DIY ADD Actuator ECU
Discussion in '1st Gen. Tacomas (1995-2004)' started by treyus30, Jan 14, 2025.
  1. Jan 15, 2025 at 4:49 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Here's basically all the info my FSM has for the electronic ADD. It just shows which pins should have continuity with each other and which shouldn't. Doubt it helps, but figured I'd already looked it up anyways:
  2. Jan 15, 2025 at 6:02 PM
    treyus30
    treyus30 [OP] 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Thanks for the visual. Any idea what kind of current that motor pulls? (<5A fingers crossed)
  3. Jan 15, 2025 at 6:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't think it would be more than 5 amps but I haven't measured it.
    I do know the Transfer case and Diff lock actuators can draw around 10 amps if they are stalled but the ADD has a smaller motor.
  4. Mar 4, 2025 at 8:57 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Went ahead and having this manufactured after experiencing the mess of protoboarding it. Here is the only silver latching DPDT push button switch I could find. Super satisfying to press haha.
  5. Mar 5, 2025 at 11:21 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You can use the same aftermarket rear elocker switch on the front ADD motor. I'll dig up the info. I've done it before. You don't want the power to latch on. That will leave constant power to motor. It needs to be momentary and flip flop politarity to move which ever direction you need.
    https://www.offroadwarehouse.com/product/low-range-off-road-front-toyota-elocker-switch-diyelsf
    This is the rear actuator diagram, but same principle of operation. Wire colors are different.
    If you end up with the 8 terminal switch this is the diagram for rear. You'll have to compare front wire colors to rear to determine the difference. Terminals 8 and 7 are for an internal led that lights when it locks.
  6. Mar 7, 2025 at 3:28 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Too late. But not a problem as that is why there's a feedback loop to the PMOS which stops current once the switch activates (hence why it's not just a DPDT switch). Much greater reliability than a mechanical toggle as well
    mechanicjon[QUOTED] likes this.
  7. Apr 14, 2025 at 12:25 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    So, turns out the Toyota FSM is not entirely forthcoming with the limit switch behavior and I had to basically invert the design because of it. The switches are not Normally Open. They are Normally Closed.
    So during travel, the feedback would pick up voltage and turn it off, leaving the motor in a halfway state. To fix this, I had to swap polarity of the board, use NMOS instead of PMOS, and change the resistors to pull-down instead of pull-up. Thankfully this was doable on the 2nd iteration of the boards I had manufactured. It now works.Sadly this means the ground plane is now a +B plane, so I have to isolate it well, wherever I decide to mount it.
    Final solution here:
    The Molex plug is waterproof, and the whole set is only $5, so I'm definitely using them for future projects. I also poly-filled 4 pins with +12V and GND, so I can branch 2 extra circuits off the one input for other things, provided the total doesn't exceed the fuse ofc. Btw, the resistance of the motor is roughly 3-4 ohms, so pulls around 4amps.
