10 years of ownership I gotta say it's been a rock solid truck. Only problem is the front wheel bearings went out at 150K. Rest of the truck is stock original. Formerly was the original owner of a 1994 Toyota Extracab V6 4x4 DX Evergreen Pearl pickup 5-speed manual. Loved that truck!
    I'm seeing how far I can take the water pump. My 06 (I'm original owner) currently has 215K miles on the original pump. Coolant has been changed every 100K miles with genuine Toyota Super Long Life fluid.
    GilbertOz likes this.
  6. Feb 29, 2016 at 8:53 PM
    #46
    john81892
    john81892 Member
    So I started today and have removed everything to get down to the water pump. The biggest difficulty that I have had so far is removing the four nuts that secures the cooling fan to the water pump pulley. Mine were practically welded on but with some time and effort they relented. Ill post pictures after I finish the swap.
  7. Mar 1, 2016 at 4:46 AM
    #47
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Take many pics, I'm interested! Good luck.
  8. Mar 7, 2016 at 12:35 PM
    #48
    john81892
    john81892 Member
    I forgot to post the results of the swap. After two day of work (this was one of my first major replacements), I swapped out a water pump, thermostat, radiator hoses, and flushed/replaced coolant. That was a lot of work! Here are some pictures and descriptions of the process:
    http://imgur.com/a/S2MJO
  9. Mar 8, 2016 at 4:15 AM
    #49
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Is this a second gen 4 banger? It's certainly not a 1gr fe. Don't recognize the motor.
  10. Mar 8, 2016 at 5:27 AM
    #50
    john81892
    john81892 Member
    Yes this is a 2nd gen 4 banger!
  11. Mar 8, 2016 at 10:26 AM
    #51
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I must be one of the lucky ones also. My 2005 Tacoma currently at 145k miles and still with the original water pump and coolant. I'm gonna keep going until the pump starts weeping coolant or makes noises. Hope I can get to 200k miles
    GilbertOz and john81892 like this.
  12. Mar 8, 2016 at 11:09 AM
    #52
    john81892
    john81892 Member
    Best of luck. Hopefully my pictures will help!
  13. Mar 8, 2016 at 12:17 PM
    #53
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    174,000 and counting. New fluid but same water pump.
  14. Mar 10, 2016 at 7:26 AM
    #54
    esse10
    Texas
    174K? Cool, I'm considering changing the fluid when I get to 175-180k miles. It still looks pink and smells normal
    @john81892 ,Thanks
  15. Mar 10, 2016 at 7:44 AM
    #55
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    didnt you have to tension the serpentine belt to its proper specs when you put it back? how did you measure that it was the correct tension?
  16. Mar 10, 2016 at 10:14 AM
    #56
    cj13058
    Oregon
    Well I think it sets the tension on it's own. There is a tensioner pulley that does the work...use a socket to turn and release tension then belt can be removed. You will need a screwdriver to hold the pulley un-tensioned. After routing your belt back around take the screwdriver out and you're good to go.
    Unless, I did it completely wrong.
  17. Mar 14, 2016 at 9:14 AM
    #57
    esse10
    Texas
    I 2nd that it's got a spring loaded automatic tension pulley and no adjustments needed.
  18. Mar 14, 2016 at 9:57 AM
    #58
    cj13058
    Oregon
    Ahhhh...the words I was looking for.
  19. Mar 18, 2016 at 3:22 PM
    #59
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What is correct Torque for the water pump bolt's ?
  20. Mar 30, 2016 at 3:07 AM
    #60
    Bob2
    Bob2 Member
    Bob
    07 Tacoma
    Hi guys, I'm changing my water pump today. I have 176,000 and it started
    making noises, hope it doesn't take all day
