DIY: Amber DRLs/Signals Mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by xola3que, Jul 19, 2017.
  1. Jul 19, 2017 at 11:46 AM
    xola3que
    xola3que [OP] Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    A few TW members contacted me and requested a write up for the Amber DRL/Signal Mod like it came with the 2nd Gen. So here it is:
    Explaination of Mod: Use the signal light locations in the headlights as always-on DRLs. When the signal stalk is triggered, DRL will be deactivated and signal will override. Once the signal stalk returns to neutral, DRL will be ON again.
    Briefing: Use an ignition power source to run the daytime running lights. Signals and Emergency will trigger the 5 pin relay for blinking.
    Alternative 1: You can use the aftermarket switch back module for this mod but it costs a bit. From what I heard you can also use Toyota OEM module came with the second gen for this mod.
    Alternative 2: You can use the "always-closed" 3 pins relay but those are harder to find and more expensive.
    A: Accessories:
    1. Optional: (1) pair of 7440 amber LEDs. This one works pretty good.
    http://www.ebay.com/itm/JDM-ASTAR-7440NA-Super-Amber-Yellow-LED-Turn-Signal-Blinker-Parking-Lights-Bulbs/331909043630?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    2. Required: (1) pair of load resistors to prevent hyper flashing.
    http://www.ebay.com/itm/JDM-ASTAR-2x-7440-T20-LED-Decoder-Warning-Canceller-Error-Free-Anti-Hyper-Flash/331419649536?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    3. Required: (1) pair of 5 pins relay, this is what I used:
    http://www.ebay.com/itm/QTY1-CAR-RELAY-1-5-PIN-SOCKET-12V-VOLT-DC-40A-WEATHERPROOF-WATERPROOF-SPDT/272543681722?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
    4. Various wire extensions. I have few leftover sets wire harnesses from an HID installation so I cut it up and use the fuse that came with it. You don't have to go spend money on this but if you have to, I recommend a set of quality relay harness from Xenondepot or Morimoto. Don't cheap out with those ebay junks.
    B: Tools:
    1. wire striper
    2. solder gun
    3. Electrical tape
    4. a pair of wire sniper, pliers.
    5. Philip screwdriver
    6. 10mm socket
    7. zip ties.
    C: Installation:
    Follow the circuit diagram below for wiring. Zip tie all loose wires securely. Make sure you have good ground contacts.
    The result:
  2. Jul 19, 2017 at 12:40 PM
    MacMedic
    MacMedic Well-Known Member
    2016 Black Tacoma TRD Sport
    Nice Job...
    xola3que[OP] likes this.
  3. Jul 19, 2017 at 12:55 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    AMBER DRL FTW. Nice job OP.
    KTJO 4x4 and xola3que[OP] like this.
  4. Jul 19, 2017 at 2:24 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    cool idea...but here amber DRL are illegal and front signals have to be amber.
    Although its not usually enforced as I see plenty with white signals but still.
  5. Jul 19, 2017 at 2:33 PM
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    I think I am going to do this, but I think I am going to do white rather than amber to match the oem drl's.
    Will this work with a switch back so the drl's are white and then the signal is amber?
    Tacoma6MT and xola3que[OP] like this.
  6. Jul 19, 2017 at 3:26 PM
    bgoods
    bgoods Well-Known Member
    Brian
    Orlando
    2016 TRD Sport 4x4
    Nice mod, I like the look
  7. Jul 19, 2017 at 3:44 PM
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    I guess the first challenge is to find somebody making those dual LEDs in 7440 or 7443. I'm sure it out there
    GreyBaldTaco likes this.
  8. Jul 19, 2017 at 3:45 PM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    Amber DRL's are not illegal, in Canada the DRL systems can be White, Amber or Yellow.
    Joe23[QUOTED] and xola3que[OP] like this.
  9. Jul 19, 2017 at 3:46 PM
    ratcityrain
    Seattle, WA
    A quick google search shows some are available in the $45 range so not too bad. I think the Vled switch back does all the same you are doing, but making the cost 400% more lol
  10. Jul 19, 2017 at 6:10 PM
    Joe23
    hmm interesting. I know a few years back going to the track for a track day MTO would set up ride checks and one of my friends got a ticket for having amber DRLs.
    Guess it was just a bullshit ticket then.
    Optimaltaco[QUOTED] likes this.
  11. Jul 20, 2017 at 5:58 AM
    Optimaltaco
    Dave
    Cochrane, AB
    Yea further down on there it does talk about DRL's being allowed with the use of a signal light as well. The section on DRL is couple pages long.
    xola3que[OP] and Joe23[QUOTED] like this.
  12. Jul 21, 2017 at 11:03 AM
    EETaco2004
    EETaco2004 New Member
    2017 TRD Sport 4x4
    In order to get the DRL signal for 87a pin on the relay, did you have to cut and resolder/crimp the turn signals onto 87a pin?
    I'm attempting to start on this amazing mod and trying to see if there is an alternative to cutting any wires. Going for the clean look under the hood.
    So far I plan on using an add a circuit on the hazard light fuse in the cabin to set off the switch in the relay for pin 86. For the constant ignition source pin 30 I plan on doing the same add a circuit with the DRL fuse. So the LED DRL will always be on with the new amber DRL.
    Bastek likes this.
  13. Jul 21, 2017 at 11:24 AM
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    I knew somebody actually read the write-up :thumbsup:. BTW congrats on your first post.
    The load resistor set you get off of the link came with the 7440/7443 sockets and butts. Splice these off and use them instead of cutting into your factory wires. The socket goes into the lamp, the butt mates up with the factory harness with the resistors intact.
    Bastek and EETaco2004[QUOTED] like this.
  14. Jul 21, 2017 at 11:36 PM
    browndirtcowboy
    browndirtcowboy Well-Known Member
    Manteca
    My amber driving lights :)2017052795131619.jpg
  15. May 26, 2018 at 10:37 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    Alejandria Antioquia Colombia S.A.
    White 2003 Hilux DCSB 4x4 HI-RIDER +. 2.4L I-4, 5 spd.
    275/70R16 tires, gasolina or CNG fuel, Konig shox, Energy Suspension poly bushings,
    ADAM -
    You need to check that schematic again. If the drawing shows the turn signal relays in the "OFF" position, Then no voltage is applied to the LEDs when they are turned on. When the DRL relay is operated, nothing will happen either.
    - JAMES
  16. May 26, 2018 at 10:38 PM
    Aluttropp
    Aluttropp Member
    Gresham, OR
    I was just seeing that.... Let me re-post it again.
  17. May 26, 2018 at 11:27 PM
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    Electrical nerd...We've got an electrical nerd here!!! :D
  18. May 26, 2018 at 11:29 PM
    xola3que
    Long Valley, NJ
    2019 Tacoma Sport
    I can update the front page (with credit given) so people doesn't have to dig all the way back here to find it.
  19. May 27, 2018 at 12:32 AM
    Aluttropp
    Aluttropp Member
    Gresham, OR
    Not yet! My schematic skills are terrible. I have to redo it....
  20. May 27, 2018 at 7:50 PM
    JAMES399
    JAMES399 EL CAPO
    JAMES
    And your point is ... ??? Everything on today's trucks is computer controlled. A knowledge of electronics is essential to being able to maintain a vehicle today, and to be able to modify the electronics to make it better. I'm an electrical "nerd" and proud of it. And ... I'm certain I know more about my truck than you ever dreamed of.
    - JAMES
